Question about Westinghouse Televison & Video
Westinghouse sk-32h240s no picture
Need part # for power supply with inverter transformers on it. Also a parts supplier.
  • 105 Answers
SOURCE: Has sound,picture only comes on for a couple seconds at start up.
This is a Backlight Bulb or Inverter (power supply for backlight) failure.
If in warranty, take it to service
You can try to order an Inverter, or if needed you can get a replacement bulb (not easily available)
Posted on May 18, 2009
SOURCE: Need a service manual for SK-32H240S TV
They are now sending me a new TV
Posted on Jun 03, 2009
SOURCE: Westinghouse SK32H240S 32'' LCDHDTV Picture appears and Disappears
This problem is caused from a problem with the main board. The main board will need to be replaced. It runs from $100.00 to $150.00.
Posted on Jun 10, 2009
SOURCE: SK-32H240S Gets past the "W" then goes black, with sound.
one of your transformers probably blew. had same problem with mine so took it apart and saw the problem. did some research. Darfon makes the power board and you have to buy the whole board not just the transformer. could cost you around 200 dollars. best bet is to call a local tv repair company and see if the have spare transformers for that lcd.
Posted on Jul 09, 2009
ladywinn
  • 5138 Answers
SOURCE: I HAVE A WESTINGHOUSE HD TV 23
Look for Bad capacitors on power supply board they will be vented or swollen on top 220uf 10v 330uf 1000uf 16v
Posted on Mar 18, 2010
Westinghouse SK-32H240S has no picture.
yes there is something wrong with the board
Aug 03, 2012 | Westinghouse SK-32H240S Television
Westinghouse SK-32H240S no backlight
The voltage source to back light inverteres are from the main power supply regulator board. Check it.
Jul 20, 2012 | Westinghouse SK-32H240S Television
I have a westinghouse tv model number SK-32H240S the sound works but the picture dosen't if u turn the tv on the picture comes on for 1or2 seconds and goes out again
Hello Olga, this problem is normally caused by something on the power/inverter board (normally a transformer or a capacitor). If you are technical you can open up the TV and see what component is bad, you can normally tell because the component will leak or in the capacitors case be puffy. If you are not that technical you can also open the unit and simply pull all the plugs from the power/inverter board (big brown board on the left hand side when TV is facing down), take off all the screws, and replace the whole board. I can assist you with obtaining part #'s for this board if you would like just simply send me an email with the model #, serial # and TW # all located on the back of the TV as well as a brief explanation of what the TV is doing to westytech@westinghousedigital.com. Please rate my answer if it was helpful, have a great one.
Mar 28, 2011 | Westinghouse SK-32H240S Television
Westinghouse sk 32h240s problems less than 2 years old....sound but no video
Hello, it sounds like you need to change your LIPS board which has the power supply with the inverter board all in one board. You can find this part by emailing parts@wde.com, please make sure you include the model #, serial#, and TW#, all located on the back of the unit. If you would like more information you can also email me at westytech@wde.com. Please rate me if this information was helpful.
Jan 31, 2010 | Westinghouse SK-32H240S Television
I have a westinghouse tv model number SK-32H240S no picture
It seems that your unit has some sort of Video side, PSU fault, or a problem to the Video section that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 21, 2010 | Westinghouse SK-32H240S Television
Westinghouse tv Mod.SK-32H240S COMES ON SHOWS THE
This model has what are called a LIPS board in it which is a board that has both the power supply and the inverter on the same board. What you need to do is replace this part and your TV will be as good as new. To obtain this board simply email parts@wde.com and they will let you know price and availability of this board. Please make sure to include model#, serial#, and TW#, all located on the back of the unit.
Jan 19, 2010 | Westinghouse SK-32H240S Television
We need a replacement bulb for our westinghouse LCD tv sk-32h240s, but don't know exactly what part to order
Hello, you need what is called a LIPS board which is power/inverter board, in order to get price and availability please email parts@wde.com, make sure to include model#, serial#, and TW#, all located on the back of the unit.
Dec 24, 2009 | Westinghouse SK-32H240S Television
May 18, 2009 | Westinghouse SK-32H240S Television
Picture flashes for 1/2 second then is gone...sound continues
power supply if led ligth stays blue and then after a few minutes changes to orange is your power supply.if light color goes to a purple that is your mainboard $$$$$$$$$$$
Oct 14, 2008 | Westinghouse SK-32H240S Television
Televison & Video Logo
1,094 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
