Question about Olympus FL-36 TTL Flash
My FL 36 suddenly stopped firing. Everything else is normal: the display panel, knobs and illumination. It does not fire even if I depress the test/charge button. What is wrong with the flash?
My flash does the same, let me know if you find a fix
Posted on Aug 05, 2009
I have a flamerite milan fire suite lights not coming on checked bulbs they are OK heating working also
No power to the fire: Check the wall socket, plug and fuse. No illumination: Make sure the fire is turned on. Check heater is working, if so change lamps. Illumination but no heat: The safety cut has operated see note on operating the Fire. Noise when illuminated: Due to moving parts, the electric fire will make a noise. Noise from the heater when in use: The sound of rushing air is normal. Logo
Jan 21, 2017 | Heating & Cooling
All 4 burners keep firing although the knobs are in the "off" position
It actually stopped doing it all by itself while we were waiting for a solution.
May 16, 2009 | Magic Chef 30 in. 8241RT Gas Cooktop
All 4 burners are firing although the knobs are all in the "off" position. I can't get them to stop firing.
Unplug the oven for at least 30 minutes. Plug it back in and see if it stops. If not, the control board has a problem (could be just bad connections).
Olympus fl-50 powers up but flash does not fire / work
I have the same problem, I have looked every where even on the Olympus site and have no luck finding anything, I paid £280 pounds for this unit and have hardly used it. Took it to a few repair center's & they reckon £200 pounds to repair it (how can that be) I only want it repaired and am sure it is the bulb I don't want to buy a new one this could happen again at great cost to me. I have to say I am not very happy with Olympus at all, bad service, & lack of help with this problem.
Jan 17, 2009 | Olympus FL-50 TTL Flash
Non-syncing Olympus FL-36
Hey I have an E510 and an fl 36 flash unit and no problems for a year now.
And no problems at all {knock wood]!
Have you checked to see if all the flash pins are making contact?
Normally I only turn my flash on after I put it on the camera and then turn the camera off and then on again to see if everything is ok. I remember the flash would not communicate with the camera on a shoot and after a while I realized that the flash was not all the way in the hot shoe. Fool around with the flash off the camera first and see the flash have modes that you have to set up if the mode is set in full manual that might be a problem. There is a button that you have to hold down for three seconds to get in the menu. My buttons are fine and have not faded any at all. I realize that the power button an the flash is hard to press on, I do hope I was of help .GOOD LUCK
From Chris
May 12, 2008 | Olympus FL-36 TTL Flash
Jennair CCG2523 Gas Cooktop
igniters fire continully any time knobs are on, even after burners
are lighted.
Sep 18, 2007 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Firing Ingnitors
But when the top is closed, it starts clicking means that wire touching body of your range. Carefuly check wire connection and insullation, re-connect, or repair damaged wire insulation or replace damaged wire.
Aug 29, 2007 | Tappan TGF657 Gas Kitchen Range
Open Questions:
Olympus FL-36 TTL Flash Logo
200 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
