Question about Brother IntelliFAX 4100 Laser Fax
The fax machine is making an unbearably loud screeching sound
And the faxes have faint horizontal lines through the pages.
    Problem Solver:
  • 11 Answers
That will be the drum unit arching you will probably need a new drum unit. you can try cleaning the drum some times that helps'
PS. remove the toner before you clean the drum unit use compress air and make sure you are outside the house it is messy.
any other question please let me know.
Posted on Mar 25, 2009
I can't receive fax messages. the phone rings and the response says call pick up.
Hi Viv, you still use the ole fax machine eh?? Does it make the screeching sound when you pick up the phone? Do you have a separate fax line? Check your settings. If nothing else works try using emails to do your stuff..
Oct 01, 2017 | The Office Equipment & Supplies
I get a white line through but it is not telling me to change toner?
This can occur if you receive a lot of faxes that may have a vertical block or a lot of text or pictures etc. in the same location on the page. The toner can be used in that particular area of the page and a white line results.
Remove the toner cartridge from the fax, keep it horizontal. Shake it side to side whilst keeping the cartridge horizontal. This redistributes the toner inside the cartridge. Replace the toner cartridge in the fax.
Hope this helps.
Feb 09, 2010 | Brother IntelliFax-2820 Laser Fax
When faxing out-2 large black horizontal lines appear on page
Bad scanner block, sorry. Very expensive if you can find one.
Mar 11, 2009 | HP 1040 Plain Paper Inkjet Fax
Digital answering machine
Hi Bibi - Is this a regular land line? Is the fax machine supposed to answer if it's a fax but not answer if it's a phone call? Let me know exactly what your mothers' setup is please. It sounds to me like the fax is trying to answer all the calls and the screeching she hears is the fax machine try to handshake, or connect, with another fax machine. You've probably heard what that sounds like. Let me know the answers and if you can ask some people that called if they heard anything. Thanks.
Jeff
Jul 19, 2008 | Radio Shack 3808 Digital Answering Machine
The fax does not work - the displaye states sending and receiving but nothing happens. we have tested the phone line and tried plugging in to a different socket. the line rings but does not convert to the...
Most likely the modem is bad in the fax machine.
But a make and model number would help.
Some have the fax boards seperate, some are incorporated in the processor board.
Also it could just need the software reloaded or updated.
If you have a digital line, the majority of fax machines today STILL require an analogue line.
But a make and model number would be very helpful.
Thank you.
Apr 30, 2008 | Office Equipment & Supplies
Prints Faint green horizontal lines
Go to control panel and printers and faxes and right click on printer icon then hit printing preferences, go to maintenance and do head cleaning cyles and print nozzle check. if it comes out fine trash and reinstall driver
download driver from support.epson.com site after selecting the printer mdel on the lists
Apr 12, 2008 | Office Equipment & Supplies
HOW TO STOP VERY LOUD SCREECHING RING
Assuming there's nothing in the manual that tells you how to stop it. Is there a hole where the sound comes from? Block it up with blu-tack or sticky tape. Regards
Sep 25, 2007 | Canon FAXPHONE L170 Plain Paper Laser
HOE TO STOP VERY LOUD SCREECHING RING
I have the same problem. If you get an answer, please share with me. thank you....
Brother IntelliFAX 4100 Laser Fax Logo
139 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
