WASHING MACHINE CAUSING GREY STAINS
I've had my washing machine for about 6months and in the last 3months I've noticed grey stains on my clothes, it doesn't cover the whole item, it just leaves patches. I've tried solving the problem myself by following the maintenance instructions but nothing seems to work. If anyone knows what's causing the stains I'd be grateful for the solution :-)
  • lglaspey Mar 05, 2009
    We are having the same problem! After talking to a plumber, they recommended changing the stainless steel hoses feeding water into the machine. They said over time the inside of the linings can start corroding and may cause stains on clothes. If this does not work, they suggested emptying the water from our hot water heater and checking the annode. Apparently the annode can go bad and may discolor the water stored inside as a result. Good luck!!
  • 15,935 Answers
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
The machine is doing yellow spots on several clothes and it is clean from inside and nothing could cause rust stains inside
Search Results
    Washing Machine Stains: Possible Causes And Cures
    www.stain-removal-101.com/washing-machine-stains.html
    Have you ever experienced washing machine stains, where your machine is the culprit for ... Just never put clothes in when doing this as it will discolor them. ... I get largeyellow spots on my Battenberg linens after washing, or maybe they ...
    Removing Yellow Stains from Washing ' Clorox
    https://www.clorox.com/...laundry/removing-yello...
    The Clorox CompanyFeb 4, 2010 - I do my laundry at a neighborhood laundry that has. ... into the machinefor the wash cycle but still get the yellow spots. ... Since you diluted it in a gallon of water, the yellow spots/splotches should not be from the liquid bleach. ... Rinse and air-dry to see if it has any effect before doing a large number of items ...
    Weird yellow spots on whites - Home Forums - GardenWeb
    ths.gardenweb.com > Home Forums > Laundry Room
    Jul 27, 2010 - I wash on warm/cold using powdered Tide and nothing else. The laundryemerges from the machine with yellow spots in places. Not pale ...
    Mysterious yellow spots on clothes, bedding, etc ..
Feb 03, 2016 | Washing Machines
Aquarious wd63 washing getting grey stains at end of wash cycle
Hi.
Can you tell me? Does the washing machine sound noisier than normal in spin? Does it sound rough?
The grey marks could be drum bearing wear causing oil from the bearing to enter the washing machine. Sometimes you may see grey or black dots on your clothing.
If this is the case then repair cost is typically around £100 depending on where you live.
Hope this helps
Aardvark Repairs
Nov 18, 2009 | Hotpoint Aquarius WD63 Front Load...
I am getting stains on my dark clothes that look like oil stains.
Check that the dispenser is clean, it may be gunged up with black gunge, use soda crystals and put machine on hottest wash. If all is clean it could be down to seal gone in drum letting grease into system. Good luck, let me know how it goes.
John
Sep 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Clothes come out with stains on them
I had a similar problem with my Kenmore front loader. Turned out that the rubber lining around the door was trapping dirty, soapy water causing a nasty residue to collect. That residue got onto the clothes. I cleaned the rubber liner and now keep the washer door open between uses. I still occasionally wipe down the rubber liner with a wet rag. Problem seems to have been solved.
Jun 13, 2009 | Samsung WF328AA Front Load Washer
Grey Stains on my whites
Need ot check the main seal and the main bearing. You can do this by accessing the rear of the unit.
Feb 13, 2009 | EuroTech EWC177 Front Load Washer / Dryer
My Washing machine stains clothes; they come out with brown rusty stains. Otherwise the washing machine works fine. my washing machine is lessthen three years old and always give brown stains in white...
I had the same problem, and it turns out that it is NOT the seal. It is the liquid fabric softener. The fabric softener dispenser needs to be cleaned periodically or it gets a black waxy, goopy, build up. It is this same buildup that ends up staining your clothes with dark brown or black stains. Just remove the dispenser and wash it our very well and the problem will be gone.
Oct 25, 2008 | Washing Machines
Old washing machine is starting to leave grey streaks on clothing
hmmm..let's see..sounds like you have some residue accumulating from something possibly seeping into the tub. That can be old rubber, a metal sheath, or even an leak of lubricant. Like an old car, there are parts of every mechanical device that need to be attended to.
I'd recommend you find the most seasoned person that works on older machines, to come by and assess what is 'leaking' on your clothing. Grey comes from something metallic or rubber/plastic.
Hope you can solve this one, and keep that old machine happy.
Feb 19, 2008 | Washing Machines
Grey gunge discharged ion clothes leaving spot stains from the drum on clothes
Colud be oil from the bearings, which means that the bearings is on their way, or it could be that the machine is dirty inside. It happends when washing just on low temperatures (60* and lower).
Dec 19, 2007 | Zanussi FJD1666W Front Load Washer
Miele W1119 not cleaning white clothes properly
liquid detergent is a pain and not as good as powder. liquid detergent often makes machine smell as well i doubt there is a fault with the machine. try putting on a boil wash with no clothes and this will clear out the slime left behind by the liquid detergent. you didn't say what colour the stains are but iy grey or brown it could be from your water supply - a more common problem than you might think. turn off water and remove the supply hose. there should be a gauze filter at one end and make sure not clogged with dirt. also look into the spigot of the vavle and see if any muck there.
May 11, 2007 | Miele Touchtronic W1119 Large Capacity...
Stains on clothes
Have you tried Calgon to get rid of limescale deposits? Also have you used any laundry bleach at any point, because it stays in the machine for ages and clothes come out with faded patches and bleach marks for weeks afterwards.
Sep 16, 2006 | Baumatic BTWM4 Front Load Washer
Washing Machines Logo
481 people viewed this question
Top Washing Machines Experts
