Question about Hotpoint Ultima WF860 Front Load Washer
How do i open the filter on a hotpoint wt721 - Hotpoint Ultima WF860 Front Load Washer
  • 4 Answers
IT WILL EITHER BE BEHIND FRONT PANEL OR TILT MACHINE ON ITS BACK IT COULD BE ACCESSED THROUGH THE BOTTOM ITS A ROUND THING WITH SMALL SCREW IN IT REMOVE SCREW AND TWIST AND CAREFULLY REMOVE TAKE CARE WITH WATER AS WATER THATS IN DRUM WILL BE REALEASED ONCE YOU DO THIS BUT IF BLOCKED WITH A PENNY OR FLUFF OR WHATEVER MACHINE WILL NOT DRAIN OR SPIN
Posted on Mar 04, 2009
Hotpoint Ultima WT721 F 08 fault code
Try the brushes first. I'm guessing the carbon deposits on the floor are from the brushes.
Nov 16, 2013 | Washing Machines
Hotpoint ultima wt721. Cycle runs then stops at drain/pump out with alert code f - 05
Hotpoint (Indesit!) F05 decodes as 'pump block'.
I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Mar 21, 2011 | Washing Machines
My Hotpoint ultima WT721 1200 spin keeps tripping out all plug sockets. Have changed fuse but still does it. What could it please?
hello, bad earth check all the wired connection to the washer if these are ok then check your socket wires make sure wires are tight if these ok then there may be fault inside the washer power supply hope it helps
regards
shaun
Jan 15, 2011 | Hotpoint Washing Machines
What does the message F-08 mean on my Hotpoint Ultima wt721 please?
Error code F08 that the heater relay cannot be activated.
Check all connections to the module, pressure switch, and heater element.
Hope this helps.
Feb 01, 2010 | Washing Machines
My hotpoint washing mechineall displays flashing when we put on .why?model wt721
Basically it is telling you that it has an error. Countthe number of flashes and see which lights actually flash and then refer to your user manual and it should identify what is wriong.If you don't have one then see which lights are flashing and drop me an email to kw7157@yahoo.co.uk in the next 8 hours.
Nov 10, 2009 | Samsung Washing Machines
Hotpoint ultima wt721 error code fo2 showing! will not work properly!
Error code F02 means the motor has jammed, and or the tacho is loose or broken. .Check the motor hasn't jammed up somehow, or that the small tacho coil on the end of the motor hasn't dropped off (tip the machine back and it's in between the brushes - it should be held in place with a clip. If it's hanging loose it's the fault)
This fault code basically means the PCB cannot detect any impulses from the tacho coil on the motor, so the main implication is that the motor is just not running. However, because other fault codes cover most of the other motor faults, the PCB thinks the motor may be physically jammed. That is, as far as the PCB is concerned, it is supplying the motor with power, but it can't detect the motor is running. This fault is not caused by worn carbon brushes because on these washing machines, an open circuit on the motor causes the washing machine to do nothing at all. It would not fill, or empty (as well as the motor wouldn't run) although the indicator lights would work.
Nov 03, 2009 | Hotpoint Ultima WF860 Front Load Washer
Found filter on front of my WT721 hotpoint but tried turning anti clock wise it turns slightly but can,t get if off !
You are turning it the correct way, could be something stuck in the filter, just keep trying to unscrew it and pull hard at the same time.
Please rate my solution.
Thanks.
May 03, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ulima wt721
You will find the tacho on the opp end of the motor to the pulley..
Check to see if it is loose or broken, if it is loose, just push it back in to position.
Plz rate my solution,
Thanks.
Jan 21, 2009 | Hotpoint Ultima WF860 Front Load Washer
HOTPOINT ULIMA WT721 FAULT CODES F5 AND F11?
my hotpoint ultrima wt721 has stopped with f-5 showing the door has stayed locked wot do ido
Jul 15, 2008 | Washing Machines
Hotpoint Ultima WF860 Front Load Washer Logo
536 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
