I need the remote control codes for a Sylvania LC225Sl9 TV. I want these codes to use in a Motorola DRC800 4-in-1 Universal Remote Control.
  • 1 more comment
  • lrfarris Mar 04, 2009
    I have the manual and have tried all of the codes provided. The do NOT work! The TV is fairly new. It is NOT a projection TV. IT is a 22" Digital LCD TV. I simply need the codes to make this TV work with my Universal Remote.
    The codes you provided, 0054, 0171, 0030 were the ones provided with the Universal Remote. I also tried codes 0020 and 0096 wich I obtained from the Internet. None of them work. Help!!
    So far, the solutions offered were already tried by me prior to contacting you. At this point, I am receiving nothing new.
  • 13,433 Answers
Have you tried the codes in the manual or are those the codes that your looking for?
Posted on Mar 04, 2009
  • Ekse Mar 04, 2009
    Sylvania 0054, 0030, 0171, 0020, 0096
    This manual includes instructions on how to enter the code into the remote controller.
    http://www.eastlink.ca/cable/support/doc...
    Let me know if you need anything else.
    Thanks,
    Ekse
  • Ekse Mar 04, 2009
    In that case please use the search code function "SEARCHING FOR CODES" Part in the manual In the previous comment.
  • 916 Answers
Here you go this should be the manual you are looking for Click Here
1- Manually turn ON your device
2- Press and "HOLD" CODE SEARCH
3- Press and release the TV button
4- Release CODE SEARCH.
5- Press OFF/ON repeatedly until the device turns off
6- Once the device turns off, press and release ENTER.
7- With the device on, press any other button to see if the tv responds
  • 583 Answers
Http://www.remotecodelist.com/remotes/rca/rca_systemlink3_prog.html
(for tv remote controls)
 http://www.xdiv.com/remotes/
for remote controls
http://www.universal-remote.net/?gclid=CN6V9PXTg5UCFQntegodwDfd3A
click this links 1 by 1 and check out.
  • 744 Answers
Programming Your RCA Universal Remote.
The RCA universal remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes: TV-000, VCR-000, Cable Box-000, and AUX is programmed with VCR code 037. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search: 1- Manually turn ON your device (TV, VCR, Cable Box) 2- Press and "HOLD" CODE SEARCH 3- Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once. 4- Release CODE SEARCH. 5- Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second). 6- Once the device turns off, press and release ENTER. 7- With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists: 1- Find codes for each device and brand below. 2- Press and "HOLD" CODE SEARCH. 3- Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step. 4- Enter the three digit code from the TV, VCR or Cable Box code lists. 5- Release CODE SEARCH. 6- With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists. TV Codes Admiral 005 MTC 011,019,027 Amtron 064 Multivision 081 Akai 002 NAD 018,023 Anam National 038 NEC 011,014,019,027,038 AOC 011,019,027,088 MTC 0017,0023 Bell & Howell 005 NEC 0017,0023 Candle 011,027,033 Panasonic 012,013,038,086 Citizen 011,027,033,064 Penny 000,008,011,019,027,068,086 Colortyme 011,027,084 Philco 006,007,010,011,013,016,019,027 Concerto 011,027 033,035,037,038,043,087,089 Contec/Cony 036,037,040,042,064 Philips 006,007,010,011,013,016,033,035 Craig 064 037,038,043,066,073 Curtis Mathes 000,011,015,027 Pioneer 011,027,045,062,093 CXC 064 Portland 011,019,027 Daewoo 011,019,027 ProScan 000 Daytron 011,027 Proton 011,027,037,072 Dimensia 000 Quasar 012,038,092 Electrohome 006,011,014,027,038 Radio Shack 000,021,025,036,037,059,064 061,068 RCA 000,006,011,019,027,034,038,044 Emerson 011,026,027,028,029,030 046,088 031,032,037,042,053,064 Realistic 021 065,067,075,076,079 Sampo 011,027 Envision 011,027 Samsung 006,011,014,015,019,027,036,037 Fisher 017,021,039,041 077 Funai 064 Sanyo 017,021,039,056,057,058 GE 000,008,009,011,012,027 Scott 028,037,064 038,068,086,089,091 Sears 000,006,011,014,017,018,021,023 Goldstar 003,004,006,011,019 027,039,040,041,051,071,083 027,037,050 Sharp 011,020,025,027,037,052,053,059 Hallmark 011,027 060 Hitachi 009,011,027,036,037 Signature 005,094 040,047,048,063,080 Sony 002 Infinity 013 Soundesign 011,027,033 JBL 013 Sylvania 006,007,010,011,013,016,027,033 Jensen 011,027 035,043,049,066,087,089 JVC 012,024,036,037,040,048,051,074 Symphonic 064,076 Kawasho 002,011,027 Tatung 038 Kenwood 006,011,014,027 Technics 012 Kloss Novabeam 035,043 Techwood 011,027 KTV 078 Teknika 011,019,027,033,037,040,066 Loewe 013 Telecaption 090 Luxman 011,027 TMK 011,027 LXI 000,013,018,021,023,054 Toshiba 018,021,023,071,085,090 Magnavox 006,007,010,011,013,016 Universal 008,009 027,033,035,043,066,087,089 Victor 051 Marants 013 Vidtech 019,027 Marantz 011,013,027,069 Wards 000,005,006,007,008,009,010,011 Memorex 005 013,019,025,027,028,035,043,059 MGA 006,011,014,019,022 066,076,082,089 027,041,056,061,068 Yamaha 006,014,019,027 Mitsubishi 006,011,014,019,022,027,041,055 Zenith 001 056,061,068
    Novelist:
  • 166 Answers
Ok.. buy it from
http://www.google.com/products?client=opera&rls=en&q=purchase+Motorola+DRC800+4-in-1+Universal+Remote&sourceid=opera&oe=utf-8&um=1&ie=UTF-8&ei=cKauSei7C8-_kAX1kKizBg&sa=X&oi=product_result_group&resnum=4&ct=title
    Novelist:
  • 148 Answers
Http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Register to view and/or download this manual. I hope this helps.
  • 19,396 Answers
Try the following codes: 0054, 0171, 0030.
  • Ginko
    Ginko Mar 04, 2009
    If the codes provided with the remote do not work, then you need to use the auto search feature to automatically find the codes.
    See the user guide below:
    DRC800 User Guide
    Brigadier General:
  • 3,614 Answers
Go HERE
    Sergeant:
  • 239 Answers
Http://www.charter.com/Visitors/GETBINARY.xbin?ID=1519
this should take care of it
hope this helped
please rate well
    Genius:
  • 1,550 Answers
You can get code from the manual you got with the product .
If you dont have manual contact manufacturer to get the code.
Need to program my phillips universal remote CL035A to my Sylvania TV
Look in the manual of your
Phillips universal remote CL035A for ther listing of TV codes, take notes of codes for Sylvania and input codes accordig to instructions of your manual.
If you can locate Sylamia, follow instrucions for unspecified device.
You don't have a manual?
How to Program Philips Remote Control Without the Codes eHow
Jun 19, 2015 | Sylvania Televison & Video
What is the code for sylvania tv for my remote
The codes are in the remote. Use the code search (or similar) feature of your universal remote to find a code that will control some or all of the functions of your Sylvania TV.
Jun 03, 2014 | Big Button TV Universal Remote
Control universal
Hello
Just buy one universal remote control, which have setup codes for Syllvania TV. You can get this information from the code list of the remote control. Most RCA universal remote will have setup codes for Sylvania tV.
Apr 03, 2012 | Sylvania 6413TC 13" TV
Need to program sylvania remot n9294 to operate rca tv.
how to program a sylvania n9294 remote control to a sylvania lcd color tv model lc225sl9
Jan 18, 2010 | Sylvania 2940LV VCR
Rcr312w universal remote control, I need codes for sylvania tv/vh
Sorry it took so long to respond to you request for help.[ Sylvania TV Code-1251, VCR Code-2154 ] These are the listed code for your model remote control and the Sylvania television and vcr combination unit. I hope this information solves you problem of needing codes to use your remote control with you television and vcr combination unit. Thank you for using FixYa and have a nice day.
Feb 22, 2009 | RCA 3-Device Universal Remote with...
Sylvania LC225SL9 LCD TV have RCN cable would like code 4 remote
Unfortunately, there are no compatible universal remotes with this television.
Feb 21, 2009 | Televison & Video
Codes
I need the codes for a phillips remote, i have a Sylvania
May 08, 2008 | Universal Remote Control NspireGear MP3...
I need codes for philips universal remote control
lost manual tring to hook up dvd/vcr emerson up need code
Apr 24, 2008 | Philips Universal PH301S Remote Control
Televison & Video Logo
711 people viewed this question
Top Televison & Video Experts
