Question about Intel Celeron D 325 2.53GHz 533MHz 256KB Socket 478 CPU (Bulk)
What is DDR2 graphic cards ? help
I want to buy a new graphic card. so, i went to a site called http://www.sparkle.com.tw in it there are PCI graphic cards not PCIe.It says that Memory Clock : 512MB DDR2 .the name of the graphic card is GeForce 9400 GT Series - SP94GT512D2L-HPP.
what do you mean by DDR2?
for what this DDR2 stands for Can i use this on my Celeron d 325 CPU
2.53 GHz.My mother board is Intel® Desktop Board D845GVFN.And i have 2GB ddr ram.<<<<<I saw Memory Type : 1024MB DDR2 for another card in the same site can i use it ?.its name is GeForce 9400 GT Series - SP94GT1024D2L-HPP.
PLEEEEEEEEEEEEEEEEEEEEEEEEEZE help me
  • Anonymous Mar 11, 2009
    the spacific type of an computer was in my schoolk,, pakk
    Problem Solver:
  • 17 Answers
The DDR2 is the type of memory used on the Video cards board. It doesn't affect if you are able to use the card in your computer. What does matter is the form factor of the graphics card, which is typically PCI, PCI-E or AGP. If you can look at *********** board, you need to look and see if there is a graphics card already installed(It may be built into your motherboard. Either way, your looking for about a 3" long by 1/2" high white slot, or a similar brown slot... if you don't see either of those, you more than likely will use a regular PCI slot... these are about 5-6" long and white. Best thing to do is find out the make and model of your motherboard and look for the soecs online. Or you can download a free program called Everest Home Edition. Run that program, and it will give you all the information you need. Be careful if it PCI-E, because there are different speeds, PCI-E 1, and PCI-e 16(there might be more, it's been a while since I've dealt with video cards), but make sure you know which one you have first.
Posted on Mar 04, 2009
    Scholar:
  • 53 Answers
Let's make this clear, There are many factors that contribute to a videocard's performance. The BUS which is the connection from the card itself to the Motherboard , though not the most important, is one of them.
PCI is extremely slow compared to PCI express and a videocard with PCI bus suffers from a strong bottleneck that makes it quite unsuitable for 3D graphics.
a PCI card is good as second display adapter to connect extra monitors to your pc: handy feature for data monitoring and multitasking but not that much as a gaming card.
Your motherboard does not have an AGP slot, but also has an Intel integrated graphic chip, so a PCI Nvidia 9400 will be quite a big upgrade, but don't expect high gaming performance...
furthermore Graphic memory speed has a big impact on performance, but size does not.512MB DDR2 is a big but slow memory and 1GB I can say it's totally useless, you need to use a resolution way over full HD to take advantage of it, but a PCI card performs really bad on that.
  • Aenim4 Mar 04, 2009
    By the way your computer is quite fast, but does not have much "expansion room" on his head. you need to change motherboard if you need graphics, and buy an AGP video card(PCI xpress is only on newer motherboards which probably do not fit your CPU), then you will notice an extreme improvement in graphc performance. The question is, is it worth the price? You might consider buying a new machine for that kind of stuff and keep your old machine as a backup machine just for dowloads and office work.
Drivers for sparkle graphics cards
Download and run "Driverpack Solutions" Click this link for the site.
http://drp.su/
It will find and install the correct drivers for you.
Mar 17, 2012 | SPARKLE Computer GeForce GTS 250 - 1 GB...
When i installed the driver software my computer wont boot..
just check the Bios configuration
is you ned to change PCI to VGA or Same in to Bios setup and rebot the pc
Nov 02, 2010 | SPARKLE Computer Sparkle GeForce 8500GT,...
Black Screen after installing new NVidia 9400GT
Put the old card back in, remove the old drivers and restart it in VGA mode.
You don't say what operating system you use, but XP & Vista you should be able to hit F8 before the windows splash screen to select VGA mode or Safe Mode.
Once you do that you should be able to put the new card in and start it in standard VGA mode then load the new drivers.
May 25, 2010 | SPARKLE Computer Sparkle GeForce 8500 GT /...
Monitor
have you tried another monitor with the card ?? if after changing the monitor it still vibrates then replace the card or if you overclocked it put it to default settings
Jan 17, 2010 | SPARKLE Computer Sparkle GeForce 8400 GS...
Will the Sparkle 8500 gt *PCI* work with XP?
Sure, it should have an option to use DX9, make sure it's updated though. Also google the specs of your card and see if that helps.
Apr 05, 2009 | SPARKLE Computer Sparkle GeForce 8500GT,...
Which is the BEST graphic card for celeron d 325
For 99.99 on newegg you can get a Sparkle 1GB GeForce 9400 GT, DX10, 550 MHz Core Clock, Dual 400MHz RAMDAC, Shader 4.0...
The model# is SP94GT1024D2L-HP
Neweggs Link for this card is:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814187058
Sparkle's Link for Product Info is:
http://www.sparkle.com.tw/product_detail.asp?id=94&sub_id=273
Asking which of anything is the best is really a matter of opinion, but as far as the hardware capabilities for an older standard card go, this one has to be as good as it gets. (Actually, I'm a pretty impressed...I didn't know any PCI card could do what this does. Although it won't stand up to the bus speed of a PCIe card, or even an AGP card, if all you have is a PCI slot, this is your card!)
Mar 04, 2009 | Intel Celeron D 325 2.53GHz 533MHz 256KB...
VGA CARD for ASUS P5RD1-VM
hi,
Try to visit this site.
http://www.sparkle.com.tw/product.asp?id=70
http://ati.amd.com/products/Radeonhd3800/specs.html
http://usa.asus.com/products.aspx?l1=2&l2=8
Just chose PCI EX depends on your budget.
regards!
Feb 17, 2009 | ASUS P5RD1-VM Motherboard
Install
This dependson your motherboard mate... the PCI port is the white one on ypur motherboard so all you need to do is line up the pins n just seat the card like a plug.. you might have to undo a backplate where the connector will go at the back of the tower.. screw the video card in n voila
Feb 12, 2009 | SPARKLE Computer Sparkle GeForce 8500 GT /...
Updated driver problem.
Well you should probably roll back that driver to the previous version. Doesn't sound like it gave you the correct new driver for the card or it wouldn't be messing up like that.
Jan 04, 2009 | SPARKLE Computer Sparkle GeForce 8500GT,...
Intel Celeron D 325 2.53GHz 533MHz 256KB Socket 478 CPU (Bulk) Logo
332 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
