Question about Dell Dimension 2350 PC Desktop
My Dell Dimension 2350 no longer powers on. Yesterday it powered on ok and powered off ok. My guess is the power supply is bad. Checked the power cord (with a voltage meter) and 117 VAC is at the end (where the cord plugs into the PC). Looking for a repair manual for this PC (Dell Dimension 2350). Any suggestions on how to troubleshoot this problem?
    Sniper:
  • 55 Answers
Dell has this great tool where you can troubleshoot an issue in a methodical way, step-by-step.
Here is the link to troubleshoot No Power, No POST, No Video [Dell Dimension 2350 Desktops] Just follow the steps and choose the option and continue. Remember not to skip any step since each of them has a purpose.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?c=us&l=en&s=gen&journalid=6445B6E320AC44A4E040AE0AB8E12519&treeid=4F62A0ECE60449EE8150A94E91B6BD27&Query=bm8rcG93ZXI=&SystemID=DIM_PNT_CEL_2350&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=true&dl=
Below is also a link to the Dimension 2350’s user manual.
http://support.dell.com/support/edocs/systems/dim2350/
Hope this helps. Please rate your feedback!
Thanks,
VJ
Posted on Mar 04, 2009
Dimension 2350, on stARTUP ONLY
Remove the power cord, remove the case and look inside the computer at the capacitors. See if any of them are busted or leaking corrosion. The capacitors look like little battery towers but they are not as tall as AA or AAA batteries.
May 02, 2012 | Dell Dimension 2350 PC Desktop
Blinking amber power light pc will not turn on replaced power supply
Out of Dell's Dimension 2400 User Guide, the 2350 user guide doesn't list it;
"If The Power Light Is Blinking Amber - A device may be malfunctioning or incorrectly installed
1) Remove and reinstall the Memory modules."
From me;
Ram memory modules. Slang? Ram memory stick.
I would suggest cleaning the gold plated contact pins, on the bottom of all ram memory modules, then reinstalling.
Use a pencil eraser.
If using the eraser on the end of the pencil, and not a solid eraser, refrain from touching the gold plated contact pins with the metal band.
Handle the ram memory module by the Body of the module. Refrain from touching the contact pins.
[ The Body is everywhere but the contact pins themselves. The body of the module is coated with a see-through protective plastic,
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
{ The Dimension 2350 Desktop PC uses DDR Sdram ram memory, at 266MegaHertz. Or also stated as PC2100. The above example in the link for DDR Sdram above, just happens to be PC2100 ]
Rub each contact with the eraser, both sides. Doesn't take much to clean the surface.
{Doesn't take much 'corrosion' to make a bad contact, either }
Use air to remove the eraser dust.
" 2) Remove and reinstall any cards."
From me;
Cards being any adapter card OTHER than the graphics card. Any adapter cards in a PCI slot.
(For the Dimension 2350 )
"3) Remove and reinstall the graphics card, if applicable"
From me;
If applicable. Means IF there IS a graphics card installed.
Plus for the Dimension 2350, a graphics card will be installed in one of those three white PCI slots.
I have seen a PCI slot burn. I have also seen where the PCI slot was bad, but showed no outward visual signs of damage. Solution was to use a different, available PCI slot.
By the time this is all going on though, the board should be scrapped. (Mobo)
What do the Electrolytic Capacitors on the motherboard look like? Show any outward visual signs of failure?
http://www.capacitorlab.com/visible-failures/index.htm
Plus, just to be sure have you tested the voltages of the new Power Supply?
Isn't actually an accurate test, but if voltages alone aren't what they're supposed to be, the PSU is bad.
(Accurate test is the Power Supply is under a load, then the voltages are tested )
3.3 Volt power rail, (Orange wires), 5 Volt power rail, (Red wires), 12 Volt power rail, (Yellow wires)
Test with a multimeter set to DC voltage. (Function knob set to DC voltage. May be just a DC Voltage symbol. Dotted line over solid line. If there is more than one setting, set it to the 0-50 Volt scale )
An economical multimeter can be purchased for around $6 to $12.
Bad power supply's do get shipped. Doesn't matter if a power supply is new, it can be bad.
Power Supply power cables unplugged from motherboard, (And laid aside so that they are Not near any hardware components ), turn the Power Supply on. See if it at least stays on by itself.
[ Jumper to back of the 20-pin ATX main power cable connector. From Green wire socket hole, (Soft Power On wire), to ANY Black wire socket hole. ( ALL Black wires are Ground wires )
Make SURE the jumper wire goes down into the two socket holes, far enough down to touch the metal terminal connector, at the end of that wire.
Preferred jumper wire is a straightened out paper clip, bent into a U-shape, and the middle of the U-shape is wrapped with black plastic electrical tape.
But you probably know this, as you had to test whether the problem was the Power On switch, (ATX power on switch), or the Power Supply, before purchasing a new power supply.
{Or did you?}
No to all of the above? Power supply checks out?
Start removing Peripheral hardware components.
Optical drive/s first.
(Computer unplugged from power, Anti-Static Precautions observed )
Then the harddrive. You are just trying to see if the power supply will come on, and stay on, for now.
Ram memory.
If the power supply comes on, and stays on with a particular peripheral device removed, stop.
There is the problem.
For additional questions post in a Comment
Regards,
joecoolvette
Nov 10, 2011 | Dell Dimension 2350 PC Desktop
Dell Dimension 2350. After I shut it down and try
Check that the computer is not hibernating rather than shutting down. It will be in the power settings.
Mar 06, 2010 | Dell Dimension 4600 PC Desktop
Dell dimension 2350 won't boot, the psu fan comes on and the fan for the heatsink, the hard drive makes so noise what so ever and the disk drives won't open at all.
Depending on the Power and Diagnostic LED indications the system appears to be in a no post state. If the power LED is flashing Amber, the power supply is suspect. Solid Amber, indicates a motherboard problem. The Diagnostic LEDs on the back marked ABCD can give more specific POST error details.
Mar 05, 2010 | Dell Dimension 2350 PC Desktop
My dell dimension 2350 whines. Could that mean the fan is failing?
It can mean that your power supply is failing. You must first determine where the sound is coming from. There is a fan above your heat sink and there is one in your power supply.
Jan 17, 2010 | Dell Dimension 2350 PC Desktop
2350 dead, not starting, just green flashing on board, no fans
Pull your hard drive and install it as a slave on another machine. If you can't read from it there, your hard drive is toast.
Oct 05, 2009 | Dell Dimension 2350 PC Desktop
Dell dimension 2350 shuts off after a few minutes
Definitely check the power supply fan and the CPU fan for dust. Overheating could be the culprit, good luck.
Mar 18, 2009 | Dell Dimension 2350 PC Desktop
My dell dimension 2350 won't turn on.
Probably the motherboard, if not the power supply. You're gonna need to visit a local repair shop to find out for sure.
Feb 21, 2009 | Dell Dimension 2350 PC Desktop
Dell Dimension 2350 PC Desktop Logo
453 people viewed this question
Alun Cox
