Question about Kodak EasyShare C310 Digital Camera
Hard time(force)turn on/off
Did not drop it,all of sudden it just stopped,very difficult when pushed to go on then need to hit the right spot before I can take pictures, miss my camera it was a gift
    Sergeant:
  • 270 Answers
Send it to the manufacture for survice
Posted on Mar 04, 2009
I have a 2007 ford explorer that when i hit the brake hard to stop, my truck is like out of gear and then suddenly goes into gear jerking. this also happens just at a regular stop sometimes. what is...
Sounds to be low on trans fluid, I think 2007 has to be filled from underneath on lift,the trans has a small plug,(Torx head)that has to have fluid" pushed"up through until it pours back out,I would check to see if any wet spots around cooler lines(small hoses that go to radiator.
Apr 04, 2014 | 2007 Ford Explorer Sport Trac
Kia Sedona hard to turn (2006)
Hi
If your system has leaked fluid out when you've topped it back up it could have caused an airlock in the system this can usually be rectified by turning the steering wheel from lock to lock several times whilst the vehicle is stationary this usually pushes the air out but keep checking the fluid bottle as the level will drop whilst its getting rid of any air !
Hope this helps Nick
Jul 27, 2017 | 2006 Kia Sedona
I have a garage door opener (Chamberlain Lift Master Professional 1/2 HP) all the sudden it stops durring clossing & opening The garage door. no paticular spot. just on a random spot at ramdom times,...
Somewhere on the power head( motor ) is 2 knobs. The are to adjust up and down force. As the opener gets a little old you will need to turn these up occasionally! Turn to the right a 1/4 of a turn and try. I that doesn't work turn it up a little bit more. This should get you fixed up!
Jul 21, 2011 | Kitchen Ranges
Door comes down and goes right back up. then the lite blinks 4 times with a click noise. the safety eyes also are not on
It sounds like you need to adjust your down limit switch and/or perhaps your motor force settings. If the limit switch is not in the sweet spot along the rail it can be triggering too soon or not in time. In your case it could be too far down the rail and thus not stopping/slowing the motor in time. Your door is then being pushed against the floor too hard. Your safety/return force is goes way over limit and tells the opener to go back. While closing your door look at your rail and if its bending when the door hits the ground, this is definitely happening. After finding the sweet spot for your down limit switch, you can readjust your return/safety force per your opener manual.
Jan 03, 2011 | Chamberlain 12HP Power Drive Chain Drive...
Extreme thumping when accelerating through a turn
differential could be low on oil
wheel bearings could be going out
tires could be out of balance, likely
Sep 29, 2009 | 2002 Audi A4
Power window on 1990 Ford F150 stops working
the motor has an armature inside that rotates.if it stops on the bad spot,it will draw alot of current.the armature has copper plates with a very fine separation between them.after a while the brushes wear the copper down and it can bridge 2 together.the motor will still run,until one brush stops right where the 2 plates meet.if you bang on it it will work too sometimes.
Jun 12, 2009 | 1991 Ford F150
'98 Ford Ranger clutch safety switch,
You have to see if the pedal is linning up with the switch when it is depress. The holder may be bent or moving when it is depressed.
Nov 22, 2008 | 1988 Ford F 150
Panasonic nv- ds65
Hi
I had the same problem and the solution is very simple:
Remove bottom plate by unscreewing the 7 screews (for one of them you must open the viewfinder) and make sure the ribbon cables are connected securely . You just need to push genty the ribbon cabbles and reposition the plate, this should solve the problem.
Apr 10, 2008 | Panasonic NV-DS65 Mini DV Digital...
Kodak EasyShare C310 Digital Camera Logo
53 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
