My hp photosmart 2710 all-in-one quick working one day. it turned off and can not get it turned back on. thought the power cord was the problem, so I purchased a new power cord. still have the same problem. is there and internal fuse or something that can fix this thing? Thanks, Jim
  • 75 Answers
Hi,I am sorry to say no fuse inside.the power transformer inside has most likely burned out.you can contact hp and see if there is warranty.
Posted on Mar 04, 2009
My HP Photosmart 2710 keeps shutting down, either when printing, scanning, or sometimes just on its own. I can only get it to restart by removing the power plug from the power supply and reinserting it
The most common reason for this is that the power input in the printer has a bad solder joint.
Wiggle the power connector at the back while the unit is powered up.
If it goes off, then that connector inside the printer just needs to be soldered back down.
The other possibility is that the power adapter itself is failing, which is really hard to test without another power adapter to test it with.
Mar 19, 2011 | HP Photosmart 2710 All-In-One InkJet...
HP Photosmart 2710 Scaning software
The software for the HP Photosmart 2710 All-In-One InkJet Printer can be found at
http://www.hp.com/#Product
After arriving at the site, click on the subheading "Support & Drivers", then follow the 2 steps
listed to obtain the needed software.
Jan 22, 2011 | HP Photosmart 2710 All-In-One InkJet...
I need a replacement power supply for hp2710 printer
hello, this should not be too hard to find really. you may even be able to buy at BESTBUY or Office Depot.
here is a direct link to a store that should have it.
HP2710 power cord
EBAY is another great option
hp printer cord
hope this helps good luck!
Mar 27, 2010 | HP Photosmart 2710 All-In-One InkJet...
HP Photosmart 2710 will not power on
Make sure the cord is not detached from the module itself. Please see support articles here and here to guide you through this issue. There are some basic tests you can perform, but you may have to find another one to confirm the source of the problem as the adapter or printer. Sometimes a local printer tech will have one you can use to check your printer, if you take the printer in to them.
Here's one source of a replacement, if it turms out to require one.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 24, 2009 | Office Equipment & Supplies
I want to purchase a power supply for a HP 2710 four in one printer
visit the below weblink
https://wimpro.cce.hp.com/ChatEntry/Chat.aspx?productOID=420428&productLine=5M&productSNI=hppsc2710a391140&productName=HP+Photosmart+2710+All-in-One+Printer&productCategory=421635&SCOID=238445&h_cc=us&h_lang=en&lc=en&PSOID=391138&lang=en&cc=us
Dec 31, 2008 | HP Photosmart 2710 All-In-One InkJet...
Shutting down is running across my screen
Do This: Performing a power reset
  1. Press the On button to turn off the HP All-in-One.
  2. Unplug the power cord from the back of the HP All-in-One.
  3. Unplug the power adapter from the wall outlet and wait for 30 seconds.
  4. Plug the power adapter back into the wall outlet.
  5. Plug the power cord to the back of the HP All-in-One.
  6. Press the On button to turn on the HP All-in-One.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 03, 2008 | HP Photosmart C7280 Laser Printer
HP 2710 Hit by Power Surge
Please perform the following steps.
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
Please do perform the following steps also:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
I hope you are located in United States of America and if so, please check the following link where in you can go ahead for the service.
http://hp.via.infonow.net/locator/us_partner/
Regards,
Sagar
Apr 26, 2008 | HP Photosmart 2710 All-In-One InkJet...
HP Photosmart 2710 All-In-One... Not Turning on Again...
Press the switch off and then again ON from the Power Plug where you have pulgged it in. This is the onle solution.
The another one is that when you give a Print command it will be automatically turned on.
Feb 04, 2008 | HP Photosmart 2710 All-In-One InkJet...
HP 2710 All in One Printer/Scanner/FAX and Vista
There are two models of printers starting with the number indicated. Both have Vista drivers and both have documented vista installation issues. Using the following link
HP Photosmart 2710
Select the correct model
Under software and downloads you will find the software necessary.
Below that you will see a link for Trouble Shooting software ...
Click it then Windows Vista and you will see two potential installation issues you may encounter.
Dec 17, 2007 | HP Photosmart 2710 All-In-One InkJet...
69 people viewed this question
jasbo
jasbo
