Our RCA Portable DVD Player is stuck at LOADING it does not play
When a DVD is inserted it just spins and spins. The screen says LOADING but never plays. Water did not fall on it and we have misplaced the remote control
  • mylenerem Mar 04, 2009
    The model number is DRC6331
  • mylenerem Mar 05, 2009
    Our RCA Portable DVD Player with 10" LCD screen model number DRC6331 is stuck on LOADING. When a DVD is inserted it just spins and spins. The screen says LOADING but never plays. Water did not fall on it and we have misplaced the remote control.
    Sergeant:
  • 239 Answers
Sounds like the laser eye is malfunctioning. might be best to replace the dvd player however if you are attached to the device than you can look and see if there is an electronics repair place that you can take it to to fix it.
hope this helped
please rate well
Posted on Mar 05, 2009
    Scholar:
  • 93 Answers
It's worth remembering that Laser units do fail.
The process is:
Disc Inserted, Check for reflection
Find reflection, spin up disc, try and focus.
Focus OK > Read Data > Play Disc
Focus Bad / No Data > Keep trying / Crash / Eject.
If your laser unit is clean, and it is still having this problem, then your laser unit has failed. On most DVD Players, unless it is a top of the range unit, it is cheaper to buy a new one than to replace the laser.
    Genius:
  • 1,550 Answers
Try pressing repeatedly the eject button while you turn on the unit. and take your dvd out and insert once again and check it plays .
If it does not play it means the lens is dirty you need to clean the lens .
You can get the lens cleaner from the link below
Lens cleaner
Hope this helps .
Posted on Mar 04, 2009
    Brigadier General:
  • 3,614 Answers
Better do cleaning the the optical lens. you may need a cd lens cleaner for this.
    Novelist:
  • 166 Answers
Wat was the model number of your DVD player?
  • 19,396 Answers
That means that the lens is not reading the media, start cleaning the lens with a cleaner disk.
  • Ginko
    Ginko Mar 04, 2009
    When player says no disk, even if the disk inside, and you hear a
    whirring and clicking noise when you insert a disk, that means that the
    lens is dirty or defective, and the drive cannot read the initial
    DVD track, and returns no disk.
    Try first using a DVD cleaner
    disk, if that does not work, then you will need to take the apart the
    unit to clean lens with isopropyil alcohol and cotton sticks.
    Here a choice of DVD lens cleaner products.
    See also the following websites on how to clean the lens, use a cleaner disk first, some of the units are CD, but procedure is the same for DVD and Blue Ray:
    Gizmo Highway DIY - Clean your CD player lens
    Lens Cleaning CDR CD-RW (how?)
    DVD Not Working
Is there an easy fix when the dvd keeps spinning and screen says loading but does not play?
You have to clean the dirt off the laser lens inside as it cant see the codes on the disc.Use a cleaning disc first or it will have to come apart to clean.
Dec 06, 2013 | RCA 9" Lcd Portable Widescreen Dvd Player...
Can't put DVD in to play
You cant insert a dvd disc? maybe the loading mechisum is faulty. if the dvd is inserted (hear it spinning) but no picture the reader could be faulty or the easy to fix option the out wires arn't in the correct order or colour.
Sep 22, 2010 | Power Acoustik PADVD-340 Car DVD Player
My DVD says "root" on the screen. What do I do to get it to play?
"Root" is part of the Menu screen, press Menu on the remote to clear it.
Jun 05, 2010 | Philips Magnavox DVD/VCR Dual Player
Continous loading & not playing
I had the same issue with mine. It is one of three problems.
  1. The DVD is dirty. Try cleaning it with window cleaner and a soft rag. Also try other media like CD's to see if the same thing happens. If it still won't play then it needs to be opened up.
  2. I don't suggest opening it up unless you are fairly good with tools. Although its not complicated, care needs to be taken to prevent electric shock. Once the unit 's lid has been removed plug it in carefully and insert a DVD. Watch closely for the DVD spinning. If your DVD does not spin try giving it a gentle spin in any direction. This will usually overcome any torque issues with the motor and allow the DVD to spin and play normally. If it won't spin at all despite gentle manual spinning then the motor for the DVD player has burned out and the unit will need to be replaced.
  3. If the DVD spins up and doesn't play that could mean a faulty laser system or a dirty laser lens. There are cleaning kits you can buy but I prefer the manual method. First UNPLUG the unit. Since you have the power off you can gently soak a cotton swap with 90% isopropyl alcohol or use denatured alcohol (methyl hydrate in Canada) Both are available at most hardware stores. Gently swab the small glass lens with the alcohol. Let it dry and try to watch the DVD again. If it still fails it will need to be replaced.
Jul 06, 2009 | Sony DVPNS55P Progressive Scan DVD Player
Portable dvd player
the laser may be broken,and can not read...
Apr 15, 2009 | Mintek MDP-1720 Portable DVD Player
Dvd player wont play
I found this on the PROSCAN website under customer support manuals.The website is www.oncorpus.com.I hope this information helps you with your problem. IMPORTANT THE LABEL SIDE OF THE DVD MUST FACE THE BACK SIDE OF THE TELEVISION 1. Press the ‘INPUT’ button to select ‘DVD’ mode, if no disc is inserted yet, the display shows ‘No Disc’.
2.Insert a DVD with the printed side facing towards the rear of the TV/DVD Player (see below)
3.The TV will first display ‘Loading’, then change to ‘DVD-video’. Most DVDs will show some preliminary
information then stop at a main menu screen.
4. Press PLAY/PAUSE to play it directly. Or press the DVD-MENU button to access the disc menu during
playback.
5.Use the direction button on the remote control to select the desired option. Press ENTER to select the
option or press the ► button. Playback will now commence.
6.After playback, press the EJECT button on remote control or EJECT button on TV/DVD to remove the
disc.
Note: No function‘’ will sometimes appear on the screen after a button is pressed. This indicates that the
function is not supported at the current time.
Feb 14, 2009 | Proscan 32LA30Q Television
Mintek 10.2 MDP-1060
where can I buy a power cord for the car adapter for this product?
Jan 21, 2008 | Mintek 10.2" PORTABLE DVD
DVD does not start playing
I am having the same issue. If you get this resolved please post the answer on this forum.
I called the 800 number and it is no longer in service.
Jan 15, 2008 | Durabrand PDV-705 Portable DVD Player
Spinning dvd
Most of the time a read error is a bad Laser.Spin-up problem's are sometimes the cause but I think the Laser. Most of these China made units are not cost effective to repair
Oct 26, 2007 | Cyberhome CH-LDV 707B Portable DVD Player
Keeps saying loading but never shows picture
take your set to tech the lens need to be adjust or the strip is getting in the way.
Feb 19, 2007 | Sungale PD708 Portable DVD Player with...
Televison & Video Logo
328 people viewed this question
Top Televison & Video Experts
Electro Med Services...
