Question about Numark TT1520 Turntable
Hi, i have recently started djing and i am wondering if i have to run my speakers through an amp into my mixer or is there any kind of adapter i could get so i could just plug my speakers into my mixer. thanks Nuke.
  • Nuke22
    Nuke22 Mar 04, 2009
    thank you sooooo much! also, do you know where i can get cheap amps from?
    thanks again!!!
    Nuke.
  • Nuke22
    Nuke22 Mar 04, 2009
    thanks again, great help.
    Problem Solver:
  • 17 Answers
Typically in about 95% of cases you will have to amplify your signal coming out of your mixer, befor going to your speakers. The line voltage that comes out is too weak to be heard unless amplified. When you purchase your amp, let the m know what the ohm rating is of your speakers,... this can be found on the back of the speaker, and will usually be 4 or 8 ohms(sometimes 2 or 16 but not too often).
Posted on Mar 04, 2009
  • Jay Alsman Mar 04, 2009
    I've found the best place for used audio gear is craigslist. You can get a decent QSC, Mackie, or Crown amp pretty cheap.
Powering a passive stage monitor
A passive loudspeaker requires an amplifier to increase the power from the mixer.
An active speaker does not require an amplifier and will work direct from a mixer as the amplifier is built into the speaker box.
Jan 20, 2018 | Behringer Pmp3000 16 Channel Audio Mixer
Speaker humms only. what causes that?
Incorrect connections or volume settings.
• In powering up, mixer first then amp
• In turning off , amp first then mixer
If hum still persist, without the mixer connected
then speaker amp may need servicing.
Jul 31, 2012 | Samson Auro D415A Speaker PA Active
How to connect mixer to a crown power base 2 amp and speakers
just use the main left and right outputs of the behringer to run xlr (3 prong balanced) to 1/4 inch (looks like a big headphone plug) cables into the inputs of the crown amp. the mixer has the xlr outputs and the amp has 1/4 inch inputrs, sop the cables will have to reflect that on both ends. run the outputs of the amp (rca outputs, i believe, you may have to get a rca plug to 1/4 inch jack adapter, and then use a 1/4 inch speaker cable) to the inputs of the speakers, again, the amp has rca outputs and the speakers will likely have 1/4 inputs, so you will have to address that wil an adapter. have each speaker in its own channel.
Nov 22, 2010 | Behringer *new* Behringer X1222 16-input...
How to connect microphone to Yamaha RX-V365 as a PA system.
Home-theatre receivers don't have microphone inputs. If you want to use the receiver as an amplifier in PA system, you need to use some kind of mic pre-amp or a mixer with mic inputs.
For PA mixer is needed anyway almost every time and all mixers have at least one mic input (with a pre-amp). Mixers have line-level output(s), which you can connect to the analog input of receiver.
Using receiver as an amp in PA has advantage that you have 5 channel amp. When using high sensitive PA speakers (as oposed to less sensitive Hi-fi home speakers), you can get good performance with the power rating of receiver. You could even use 2 separate channels for subwoofers and 2 channels for satelite speakers - but for that you would need a receiver with 5.1 analog inputs and special device called crossover which would divide the output from mixer into low-frequency signal and high-frequency signal which you would then connect to the front and rear analog inputs. But with RX-V365 you can use only 2 channels with analog input
Sep 15, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Amps ? stereo intergrated amps ?
Since the mixer has a line level output, yes you can use a home stereo for the "AMP". Use the AUX IN, TAPE IN or CD IN on the stereo and connect the speakers as you normally would.
Dan
Feb 26, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Low Volume using Kaoss Pad Mini while DJing
I'm having the problem too...I'm thinking that maybe getting the DC adapter MAY fix it though as stated in the Manual: "...The output level of the mini-KP will be smaller than its input level. This is because the attenuator circuit is connected at the input section, considering that the mini-KP is used on battery power." so maybe the dc connector will increase output volume?
Aug 22, 2009 | Korg Mini Kp Kaoss Pad
Just wondering what the power supply output JBL Media 3 Speakers
I have a pair of Media 3 JBL computer speakers. I am using a generic 12V DC adapter rated at 1000mA with a positive tip polarity, and it works fine.
Aug 15, 2009 | JBL Audio Players & Recorders
New to PA systems......
What brands are we talking about my friend?
Oct 09, 2007 | Audio Players & Recorders
Dj equipment
SEnd all the high notes to the small speakers and the bass to the sub. Ran.
Apr 27, 2007 | Gem Sound GemSound PA-585 2-Channel...
Numark TT1520 Turntable Logo
151 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
