Question about Nikon D70s Digital Camera
ERR sign it sounds as if my shutter is sticking. it also gives me an err reading in the view box. PLEASE HELP
  • krysti_allen Mar 04, 2009
    thank you for responding. My flash is poping up fine and i have tried different lenses. i have taken the battery out and turned the camera on and off several times. any other suggestions?
  • 477 Answers
This sound like your auto flash is not popping up allot of the time this will give you a err message and cause a slow reauction to taking pictures causing them eather to be blurry or very dark some times. is your flash working? if it is then it could be you lens try a diffrent lens if you do not have another lens then go to a camera shop allot of times they will let you try out lenses to try to get you to buy one.
Posted on Mar 04, 2009
How do I deal with an Err. 20 on my Canon T3i?
Err 20 Malfunctions related to the mechanical mechanism have been detected. Warranty repair.
Jan 21, 2015 | Canon EOS Rebel T3i
Canon EOS Digital Rebel XTI 400D Displays Err 99. Problem with CF card. Replaced with brand new card-still same err 99 camera is totally charges, acts dead, keep flashing Err CF, I try to format, it...
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
camera should be serviced.
Aug 31, 2008 | Canon EOS-20D Body only Digital Camera
Got the shutter and mirror clicks and err msg
bring it to your nearest nikon shop for a check up. i suggest a mirror lock up / shutter error.
Jul 26, 2009 | Nikon D90 Digital Camera with 18-105mm...
ERR 99
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Apr 11, 2009 | Canon Rebel XT / EOS 350D Digital Camera
I replaced battery on honda vp 2004 and sound/clock system not working on screen i read 7 err or 5 err
honda is now puttin the code on the glove box / kopen the door and then look at the inside edge it will give you a code put it in
Jan 27, 2009 | 1999 Honda CR-V
NIKON D2H ERR FAULT
I had a D2H with a similar error. The camera started giving an 'ERR' message almost from new but from reading various posts from other users I assumed it was a 'known' idiosyncrasy of the D2H, the camera would create an underexposed first shot after turning on. A colleague has the same problem on his D2H, and there are numerous references to the same problem on the web. Your post points to a similar shutter issue. My shutter failed completely at around 65,000 actuations, well short of the advertised '150,000'. In addition, the horizontal Main Command Dial had also failed a short time before, and it had cost me £135GBP to have that repaired.
The problem is down to the shutter and unfortunately replacing the shutter costs £349GBP in the UK, quoted to me by the Nikon UK Service Department, in Kingston, in March 09.
As for Nikon repairing it under a 'goodwill' policy, you may have better luck than me if you live somewhere other than the UK. I told them to keep mine, as attempting to charge me for the repair was the last straw, it wasn’t worth me spending another £350 on a camera that hadn’t been reliable in the first place. I had been planning on getting a D3 in October/November but will now probably sell my Nikon gear and go over to Canon, as Nikon don’t seem too bothered about their professional user base, and I certainly won’t be paying £5,000 for a D3X.
Sep 25, 2008 | Nikon D2H Set Digital Camera
Nikon D70 Flashing
ERR is i think an error message generated when the camera can not read the cf card ? have you had an problems with corrupted images ?
Sep 24, 2008 | Nikon D70 Body Only Digital Camera
Nikon D70 Err
Sounds like the shutter is sticking. This could be due to damage or just need cleaning. This probably means that you need to get the camera professionally serviced/fixed as shutters are extremely delicate.
Nov 09, 2007 | Nikon D70s Digital Camera with 18-200mm...
Fuji s2pro (2 units)
Your shutter mechanism reached its life expectancy, (5000 shots).
Aug 23, 2007 | Fuji FinePix S2 Pro Digital Camera
Nikon D70s Digital Camera Logo
91 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
