Question about HP Compaq Presario V2000 Notebook
Red and green patches on my lcd laptop screen
Hi.. For a couple of days my laptop lcd screen is all patchy.. have green patches on the top n red pixels r shining all throughout my monitor..
any solution to the problem, is it cause my laptop gets heated too much, or screen is gone bad???
thanks in advance..
  • Shoaib Rais
    Shoaib Rais May 11, 2010
    kindly check thru taking vga out to ext monitor if th patches are there as well then ur vga is having trouble may be adapter
    if the ext display is ok then ur lcd screen has gone bad
    is there any breakage visible on the screen like mirror or glass breaks or what how would u define patches
Have you ever seen the 10 inch lun, so dear use it
Posted on Mar 25, 2009
Laptop LCD/Display Problem, Green and Pink Tints???
Their are a couple things that could be causing this, My first thought is that the screen its self is damage. A LCD screen is composed of millions of tiny pixels so when some fails others will still work.
That other thought is that the GPU or video device on the laptop could be failing and creating video problems. Have you tried closing the laptop and opening it agian, this would help rule out a bad cable connection.
Dec 24, 2013 | Computers & Internet
I just bought this Compaq laptop and it has really bad blurry spots and has 3 red lines going through the screen
This indicates the LCD panel is dead if the red lines are going from top to bottom then its the lcd screen thats faulty it there is green/red line going from side to side then that means the motherboard is faulty, if you have just bought it from hp they will replace it if you bought it from a dealer or a second hand shop you will need to go back to the shop for a refund
Jun 29, 2011 | Computers & Internet
Hello Everyone i have a problem with my acer aspire 5920, first of all it had a bit of an impact to the lid. When power button was pressed it would power up and straight back off again, i discovered when...
I have never had this problem, but what I am thinking it could be is all of the primary colors that are used have gone out besides the red color. It might not be in the graphics card but something in the screen that has gone wrong, you might need to go into the computer and reset some like the color balance. That is a very weird problem, sorry for your trouble, I hope I helped in some way.
May 25, 2011 | Acer Aspire 5920-6574 Notebook
Green and red horizontal line goes from bottom to top of screen and at times red tint and the screen becomes green
Hi
it seems the problem is in the convergence section the two STK IC there is defected already,you replace it with a new one.
Feb 08, 2011 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
My sony lcdtv kdf-55wf655 has a blue line across the bottom of the screen and a patch of blue in the lower right hand corner
Your screen has probably been bumped by something.
The line may be possible to be fixed by an engineer reseating the cables internally, but the patchy area is a pressure fault and cannot be fixed without replacing the complete screen.
You can get these patches on things like laptop screens too, where somebody has pressed a finger on them a bit to hard.
Apr 03, 2010 | Sony KDF-E42A10 42 in. LCD Television
Red vertical line down right side of the screen
hi
I think your TV have a trouble inside lcd panel
the controller board contains driver IC. Deffective driver IC can cause of line display.
Three reasons why one vertical line accross screen can happen in LCD;
1.The missing signal from the controller IC to
LCD driver.
2. LCD driver IC itself defective
3. Dry contact in the tape carrier package.
Use masking or electrical tape to mark it where the line was located. press it if the line back to normal but when release your hand came back i think it was intermittent. Open the LCD panel
Use robber
Place the rubber on the top of TCP
Gently close back the top casing
Good luck...
Aug 21, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
My Sony Bravia's screen is showing images in red and black only. By playing with the input sockets at the back (pulling out the leads and reinserting) it was temporarily fixed the problem but, now it seems...
If you are using Component Input (green/blue/red inputs) with component patch cords, try using other input jacks ( Video In (yellow) or Cable/RF In). If the color is good, then replace your Component patch cord, the green one is broken.
Aug 15, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Dropped laptop lcd screen messed up
Yes it can be repaired. Take it to a reputable repair person.
Apr 10, 2009 | Dell Inspiron E1705 Notebook
Green cruve line
Good Day;
Suspect Convergence IC's STK4274, part Number 2003191. Replace all three IK04(red), IK05(green), IK06(blue).
Good Luck, big IRISH.
Aug 30, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Problem in Screen display
Hi, J ! You didn't say how old you set is, but to me it sounds like you may have a warped shadow mask in you picture tube. A shadow mask could be compared to a piece of screen wire. It's function is to make the electron "beams" from the three electron guns strike the proper phosphor dot to produce the proper color- red-green-or blue. If this is the case the picture tube would requie replacement. Stargazer
Jan 09, 2007 | Sony KV-21CT1 21" TV
HP Compaq Presario V2000 Notebook Logo
517 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
