Question about Goodman Heating & Cooling
GSH130481CA condensor and ARUF48601ba fan coil. Server noise at intermittent times,in heat mode, usully in the middle of the night. Sounds as if from fan coil. Fan coil 50 ft from condensor. Fan operating normally with noise.
  • robert_sm866 Mar 05, 2009
    problem solved. Not related to heat pump. Thanks to all.
  • 4 Answers
It may be your noticing the defrost cycle which can be noisy at times exspecially at nite when the unit will reverses it cycle temporarily
Posted on Mar 05, 2009
BUZZING NOISE FROM MY HEAT PUMP
Take a look at this YouTube page that explains with good videos what are some of the common problems with heat pump noise. The one that seems dominant is the defrost cycle a heat pump goes thru when it melts ice off the evaporative coils. In defrost cycle, The compressor runs but the cooling fan does not, so you will hear a loud buzzing sound and the unit sounds like it is stalled...because only the compressor is running to generate heat to melt coil ice.
https://www.youtube.com/results?search_query=American+Standard+5000+Heat+Pump+makes+a+buzzing+noise
Defrost cycle noise video:
https://www.youtube.com/watch?v=wudLk0WoIVo
Mar 06, 2015 | American Standard 5000 Heat Pump Unit
Tip
Freezer not working, things to check
The unit needs two fans running and good airflow, one fan outside cools the condensor coil and the other inside the unit blowing across the evaporator coil, warming it. The compressor must start up. The defrost timer stops everything and switches on a heating element to defrost the evaporator for several minutes. Please verify these conditions. The condensor coil may get clogged with dirt and lint, the evaporator may get clogged with ice build up, or the fan may quit working due to bad bearings, need for lubrication, or burn out. The defrost timer has an internal motor and contacts which may quit working, some have a way to manualy turn it to switch its mode in case it quits working.
on Feb 11, 2015 | Freezers
Should the condensor fan come on in heat mode?
It depends on the type of heat. If your air conditioner is a heat pump where it runs in reverse (takes heat from the outside air and pumps it into the house), the condenser fan will run. If heat is auxiliary electric coils, only the inside fan should run.
Nov 01, 2014 | Heating & Cooling
My refrigerator has been fine for years. I recently vacuumed out a lot of dirt and now it sounds like the compressor is knocking when it shuts off and this is preceded by a what sounds like a high pre
Cleaning the condensor lowers the head pressure to normal range.
The compressor may rattle internaly when started or stopped or shook. The compressor position may have been disturbed so that it makes noise every time, or the suspension springs inside is fatigued.
The fan may have some debris that may also cause noise at start up or when stopping. I would visual inspect the fan, condensor, and compressor and if it all looks ok, then just let the refrigerator do it's work. Fan blades can bend easily and when bent they go out of balance and vibrate when started, stopped, or continuously.
You did the right thing by cleaning the coil under the refrigerator, just make sure any movement needed by the parts have enough clearance and are in place where they supposed to be.
I believe a 10 yrs life from a machine is average.
Apr 02, 2014 | Whirlpool Refrigerators
Middle bar hot
this is generally an indicator that either the door was left open too long, dirty condensor coils and/or you have a issue with the condenser fan mtr not running or blade is jammed. pull the unit out and see if the fan in the back is running if not or if it is running slowly then it needs to be replaced ASAP!!!! This fan is design for two purposes to cool the compressor from over heating and to draft cooler air across the condensor coils and displace heat outside unit
Apr 16, 2012 | Maytag MSD2656G Side by Side Refrigerator
I have a GE GSS25IFR side-by-side refrigerator that is making a squealing noise. This sound began a month ago where it happened once in the middle of the night and I couldn't identify it. My wife...
Yes replace the Condensor Fan Motor.
The fan cycles on an off whenever the compressor runs. You will want to replace it right away or your compressor can burn up from the heat. The radiator thing you cleaned is the condensor this is what takes away the heat.The part # is AP4298602 enter your model # or the part # at www.appliancehelponline.com the part is in stock and on sale.
May 12, 2010 | GE GSS25IFR Side by Side Refrigerator
Very loud noise and the middle bit between the fridge and freezer isvery hot to touch with my powepiont model no TRF295 what shall i do?
loud noise comes from moving parts such condensor fan motor, evaparator fan motor. be sure they are nt hitting shroud. other is compressor-may be going bad. heat in middle is coming from mullion heater,as long as it doesnt melt gasket or short out, trip breaker should be ok.
Aug 26, 2009 | Refrigerators
Our 10 year fridg seems to get very hot on the side...wondering what would cause this Model et18pkxaw00
The condensor coils run along the inner sides of the fridge . The heat you feel , is the heat being pulled out of the freezer which is the purpose of "freon" (to attract heat) . A freezer doesn't get cold , "freon" pulls the heat out , which is then cooled by the condensor fan ( fan which cools the compressor and coils ) . The more heat you feel , the colder the fridge should get ( to an extent ) . Also make sure the compressor fan is working .
Aug 19, 2009 | Whirlpool Refrigerators
Maytag freezer don't freeze food or make ice
There could be several things causing the frig to be cold but not cold enough. First check thermostat control and air control. Both should be set in the middle setting for normal operation.Next check to see if evaporater fan is running in freezer. It should be running whenever compressor runs and circulates cold air inside frig as well as freezer. Next check if condensor fan motor is running. It blows air over condensor coils to remove heat. Last ,check condensor itself for dirty coils. If they are matted up with hair dust,etc. it will cause poor cooling. you can give thorough cleaning with vacuum cleaner. Hope this helps
Jul 28, 2009 | Maytag MSD2756G Side by Side Refrigerator
Vibration when heat only is on inside and out
Is it noisy always when running in heat or only for intermittant periods? Depending on where you live every 45-90 minutes of run time the heat pump goes into a cycle called defrost. The fan on the outdoor unit will shut off. the compressor will continue to run but in actually cool mode. this heats the outdoor coil and allows any frost or ice that is built up on the outdoor coil to melt. The compressor can get pretty loud in this mode and you may actually see steam coming off of the unit. This is normal. However if it is noisy all of time in heat check/clean your coils. If this doesn't remedy it have your refrigerant charge checked by a NATE certified Service Technician. Good luck.
Nov 22, 2008 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
291 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
