Question about Xerox Phaser 7400/DXF Laser Printer
Printing envelopes from InDesign
I am having trouble printing an 7.5" x 5.5" envelope from InDesign to my Phaser 7400. The envelope keeps coming out with the address scaled down and in the wrong location on the envelope. Sometimes the printer even says "wrong paper size" even though I have set it up in the printer dialog box on the printer and my computer. When I print it from Quark I have no difficulties. I have installed a new driver and it made no difference.
Thanks!
  • 390 Answers
SOURCE: MP460 printer--problem w/ envelopes
You seem to have clogged nozzles/printhead. Take out cartridges, do a thorough clean down where cartridges sit, the printhead, even the roller as well. Run your printers own cleaning maintenance before you do it manually with cleaning solution. Problem should be gone when you reinsert cartridges. Don't froget to reset ink levels and cartridges. good luck!!!
Posted on Aug 31, 2007
  • 12 Answers
SOURCE: Envelopes and labeles
Go the "print" dialog and select "settings". Ensure that the paper size, margins and orientation are not set for 8.5x11.  You did not mention the software you are using to print the envelopes/labels so this is the only guess I can give.   I have seen software that made me have to override the settings before.
Posted on Oct 15, 2007
  • 2072 Answers
SOURCE: Envelope Feeder is not accepting the command
> Home > Support & Drivers > Knowledge Base
Solution --> Phaser 4400 Printer: Printing envelopes
Printing EnvelopesEnvelopes can be printed from the optional envelope feeder, the Multi-Purpose Tray, or Tray 1, 2, or 3.
Guidelines for envelope printing
  • Use only paper envelopes.
  • Do not print on the back of the envelope.
  • Never use envelopes with windows, metal clasps, or exposed gummed surfaces.
  • Keep unused envelopes in their packaging to avoid the effects of moisture and dryness, which can affect print quality and cause wrinkling.
  • Envelopes may wrinkle depending on weight and stiffness of the envelope.
Many applications include a tool for creating an envelope document. For example, Microsoft Word includes an Envelopes and Labels feature in the Tools menu. Be sure to:
  • Select faceup.
  • Clear Clockwise Rotation.
  • Select the feed method with the image centered and the stamp on the envelope to the upper left.
caution_image88x30.gif Never use envelopes with windows, metal clasps, or exposed gummed surfaces; they can damage the printer. Damage caused by using unsupported envelopes might not be covered by your printer's warranty.
note_image33x30.gif Note: The heat from the printing process can melt certain types of envelope glue. If the envelope flap sticks shut after printing the test print, tuck the flaps inside the envelopes when printing the remaining envelopes. Printing envelopes from the envelope feeder
  1. Insert the envelopes into the envelope feeder. For more information, refer to the Trays section of the Trays and Paper Guide on the Interactive Documentation CD-ROM.
    • Place the side to be printed faceup.
    • The top of the envelopes should be toward the left of the printer.
Posted on Feb 19, 2008
  • 2072 Answers
SOURCE: Xerox Phaser 7400
That is caused 99 percent of the time by the fuser.
There is a solid aluminum roll and a silicon rubber ( pressure) roller in the fuser. The pressure roller either developes some flat spots from park ( non running) time and over time heat and use cause it to deform and become out of round. What then happens is when the paper enters the fuser it does so with a slight twist, and the pressure of the fuser, for lack of a better term, Irons in that crease during the fusing process.
Gave the explaination so you would understand what is happening.
Posted on Mar 07, 2008
  • 2072 Answers
SOURCE: Printing Address on Envelops
E-mailing you the info I am finding
Posted on Apr 04, 2008
I can't get anything to print from tray 1, the manual feed. I'm trying to print envelopes and they keep printing on 8.5x11 paper from tray 2. If I put envelopes in tray 2 it won't print
Have you already tried this? After you click print and select your printer, click properites and select your paper from 8.5x11 to Envelope.
Jun 25, 2012 | Xerox Phaser 8560MFP Laser Printer
Xerox phaser 7400DN jabs at fuser
The printer trays accommodate most sizes and types of paper, transparencies, or other
specialty media. Follow these guidelines when loading paper and media in the trays:
- Envelopes, labels, and glossy paper can be printed from Tray 1 (MPT) only.
- Transparencies and custom size paper can be printed from Tray 1 (MPT) and Tray 2.
- Fan paper, transparencies, and labels prior to loading them in the tray.
- Use only paper envelopes. All envelopes should be printed single-sided only. Some
wrinkling and embossing may occur when printing envelopes.
- Do not overload the paper trays.
- Adjust the paper guides to fit the paper size.
- If excessive jams occur, use paper or other media from a new package.
Mar 06, 2011 | Xerox Phaser 7400DN Laser Printer
I have a Xerox Phaser 6180MFP and when I print #10 standard envelopes and #9 renturn envelopes the envelopes come out with badly pressed wrinkles on the end of the envelope that comes out last. I have...
I am looking for a diagram on how to print envelopes with my phaser 6180 mfp - when I put the envelopes in, it keeps telling me that I need to put paper in. where can I find such diagram?
May 21, 2010 | Xerox Phaser 6180N Laser Printer
Envelope printing
The manual bypass tray on the Phaser 8400 can be set only when you have paper in the tray.
The envelope will read in the set up when you have it in the tray.
Nov 12, 2008 | Xerox Phaser 8400 Laser Printer
Ink
On the fuser (under the top cover), there are 2 green levers with envelopes on them. The one on the right is probably flipped up. The purpose of these levers is to decrease pressure on the paper when printing on envelopes which are 2 or 3 layers of paper. It reduces the wrinkling that occurs when printing envelopes on most laser printers. Flip that lever down and you're golden.
Nov 04, 2008 | Xerox Phaser 6120/YN Laser Printer
Apr 04, 2008 | Xerox Phaser 7300DN Laser Printer
Envelope Printing on HP 5610
Installed SR-3 from Office Word. It did the trick.
Mar 10, 2008 | HP Officejet 5610 All-In-One InkJet...
Printing envelopes
Try setting the page setup to 8.5x11 and adjust the margins to landscape, top and left margin approx 4". A lot of times the envelope templates are afterthoughts.
Pagemaker programmer's supervisor, "Forget that template, nobody will ever print envelopes in Pagemaker"
Hope this helps!
Mar 02, 2008 | HP Color LaserJet 2600n Printer
  • Select faceup.
Feb 19, 2008 | Xerox Phaser 4400B Laser Printer
Xerox Phaser 7400/DXF Laser Printer Logo
871 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
