Question about Lexmark Wheelwriter 6 Series II Typewriter
The letters do not print on paper
The machine types, but the letters do not print on paper.
  • Dick O Reilly May 11, 2010
    Make? Model?
    DickyO
  • Lexmark Master
  • 3,594 Answers
Andrew is right, however if you have some technical ability the part W/instructions and shipping are available for 20.00.
DickyO
1-216-241-0027
Posted on Apr 18, 2009
  • 125 Answers
Hi:
You either have a sticky print solenoid or the rubber bumper on the end of the print solenoid has deteriorated with age. This is a very common problem with that vintage Wheelwriter. It is an easy fix for a qualified tech who has the right part. It's not really something a user could tackle themselves.
Posted on Mar 14, 2009
I have an HP LaserJet4 and I'm suddenly (as of last evening) getting a 41.3 error code followed by a 13 Paper Jam. I clear the jam, warming up, blank page is ejected, I put the printer back on line,...
41.3 - points to a miss match in the paper tray.
First -
Pull out your paper trays, take the paper out and confirm the guide in the back is set to the correct position. (The little mechanism on the tray which allows you to use different paper types, example letter to A4).
Second -
The other which may have happened it the paper handling was mis-configured on the machine:
- Press the Menu Button on the machine.
- Using the + and - button go to the Printing Menu.
- Select Paper confirm that the paper size is correct for the trays within the machine.
Third -
- Depending on the document you are attempting to print make sure the document type is either adjusted to the type of paper your using or to load the correct paper into the machine. I seen where people send you a legal document and your attempting to print it on letter.
Fourth -
It could be a driver related issue, 98% of the time this is not the case. If all fails above, then attempt this.
Let me know if this helps!
Lastly it could be a driver related issue, however if more than 1 person uses it don't count on it.
Nov 25, 2010 | HP Office Equipment & Supplies
The printer says Load MP feeder B5. how can I fix this.
Several options here:
1st - cancel any documents in the print queue. and print off a report of some kind via the menu button on the machine. if that prints correctly then it either a software/ print driver setting issue.
2nd - If that prints out correctly open up a text pad/ notepad and attempt to print that if the message pops up it's very possible the paper handling has been miss-configured within the print driver.
Now if the document does print out fine, the original document you were attempting to print is set to a B5 paper size. If that's the case pending on what program you are using you will have to change the paper size to you choice of paper your using.
3rd - open up the paper tray and confirm it's set to letter or legal pending what type of paper you have in the tray(not the manual feed tray). I highly doubt it's the tray however as B5 setting would not allow any type of normal paper to be loaded.
4th - on the machine hit the menu button -> paper menu -> confirm that the paper type/ size and source are configured correctly.
Link to the user manuals for this machine : click here
Oct 19, 2010 | Lexmark T632 Laser Printer
On a Image Runner 1023iF trying to print letter envelopes loaded in the Stack Bypass. Machine once it received the print job just beeps and flashes.
Hy,
did you select the correct paper size on machine display? When you put paper in baypass the copier ask you for paper size and type.
Sep 02, 2010 | Canon imageRUNNER 1023iF Black and White...
Paper won't feed
Inside of the machine is dirty.
If the inside of the machine is dirty, the printed paper may be smudged.
Follow the steps described below to clean the inside of the machine.
1. Ensure that the machine is turned on and there is no paper loaded in the Auto Sheet Feeder.
2. Place A4/Letter-sized plain paper in landscape orientation, horizontally fold it in half.
3. Unfold the paper, and load the paper in the Auto Sheet Feeder with the inverted-V edge down.
4. Select <Bottom plate cleaning> from <Maintenance>.
5. Select <Yes> on the Bottom plate cleaning confirmation screen and then press [OK].
Paper will be ejected.
If protrusions inside the machine are stained, wipe ink off the protrusions using a swab or such like.
* Important
Before cleaning, be sure to turn OFF the machine.
Paper feed roller is dirty.
Follow the steps described below to clean the paper feed rollers.
1. Ensure that the machine is turned ON and there is no paper loaded in the machine.
2. Select <Roller cleaning> from <Maintenance>.
3. Select <Yes> on the Roller cleaning confirmation screen and then press [OK].
The paper feed roller will rotate as it cleans.
4. Repeat this operation twice.
5. Load three or more sheets of A4/Letter-sized plain paper lengthways in the Auto Sheet Feeder.
6. Select <Roller cleaning> from <Maintenance>.
7. Select <Yes> on the Roller cleaning confirmation screen and then press [OK].
The paper that is loaded in the machine will feed through the machine and be ejected.
8. Repeat Steps 5 to 7 three times.
Inappropriate paper type is used.
Check to see if the paper you are printing on is too thick. See Paper Types You Cannot Use.
Note that smudging may occur at the top and bottom edges of the paper when using Borderless Printing. Ensure that the paper you are using is compatible with Borderless Printing.
Thick paper is used.
When printing on thick paper, set the Paper Thickness Lever to the right.
This widens the gap between the FINE Cartridge and the paper. Try this maneuver if the printed surface is scratched.
Media is curled.
If all four corners or the printing surface of the paper is curled, the paper may become dirty or may not feed properly. Use the paper after correcting paper curl as follows.
1. Place the printing surface face up (A), and cover it with a sheet of non-printing regular paper to avoid damaging the surface.
2. Roll up the paper in the direction opposite to the paper curl as per the figure below.
3. Check the printing paper to confirm if the paper curl is eliminated to within approximately 2 to 5mm / 0.08 to 0.2 in (B).
It is recommended to print on curl-corrected paper one sheet at a time.
The media type is not selected correctly in the printer driver.
On the [Main] tab of the printer driver, ensure that the [Media Type] selected matches the paper loaded.
In the [Print] dialog box of the printer driver, select [Quality & Media] from the pop-up menu, and then ensure that the [Media Type] selected matches the paper loaded.
Paper is loaded incorrectly.
Load in the portrait orientation regardless of the print direction of the Auto Sheet Feeder.
Ensure that paper is loaded correctly. Slide the paper guides against the paper stack.
Oct 18, 2009 | Canon Pixma MP500 All-In-One InkJet...
I dont get prints when I give print command but when I use the
What does it say in the display?..load paper plain letter....load MP feeder? I think the problem is the following. On the menu right arrow over to the paper menu. Hit select...it then gives you sub menus...paper type...paper size. Go to paper size...specify the tray your using...most likely tray one. Hit select and see what size paper its set on. I'm assuming your trying to print on letter size. If it says something else like legal...executive..A4...change it in the menu to letter. If it changes to letter hit select to save the setting. Now if it won't change in the menu pull open the paper tray. The back paper guide is real sensitive on these machines. You have to make sure the geen/blue tab on the back is set exactly into the letter size slot on the tray. That slot will be slightly bigger than the rest of the teeth you see on the bottom of the tray. If you have it set right then there should only be the 2 bottom tabs extending on the outside left side of the tray. Those tell the printer what size paper is in the tray. If theres 3 sticking out...you still don't have it set right for letter size. Okay..the last thing. Something that goes bad on those machines is the tray card. Its where those 2 tabs on the side of the machine I mentioned interface with the printer. They can go bad. You can either replace that card..or trick it. To trick it go back to the paper menu...paper size tray 1. Open the tray...and close it again. The setting on the screen will change to another size...do that again or until it changes to letter size. The leave it alone. You may have to do that everytime you add paper an reinsert the draw unless you replace that card. Hope this helps!
Mar 24, 2009 | Lexmark Optra S 1855 Laser Printer
Problem printing on matte photo paper
no thats why it is not working the right way you have to use the semi gloss paper thats what it requiers
Jan 03, 2009 | Brother MFC-3240C All-In-One InkJet...
Printing 5x7 invitation
use the mpf tray. go to the machine press menu down arrow untll you get to tray settings. right arrow over till u get to paper type...then down arrow till you see paper size...right arrow again till u see tray 1...down arrow till you see mpf..right arrow till you see letter. Now that you are in the mfp section you can down arrow and you will see serveral selections I would keep it at letter. when you select it an * will appear next to letter. Then select menu and you and the printer is set. Now go to the print option in the program that you are using and when the dialog box to print opens select properties. go to paper quality the mpf should be selected in the tray souce. Now go down and you will see the advance button, click on that you will see Paper/Output make sure it says Paper Size and Letter is selected. Media Type should say Plain 1. If the invitations is on a heavier paper like card stock click the down arrow and select Covers 1 . If your paper is coated like matte finish photo paper select Coated 1. Now click ok. Do a test print and see if you get what you want. If not, let me know.--Deeva
May 21, 2008 | Dell 3100cn Laser Printer
Problem with Brother MFC-9420CN
This happened on my MFC-9420CN. It turns out the there are blue tabs inside the paper tray that hold the paper in place. If the tabs are not touching the paper, you'll get this "Check Paper Size" error. The printer thinks that you have loaded a different paper tray.
Don P. Greensboro, NC
Nov 07, 2007 | Office Equipment & Supplies
Printing on Stationary with an HP Laser Jet 1320
Most printers and copiers are made for the standard 20# paper, if using a different paper then most of the time you need to specify what type ie: transparency, labels, lbs etc. so the machine can accommodate itself. ( lowering or increasing the heat in the fusing section, and pressure on the paper.)
for that machine everything is done through the pc. go to File, Print, right click on the printer, go to properties got to device settings, General, printing preferences and paper quality, there is a box there for paper options. try setting it to cardstock.
Oct 04, 2007 | HP LaserJet 1320n Printer
Lexmark Wheelwriter 6 Series II Typewriter Logo
112 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
