Question about Syntax SV266M Motherboard
My system will only work in safe mode
It wont load in normal load, only in safe mode..i switched everything to another case and now this ic happening...i am funning xp pro
  • 67 Answers
If you have the XP pro disk. You may want to put it in your Cdromand restart your PC. When it asks you "boot from CD" press enter. On the setup menu chose repair. It may fix your XP problems. Second solution could be upgrading your service pack.
Posted on Mar 04, 2009
  • 75 Answers
You have a driver issue.I would suggest formatting and reinstalling xp,or use live chat to walk you through finding and removing bad driver.
My computer says its restarting but it hasn't and it wont shut off
Hello, if the Windows operating system, then wait as the operating system upgrades.
Nov 11, 2016 | Computers & Internet
My sylvania netbook wont load it just shows the logo.i get the mouse but thats all.
AS YOU ON THE SYSTEM AND EVEN BEFORE WINDOWS STARTS KEEP PRESSING THE F8 KEY CONTINUEOUSLY. A MENU WILL APPEAR. SELECT SAFE MODE AND ENTER. WINDOWS WILL LOAD IN SAFE MODE. THIS WILL SOLVE SOME OF YOUR PROBLEMS. NOW RESTART THE SYSTEM IN NORMAL MODE.
IF THIS DOES NOT WORK SELECT "LOAD WINDOWS WITH LAST KNOWN GOOD CONFIGURATION " AND THEN RESTART. THIS WILL SURELY SORT OUT YOUR PROBLEM.
PLS REPLY OR COMMENT. THANKS
Jun 10, 2011 | Computers & Internet
Wont get past Microsoft Windows XP loading screen on Acer Aspire1
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 17, 2010 | Acer Aspire One AOA150-1126 Notebook
My pc wont even load up. it just gets stuck on the first HP screen with press f9 or f10. it just freezes up, and i dont know what to do. ive tried pressing both of the keys but none work.
try to start it in safe mode, then you can run system restore back to see if this fixes it. when computer loads up and shows the first screen, then push f-8 before it fully loads, this will take you to the safe mode screen, choose safe mode, then when loaded run system restore back to where the problem was ok. if this does not work then I would restore windows from the backup cd. if using safe mode when rebooting, it will change back to normal.
Feb 07, 2010 | HP Mini 1000 Netbook
Lcd screen broke external monitor wont work
Sounds like you resolution is too high or vista doesn't recognise your driver.
Try starting in Safe Mode by powering up your PC and tapping the F8 key until you see a menu. Select Safe Mode from the menu. Once in safe mode change the resolution to 800x600 then restart in normal mode.
If that doesn't work then download and install the correct drivers for your display card here;
ftp://ftp.work.acer-euro.com/notebook/aspire_3680/
Once downloaded, you may need to install it in safe made once again.
Thanks
C
Mar 28, 2009 | Acer Aspire 3680 Laptop
I can only get in my computer in safe mode.....why
Are you running Windows Vista? In safe mode, click on start and type "msconfig" without the quotes. There is an option to boot only in safe mode. Change that and it should solve our problem.
Mar 04, 2009 | Syntax SV266M Motherboard
Can you help? Have a Advent 7096 laptop protected by PC Angel. Have run system recovery using 4 discs. Cannot get into Windows - message reads "load needed dll's for kernel" Not my machine but...
If you having problem running system recovery in normal mode try running system recovery in Safe Mode by pressing F8 key when you turn on the laptop.. a selection pop-up, select your primary hard disk where your windows installed still pressing F8 then a Boot Selection appear select Safe Mode after starting in Safe mode do the system recovery.. still not working choice the Last Good Configuration. TY
HOPE I CAN HELP
Dec 04, 2008 | Computers & Internet
My presario 500 wont even turn on
try running it in safemode and if you have recently added any new hardware or software that may be causing your problem uninstall it while you are in safemode.
As the computer boots press F8 to enter safe mode. If this is successful then everything on the screen will look big, ignore that for now. uninstall anything that may be causing the problem. If you have not loaded anything lately, then while in safe mode restore your computer to an earlier date when you know that everything was working okay.
You can do this by going to Start>all programs>accessories>system tools>system restore. Then choose a date when you know that things were okay and press restore. You computer will restore to the date you selected and it will reboot. If asked to whether you want to start windows normally after the boot then select that option.
I hope this helps
Nov 14, 2008 | Compaq IDE CD-Rom Drive Presario 500...
Cannot get out of running windows normally
You didn't loose you work, windows only got corrupted as what often happens. Start up into safe mode, then run "scan disk" and select fix errors automatically, it might take a while to run. Maybe with a little luck it might find some errors and fix it.
Worst case situation - put the hard drive in another computer that boots in order to back up work, then put it back in your machine and buy a copy of windows xp. Then install drivers from Acer's website. (might have to use a jump drive with another machine to install first network drivers on your machine)
Hope this helps maybe a bit......
Apr 25, 2008 | Acer Aspire E360 PC Desktop
Screen freezes
If you can manage to access the safe mode troubleshooting please do it. By pressing F8 afre the POST and before windows loads. Select Safe mode and let 'em continue load the safe mode desktop. However if the safe mode won't work. You need to reinstall the system. You can use your compliment Recovery CD in doing so. Hope this will give you hints.
Best regards,
Rosener Guyano
Feb 14, 2008 | Acer Aspire 3690-2196 Notebook
Syntax SV266M Motherboard Logo
110 people viewed this question
Top Syntax Computers & Internet Experts
Gbenga
Roy May
Are you a Syntax Computer and Internet Expert? Answer questions, earn points and help others
