Question about Leisure HOMEPRIDE Electric Fireplace Heater w/ Remote
Heat n Glo electric fireplace w/remote just stop working.
It was working fine until recently I tried turning it on and it attempted to come on then it just stopped. It don't appear to be getting power. Is there a fuse behind the panel that may need to be replaced? Any help would really be appreciated. Thanks.
Throw it out on the street when a bus runs over it file for insurance and get a new one. tell the insurance company you where having a city bonfire in your front yard and the bus jumped the curb. You know city slicker folk in those tall buildings don't know any better.
Posted on May 25, 2009
My heat n glow gas fireplace stopped working- got the pilot light lit and ran when I turned the switch on and then just pooped out. Pilot still going strong, but nothing happens when I turn it to "on".....
Posted on Oct 28, 2009
  • pnine Jan 17, 2011
    I have the same problem
I had the same problem with mine and my daughter told me in order for the heater to work the fireplace has to be turned on first..and ya it worked...but now it is gone again..and the firplace works but no heat or fan
Posted on Nov 01, 2009
Pilot is on, wall switches for both ignition & fas have been changed out. Still get NO flame when wall switches are turned on.
Heat & Glo ' Install & Owners Manuals
www.heatnglo.com/Owner-Resources/Install-and-Owners-Manuals.aspx
Each fireplace, stove and insert has a rating plate which contains your model number and serial number. Gas and wood burning fireplaces have a rating plate in ...
Resetting Your Heat & Glo® IntelliFire™ Plus Ignition ...
? 2:21
www.youtube.com/watch?v=_-8dY8tUGhw
Aug 24, 2012 - Uploaded by HeatandGlo
Resetting Your Heat & Glo® IntelliFire™ Plus Ignition System Video ... Relighting Your Heat & Glo® Standing Pilot FireplaceVideo - Duration: ... How to Install Your New Gas Log Set - The Fire Place - Palm Desert - Duration: ..
Oct 07, 2015 | Heat N Glo 6000 Gas Fireplace Manual
I have a heat & Glo XLR Plus. This is the first time I have used it but when I turn it on, the flame burns for around 30 sces then goes out. Then after about 30 secs it comes back on.. then off and so...
On your hand held remote [check your remote's owners manual], there is a mode setting for thermostat. This allows your remote to act as the thermostat for the room. It is in this mode and the temperature is set close to the current room temperature. Turn this mode off. Do not use this mode. Obviously you do not have the required experience to use it. It will come on and off even when you are not home. Again, until you become a lot more familiar with the setting, turn it off.
Mar 08, 2015 | Heat and Glo GFK-160A Blower Kit for Heat...
Fireplace remote not working properly
Jim,
I'm not sure if you have found a solution to your problem yet, but if you would like to provide some additional information about your problem, I'd be happy to help.
If you are looking for a replacement, I have them available here: Smart Stat Remote for Heat-N-Glo.
Jan 01, 2013 | Skytech Smart Stat Fireplace Remote for...
Owners manual heat-n-glo smart-stat
Try searching through this:
http://www.heatnglo.com/Resources/Customer-Care/Installation-Manuals.aspx
Nov 11, 2012 | Skytech Smart Stat Fireplace Remote for...
Smart stat 2 fireplace remote chirps similar to a smoke alarm. batteries have been replaced twice. Chirps at the receiver which is a plug in style no batteries. The beep can be stopped for a few hours by...
The chirping has nothing to do with your fireplace or electrical. The Smart Stat II remote is for use on a millivolt system only. The receiver sends out a signal every 15 minutes. If it can't find the hand held remote, it will chirp. The hand held must be within a 15 foot range. There were some issues with the remotes back in 2009, I believe. They were faulty and would chirp for no reason. They were covered under warranty for one year. In my opinion, these remotes are not as good as they should be. A TV remote lasts for years without missing a beat and has a better response rate. I've seen these replaced up to three times a year. At $229 a pop, hmmmmmm. You be the judge. Sorry for the side track. Move the hand held closer to the fireplace. The decorative front that is on the fireplace can also interfere with the signal as the receiver is under the fireplace and the metal front can stop the signal. Either pull the receiver out from underneath and set on the hearth or just pull it closer to the front to keep hidden. Another issue with low voltage systems is dirty connections. If your wall switch or remote just suddenly stops working, try unplugging all connections and reconnect. Being low voltage, any bit of corrosion will prevent it from completing the circuit. Gas fireplaces are not difficult to work on or maintain. Just use common sense. There is a 110v outlet underneath to power the fan and any kind of electronic ignition there may be. So be sure to lock out the breaker if needed and shut off the gas supply. Most electronic ignition systems have a battery backup that will start the fireplace and radiate heat. Batteries should only be installed when the power is lost or they will corrode and be useless. The respective brand website usually have owners manuals and replacement parts breakouts for your review or download. Hope this helps. Crank up that fireplace and stay warm!
Sep 01, 2011 | Skytech Smart Stat Fireplace Remote for...
Need thermocoupler for GTI Gas Technology fireplace insert
Contact your nearest Heat-N-Glo dealer for part #446-511 thermocouple. If you need a thermopile thats part #2103-512. To find your nearest dealer go to www.heatnglo.com
Dec 27, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Need Help
I have a 14 year old GTI fireplace the pilot is lite but when i push the button to turn it on , the fire place does not come on help please
Apr 03, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
2,076 people viewed this question
Top Leisure Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
Are you a Leisure Heating and Cooling Expert? Answer questions, earn points and help others
