Question about IBM ThinkPad T22 2647 Notebook
Swap two hard drives
I'd like to swap a HD from an IBM T20 and an IBM T22. Both are running Windows XP. There is no other software/programs that I need to keep.
Can I just unplug from one and insert in the other?
  • mrgdownunder Mar 04, 2009
    What are the jumper settings suggested in this solution?
  • mrgdownunder Mar 05, 2009
    I guess what I'm not sure about is where to find/change the jumper settings???
  • 3 Answers
Jumpers on disk drives are the little plastic squares fitted over metal pegs back near where the IDE connection is made on the drive. Sometimes, an abscence of a jumper implies a certain setting. To change the jumper settings, you physically move the jumper(s), so some needlenose pliers would be good to have. Many drive's jumper settings are located differently, but most explain themselves on the drive case somewhere, usually in a little chart. You can Google 'em up if need be, too, if you know the model. They tell the drive, simply put, how to interact with other similar drives and their connection(s). You may not need to change them, but just make that the drives being installed have similar jumper settings to those they are replacing: if the first drive was set to cable select, the drive taking its place should be set the same, in cable select. This holds true for master and/or slave settings, too.
Posted on Apr 29, 2009
    Scholar:
  • 150 Answers
Indeed you can. Make sure the jumper settings are identical for the swap, and as long as the replacement one has windows xp running on it you should be fine.
Posted on Mar 04, 2009
  • Kurtis Stalnaker
    Kurtis Stalnaker Mar 05, 2009
    You can use the same jumper settings as the other hard drive with this hard drive.
Need info about series
The type of drive is IDE and 2.5- Inch for all those models.
T20, T21, T22, T23 --- 2647 all use the same IDE type of drive.
These you can buy for example in ebay. Search for laptop hdd ide 2.5inch or similar.
Jul 01, 2012 | IBM ThinkPad T40 2373 Notebook
Can Windows XP Pro be installed on an IBM T20? I'm
yes you can. I checked e-bay and there are lots of them with windows xp.
Sep 09, 2009 | IBM ThinkPad T20 2647 Notebook
Need driver on my nootbook ibm t22 for display for win 2000 op. hew just 16 color min 16 bit nid 32 bit color thank you...
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP or Vista device drivers for your model computer,
Use this link :-
http://www.ibm.com/products/finder/us/finders?pg=ddfinder&cm_re=other-_-suprcn-_-download
May 08, 2009 | IBM ThinkPad T20 2647 Notebook
Problem with a IBM ThinkPad T20 2647 PC Notebook
check ur hd for bad sectors...shutting down for no reason is usually this(bad sectors)
also check system information and check device manager..could be software problem/incompatabilty/no drivers installed/or two devices trying to use same resource and shutting down cos cant.
Jan 07, 2009 | IBM ThinkPad T20 2647 Notebook
Hard Drive
When you boot from your OS CD it will run through Set Up and give you the option to format the harddrive.
Just select NTFS for windows 2000 or XP, or FAT32 for Windows 98/ME.
Aug 06, 2008 | IBM ThinkPad T22 2647 Notebook
ThinkPad T22 will not boot to windows
I've seen several T20 series with the same problem. A CRC error pertains to a chipset on the motherboard, and the only way I've found to fix a CRC error is to replace the motherboard.
Jul 07, 2008 | IBM ThinkPad T22 2647 Notebook
IBM Thinkpad T20 - Model Type 264784U
I would say the hard drive is failing. But need to run a diagnostic on it to be sure.
If you would like to know where to get the ibm / hitachi hard drive diagostic let me know. It's free for download and you can get a bootable ISO image to burn onto cd. Allowing you to boot from cd in order to test the drive.
As far as replacing, you should be good with a 60gb or 80gb. Did it orginally have a 20gb in it? I would say for most people, 60-80 is way more than enough. Unless you have a ton of music or pictures.
Oct 22, 2007 | IBM ThinkPad T20 2647 Notebook
IBM ThinkPad T22 2647 Notebook Logo
93 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
