Question about Sylvania LC320SS8 32 in. LCD Television
This set is almost new having never been hooked up to an antenna
And has only been played to watch DVDs for about 5 hrs. When I turn it on the greeen light just blink and then the set turns off.
  • fourway Mar 24, 2009
    On power on the light switches from standby to on and the screen lights up and displays the "Digital Television" text that it always shows for a moment while powering up. then the green likgt flashes a few times and it powers down.
    Sylvania tech support said unplugging the TV for an hour should fix it. when I called back to say it didn't help they basically said sorry your problem.
    This is a $600 set that lasted exactly 12 months and 4 days.
    That's right, out of warrantee for 4 days.
    I am absolutely furious.
    Cost of ownership $50 a month.
    For that money I probably could have rented something in the 57 inch area.
  • 463 Answers
First thing to do is unplug the power from the wall for about 1 hour, then plug the TV back in and see if the results are the same.
If so, obviously the television is in some sort of error condition, or the input is set to something like HDMI and you're using the compnent inputs.
contact sylvania customer suppport:
on the web:
http://www.sylvaniaconsumerelectronics.com/support/
by mail or telephone:
Customer Support Telephone Hotline
800-968-3429
have the make and model no. of your TV handy.
http://www.sylvaniaconsumerelectronics.com/contact/index.html
And good luck, because Sylvania's website is SLOW and most of the time unresponsive. You'll probably get faster results by returning the unit to your dealer and raising a stink.
Posted on Mar 04, 2009
Sony flat-screen bravia tv picture goes black but keeps playing audio when playing Netflix or DVDs.
your dvd player needs its own connection as does netflix and cable,get a new hdmi cable for each
Jul 11, 2015 | Samsung Audio Players & Recorders
How do i set my Toshiba ct-90157 remote to watch dvd's
Most DVD players are connected to one of the rear audio/video inputs--hook to that input and select it on the TV--then hit play and if connected correctly you will see the movie.
May 20, 2012 | Toshiba 50A50 50" Rear Projection...
Does the JVC AV-56P776 have any kind of lock out on it went thru setup it plays dvd's but not regular tv
if plays DVDs via rear connections what have you got hooked to it for regular tv reception? Hooked to the coax fitting, using antenna or cable or sat with a box or not?
Good news is if it works with DVD set is likely ok and you have some other issue----just need some more information to decide what that issue is.
May 02, 2012 | JVC Televison & Video
Hi i have a ripspeed dv710 plays the radio fine put a cd in and theres no sound but timer goes up si a no its plying same on dvds you can watch the film but no sound anybody help??
it sounds like it was installed incorrectly. there must be amps in the car. when the dvd player was installed they hook up a blue wire on the back of the radio. its a power antenna wire . switch it for the blue white wire and youll be in buisness
Feb 04, 2010 | Car Audio & Video
Can't see dvd on TV
how to hook up to watch dvds
May 25, 2009 | Sansui VRDVD4005 DVD Player/VCR
Use Visio just for dvds?
(duh)
I will post this answer just in case anyone else out there has this problem.
Press the button on the remote that says AV. The blue screen saying "no signal" disappears and you can watch videos without a server or antenna connection.
Apr 10, 2009 | Vizio GV42L 42 in. LCD Television
How to hook up a dvd recorder with HTS6500/37?
Suddenly had this problem. My Phillips is hooked up to TV and to Cable Box. When I inserted a DVD it would return a "no disc" but it would read and play CDs. After a call to Phillips...who said that they had no idea what was going on and I should take it in for service...it was 4 months out of warranty. Repair company said it was not worth the repair costs ($200) so I should try cleaning the lens with a lens cleaning disc. I bought a Maxell. It has a set of little brushes on the bottom of the disc. I inserted it and played track 2 for 20 seconds as instructed and voila! It began reading the DVDs again. I was only out the $10 for the disc cleaner. If you have this problem, try the disc cleaner first as it might be the fix.
Oct 03, 2008 | Philips HTS-6500/37 System
Ilo DVD player/recorder
> jfthr - Tv convertor boxes transfer digital signals into ANALOG. So when it goes to the dvd recorder it IS ANALOG. I have my antenna hooked to my convertor box, the converter hooked up to the ILO (A/V connections) then, the output on the ILO to the input of my analog tv. (Video selection on my tv). It works great to watch tv and/or record. I switch to the "DVD SOURCE" to watch dvds. Maybe you have the conv box hooked to the tv then the outs on the tv to the dvd. That would explain why you can get a picture but not watch dvd? The ILO has to go between the box and the tv in order to watch dvd.
Aug 07, 2008 | iLO DVD Recorder DVDR05
How to connect my dvd & vcr with the converter box
Here is my setup.
1) Separate DVD player 2) Separate VCR 3) Digital to Analog Converter box 4) Analog TV 5) Rabbit ears (UHF/VHF) antenna
The antenna goes into the converter box.   The RF-output of the converter goes into the RF-Input of the VCR The DVD output goes into the front input jacks of the VCR The VCR RF-output goes into the TV RF-Input The VCR Line output goes into the front of the TV
To watch DVDs, we turn on the DVD player, turn on the VCR, and set the VCR channel to L2, and tune the TV to channel 3.  The converter is off.
To auto record on the VCR, the converter must be tuned to the station being recorded.  The converted must be turned on, the TV can be off.
To watch VCR tapes, turn the TV and VCR on.  The TV is set to channel 3.  Just press play on the VCR.
To Watch TV.   Turn the TV and converter on.  The TV is set to channel 3.   Change the stations using the converter.
May 06, 2008 | Insignia Digital-to-Analog Converter for...
Newer DVDs won't play properly
you need to buy a cheap av moulator (about 20.00 at most stores) this will solve the problem radio shack has them and so does wall=mart
Jan 13, 2008 | Panasonic Home Theater System System
Sylvania LC320SS8 32 in. LCD Television Logo
133 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
