I purchased this dryer when living in USA. Last year I moved to Brazil and brough a 20ft container with what I had inside my house.
After arriving here, I tried to connect the dryer and it didn't work. The L2 code displays in the dryer panel. After doing some research I found that here, like in Europe, there is a 1 x 220v from the outlet, while in USA it was a 2 x 110v.
Not sure if that dryer needs 110v in any of its components.
Could you please provide options on how to proper wire it to my existing outlet?
Thank you,
Paulo.
SOURCE: Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
SOURCE: Modifying the DC18RA from 110V to 220v
don't replace the transformer in ur charger.just get a step up transformer like 110v to 220volts with plug in receptacle.
SOURCE: Battery Charging Problem
The problem is not with the batteris, but with your charger, you have to make sure it can take 220V or you will burn it. Look for a switch on it to change from 110V to 220V.
SOURCE: MAKITACHARGER 220v to 110v problem after using of right converter
hi all,
I added another HowTo page for moding the DC18RA from 110V to 220V , you can find it here
Have fun and good luck
SOURCE: Kenmore series electric dryer need to replace 3 prong w/4 prong
The following link explains how to convert a 3-prong appliance cord to a 4-prong and vice-versa:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If you still have questions, please let me know. I hope this helps you.
