Question about Asko T700 Electric Commercial Dryer
I need the wiring diagram for an Asko T700 dryer. While replacing the belt I have some question on the connections to the relays on the rear panel. I am not sure if I put them back correctly.
    New Friend:
  • 18 Answers
I'll add the diagram that was inside my Asko T700 to the documents section.
Posted on Aug 16, 2009
  • ian vincent quidlat
    ian vincent quidlat Dec 18, 2013
    hi.. can I ask for a copy of the diagram too?
  • Karanngoroo
    Karanngoroo Jan 07, 2014
    can I get a picture of the wiring also please. Thanks!
How to replace belt on asko t701 drier
CHANGING THE DRIVE BELT
1. Remove the top cover and the rear panel (see page 26).
2. T720/780: Remove the external fan housing (see page 32).
3. Remove the special tool.
4. Remove the belt from the belt pulley and take off the belt.
5. Feed the belt over the drum onto the motor shaft and over the belt pulley.
6. Install the special tool.
7. T720/780: Replace the external fan housing.
8. Replace the rear panel and top cover.
_____________________________________________________
REMOVING THE TOP COVER
1. Remove the three T20 screws at the rear of the top cover. (Keep the two star washers.)
2. Tilt the cover and pull it backwards.
REMOVING THE REAR PANEL
1. Remove the top cover.
2. Unscrew the centering nut until the face of the nut is level with the end of the thread and knock out the bearing.
3. Fit the special tool (part no. 88 011 54) by fitting the tube end into one of the stamped out keyholes in the front rail. Lift the rear edge of the drum and press the drum edge onto the roller.
4. Remove the ground connection (yellow/green wire) from the input terminal block (see pages 8 and 9).
5. Take the cable bundle out of the cable clamp and pull the header block off its terminal pins.
6. Remove the wiring:
T700/T720: R1 a, R1 b, R1 13, R1 14, R1 34 on the contactor.
T760/T780: Ra, Rb, R13, R14, R34 on the contactor and F3 and F4 on the radio interference filter.
7. T720/T780: Remove the hoses to the water tank housing.
8. Remove the centering nut and the eight screws._____________________________________________________
NOTE: Do not remove or loosen the screws around the heater housing or drum bearing.
9. T720/T780: Remove the three plastic screws at the lower part of the rear panel.
10. Lift off the rear panel.
Dado
Sep 22, 2014 | Asko T701 Electric Dryer
I need a wiring diagram for asko dryer
They usually put the wire diagrams inside the actual console area, they make it to where only services can find it. If it isn't inside the console then try going to asko website to see if they have a PDF file you could download
Jan 31, 2014 | Asko T700 Electric Commercial Dryer
How to Replace the belt for a Asko T700 Dryer?
I have a T760, and the way I do it is to take the top off (3 screws in the back and slide it out from under the front lip), take some pics of the wiring so I'll know where they go (they're marked, but pics still help), and take the back off (perimeter screws). The drum bearing is mounted in the back, so I have to tap the drum shaft thru the bearing (take the washer off and put the nut back on so it is flush with the end of the threads). Asko has a special tool to hold the drum in place while the back is off, but I made one out of a coat hanger (a hook on one end to hang on the lip of the drum, bend a couple of right angles to fit thru the holes in the front panel, make it before the back comes off). The real hassle is holding the drum in place while reinstalling the back and the tool does this nicely. The belt has a spring loaded tensioner, make sure the wheel and bearing are ok, put it back together, and you're back in business...
May 10, 2012 | Asko T700 Electric Commercial Dryer
I have an ASKO T700 dryer. When I turn it on, it makes a high pitched squeak. If it's on for longer than a minute, I can smell a burning smell. Any suggestions?
you got a roller or belt idler not turning and burning the drum belt. you have to take the dryer apart and find the problem. if you need to lubricate a roller or idler use mineral oil or roller oil, do not use wd-40 or 3 in one.
Feb 12, 2011 | Asko T700 Electric Commercial Dryer
Does the belt go in the center of the drum or in one of the grooves of the dryer 700t
Hi the belt sits in the middle of the drum ,you need to remove the rear paneland rear fan assy first
Jun 09, 2010 | Asko T700 Electric Commercial Dryer
How do I replace the belt on my Asko T761 dryer? Do I go in thru the front, the back? Are there instructions on-line for belt replacement?
How to install a belt on ASKO dryer
Belt Type: Flat belt with ribs
Installation Notes: Ribs go against drum
You could Refer to :-
http://fixitnow.com/wp/2006/05/08/asko-t700-dryer-wheel-drum-and-belt-replacement-instructions/
It would be a Generic one but would help you.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 11, 2010 | Asko T761 Electric Dryer
Noisy dryer with long dry time
check to see if the fans are loose if so replace them this will also cause poor drying time.iI find its better to dismanttle these dryers and check the rollers,belt and jockey pulley at the same time.they look hard to work on but they are easy just take you time theres generally no wires to undo.
Mar 21, 2008 | Asko T700 Electric Commercial Dryer
Asko T700 loose belt, access from front?
I think you must replace the belt and the tensionarm. It MUST be done from the backside of the machine... Remove the backpanel, and the drum, change the tensionarm, and put the drum into the machine again. Put on the new belt, and mount it together again. Be careful for sharp edges! Hope this helps :-)
Jan 12, 2008 | Asko T700 Electric Commercial Dryer
Replacement part for Asko Dryer T700
Call Asko and order it there. Cant imagine that it is a expencive part. I only have the Norwegian partnumber.
Dec 24, 2007 | Asko T700 Electric Commercial Dryer
Asko T700 Electric Commercial Dryer Logo
816 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
