Question about Gateway MX6453 Notebook
Gateway mx6453 thought I heard a snap and the comptuer went dead.
Thought I smelled a transformer type smell but wasn,t sure. About an hour into using it,it just went dead.I pushed the start button,the light in front flashes red a few times and thats it. I have a bad connect with power cord into the computer. Outside chance the battery is dead and can't make a connection with power cord but I don't think so. My last hope is here.
  • dougnr Mar 21, 2009
    I just had the same problem. I plugged in the power supply while the computer was running. I heard a 'click' and the unit went dead. The power supply is fine, so I had hoped it was a fuse I could get at, but I can't seem to get the bottom cover completely off.
    I bought this thing at Best Buy so I may see what they would charge to have a look.
    Problem Solver:
  • 18 Answers
It sounds like you have a fault with the power port on the mainboard or power board (quite a few gateways have a separate power board) , the battery won't charge if this damaged or loose which would explain the dead battery. The smell is probably caused by sparking on the loose power port. I wouldn't try to power it on anymore as you may damage it further. it is possible that the area around the power port is burntout therefore rendering the powerboard or mainboard useless but they are replaceable at a cost. If the laptop is still under warranty then you will need to take it back to where you brought it.
You will need to take it to an engineer to have it assessed unless you are able to make the repair yourself. Good luck hope this helps.
Posted on Mar 04, 2009
Low humming noise and burnt plastic smell coming from 1990 acura integra
Jennifer what type of timing belt does your engine use ?
Is it Nylon ? When was the last time you had it changed ?
Burning plastic smell may be being caused by the timing belt bearing runners seizing and the belt is getting hot .
If the belt is due to snap you could cause a lot of damage to the engine if it breaks.
Might be worth getting a mechanics advice on this as a possible cause
Mar 04, 2017 | 1990 Acura Integra
Metal snapping noise, like a broken spring, now burning smell. clutch?
Sounds like the throw-out bearing or the pressure plate has gone out..
Jun 24, 2017 | Cars & Trucks
Fridge & Freezer smell like a gas grille...
Do you mean it smells like propane? Or does it smell like propane exhaust (think taxi cab or fork lift)?
Either sounds pretty serious. I have heard of people using hydrocarbons to recharge refrigeration systems, though it is not the recommended method.
Do you own your residence or do you rent? Either way, call a repair man or the management of your rental right away and insist to have it inspected.
Fridges might smell like plastic or stale air if not used in awhile, but not propane/exhaust that I have ever heard of.
Jul 30, 2009 | GE GSH22SGRSS Side by Side Refrigerator
My 1999 cavalier will not shift out of first gear
fix the fan first, the trany may be over heating, drive it. if not shift, check the fluid level. check the colour and smell for it having a burnt smell
Jul 22, 2009 | 1999 Chevrolet Cavalier
Dryer smoking, burned rubber smell
if the rug has a rubber side it will melt make sure dryer is clean and no left over burnt material ..
Sep 18, 2017 | Dryers
Gateway notebook mx6453 died in the middle of using it
hi it sounds like you need to get a new power jack for your laptop.
Mar 04, 2009 | Gateway MX6453 Notebook
Have a 2003 Cadillac CTS that I first smelled a rubber burning smell come out of a/c vent while sitting at the light only. Then today went to go home and heard all familiar noises when you start a car but...
Hello, I dont know if I can help you or not but this is what was going on with my car: It had the same smell coming out after the car was warm enough. It smelled like rubber burning. I took it to the GM Goodwrench and they thought it was just a loose nut that caused an oil leak. So they fixed that but it still had that smell. We discovered it was our power steering fluid leaking onto the engine. Now maybe your smell is from leaking transmittion fluid and the car's security systems are a pain in the ****. They will lock the car from starting if it thinks you hurt the car. I dont know if this helped but I hope it did.
Feb 21, 2009 | 2003 Cadillac CTS
Service to Whirlppol MH7130xez-1, circuit breaker popped then unit went dead
water may have leaked inside unit causing a short.the transformer output is about 1400 volts that feeds a large capacitor. a direct short can blow the transformer instantly or any support parts without time to burn something. creating little or no smell. I never sujest that a person
to try to repair a microwave oven because
the capacitor can still be charged and very lethal.
Feb 25, 2008 | Whirlpool MH7135XE Microwave Oven
Gateway MX6453 Notebook Logo
167 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
