Question about DeLonghi CTH2003 2-Slice Toaster
When I push the lever down on my CTH2003 2 slice toaster it won't stay down, therefor I it does not toast.
5 Suggested Answers
  • 944 Answers
SOURCE: Toaster Loading handle wont staY down
I have researched this toaster quite extensively, without any success as to actual solutions. Usually these machines have either a solenoid activated lever that holds the toast down, although magnetic systems are not uncommon. These may be avtivated by a thermostat, an optical "brownness" meter or a timer. Usually the cost of replacing this would be as much as a new toaster due to labour costs, however it may possibly be fixable - could you add a photo of the internal workings - this might help. Unfortunately many other purchasers appear to have similar problems and claim to have had little success with either dealer or manufacturer. The number of toasters of this model offered for sale second-hand as new at ridiculously low prices makes me suspect that there is a fundamental problem with the model. Use any warranty you have, but unless you wish to write a lot of letters/mails then i suspect a new toaster might be your best bet. Availability of spares for this toaster is another issue - I have been unable to find anyone who claims to supply these, although individual components are almost certainly from different manufacturers and could be sourced. If you can arrange a photo of the toaster when open (reasonably close up and general view) then I may be able to help more. Apologies for no actual "Solution" yet.
Posted on Feb 17, 2007
SOURCE: Right side of the toaster will not heat up
At this point the problem is nit solved.
will look into a solution before investing any funds on the solution. There are many free options to be considered at this point.
Posted on Mar 24, 2009
  • 1606 Answers
SOURCE: 4 slice toaster when pressed
Try cleaning the bread crumbs out of it. If you get enough piled up under the latch mechanism, you can't push it down far enough to engage it.
You may be able to do an adequate job by opening the bottom cover - most toasters are made so it's easily removed for this very purpose. If not, you'll need to pull off the knobs and remove screws so you can take off the top cover. Be careful not to touch the heater wires with any tools - after they've been used a while they become rather brittle and break easily, and even a scratch can cause them to erode and fail. I assume you know to unplug the toaster before working on it.
Posted on Jan 06, 2011
SOURCE: toast wont stay down in toaster it wont lock in
I'm at the same crossroad. Thry holding down the lever for more than 4-secs. The light will blink once, then it is as though the circuit is over-ridden and a toasting cycle will begin. This might help to eliminate wether you have a mechanical or electrical issue. Mine appears to be electrical. I'm now investigating if it is the timing or relay?
Posted on Sep 24, 2011
Hi my girlfriend just gave me this toaster, and would like to know what the lighted buttons are for thanks
Since you don't mention the make or model number of the toaster or its age I can only make the following guesses.
It might be an electronic model. To test if this is the case, leave the toaster unplugged and push the lever of the toaster down. If it does not stay down it is an electronic toaster. If it stays down then it is NOT electronic.
The lights might be lighted push buttons.
If you plug the toaster in then put a slice of bread or two in and push the lever handle down and one light comes on then this is probably a dual purpose pushbutton. It indicates that the heating elements are on and if you push it will cancel the toasting cycle and the bread slices should pop up.
If there is a button beside the above button it could be for extending the toaster cycle time a bit longer to compensate for a thicker slice or a denser bread like a bagel. If you push it, it will light up to let you know that the cycle has been extended for this reason.
If there is a button beside this one, it could be for extending the toasting cycle to compensate for a frozen slice of bread or whatever, like a bagel or even a frozen waffle.
If you find the make and model for your toaster, it might be on the bottom somewhere, google it to see if you can download an instruction manual for it.
Hope this helps. Good Luck.
Jun 03, 2017 | The Kitchen Appliances - Others
When you press the lever to push the bread down in the toaster, it will not stay down
How to Fix a Broken Toaster - For Dummies
Toasters are uncomplicated appliances with heating elements, a thermostat, switches, and plugs and cords. ... If you get a shock when you touch the toaster, it's not grounded. ... What to do when your toast won't stay down ... Take off the carriagelever and front cover and look for a knob, screw, or nut located near the toast ...
How I fixed my toaster - YouTube
? 6:15
Feb 5, 2010 - Uploaded by paisteboy
Hey I know its been like 5 years since you posted this but how didyou get off the black knobs? I have a similar ... Thanks much - I shall try this on my mother-in-law's Oster toaster! ... But now that side won't stay down, so what to do? .... About · Press · Copyright · Creators · Advertise · Developers · +YouTube.
Jan 16, 2016 | KitchenAid Kitchen Aid KMT222OB - 2-Slice...
The lever won't stay depressed
mcdevito75 here, The lever mechanism could be worn OR the setting for darker / Lighter toast is set to Light, swtch to darker see if that helps.
Jun 22, 2010 | Breville CT40 Retro Classic 4-Slice...
Krups toast supreme 4-slice toaster stopped working
The element has burnt out, IF you can get another it is worth repairing, IF NOT, then it is time for a new one.
Apr 13, 2010 | Krups FEA212-45 Toast Supreme IV 4-Slice...
I just bought this kenmore 2 slice toaster and the toast lever won't stay down!?
Make sure it is set dark enough. Some toasters will not stay down if they are set too light.
Feb 11, 2010 | Kenmore 135101 2-Slice Toaster
Sunbeam 3831 Toaster (2-slice) -- toast/carriage won't stay down
great ! its a great fealing when you save a appliance from the junkyard .
Mar 30, 2009 | Sunbeam 3831 2-Slice Toaster
When i push the lever down to make toast, it does not stay
This is a problem, our old toaster had this problem, and it would only work if we jammed the handle down, but don't try this, only because ours broke after we tried this, but if you can send it to the manufacturure, they should be able to fix this. If you don't what to do this, please phone me at 505 9181, but please call me from 8:00-10:00, 2:30-8:00.
Oct 21, 2007 | Cuisinart CPT-60 Custom Control Total...
Toaster lever wont stay down
Open the toaster up and look inside by the levers, there should be a little piece that will keep the lever down, if this is missing, then you may need to replace the toaster, if not, then the little piece may be stuck, you can use the following to try and loosen it up,
1. WD-40
Oct 11, 2007 | Waring WCT708 4-Slice Toaster
4 slice toaster
open the unit. look for disconnected wires from sloppy factory
May 20, 2007 | Cuisinart CPT-140 Cool Touch 4-Slice...
DeLonghi CTH2003 2-Slice Toaster Logo
62 people viewed this question
Top DeLonghi Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Oloyede Monsuru
Are you a DeLonghi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
