Question about Fellowes Manufacturing Powershred 4200CC (Cross-Cut) Shredder
What does a red light mean
Machine not working. The far left side light is red. What does this mean?
Greetings Gurus. I have Makita charger model DC18RC, battery model is 18v BL1815...manual is of limited help. I'm trying to understand what the indicator lights mean, what the time is for charging,
I agree that the pictographs are not very helpful. You probably have one of the new chargers. I have an old one, which is a little easier to figure out.
From top to bottom
1. The flashing green light with the electric plug indicates that the unit is plugged in and ready to go.
2. The flashing red little fan means that the battery is too warm so it is just cooling it and not charging it at that moment.
3. The solid red empty battery outline means that it is charging but hasn't got very far, less than 80% full.
4. The mostly full battery outline with both solid red and green lights at the same time means it is 80% full or more
5. The full battery outline and solid green with the musical notes means it is full up.
6. The broken battery outline with flashing red and green means you've got a broken battery.
7. The yellow light with the wrench means the charger is "conditioning" the battery, whatever that means.
8. The yellow light with the fan means "cooling abnormality."
Hope this helps
Nov 01, 2014 | Drills
My usb wireless mouse receiver displays a red light on the far right on what appears to be a picture of a battery. The green light lights up the number 9 on the left. WHAT DOES THE RED LIGHT MEAN? I don't...
I just had the same problem. If you look at the picture carefully, it's the mouse & the red light means you need to change the battery in your mouse. The picture just to the left of mouse picture is the keyboard so if that turns red, then you need to change the batteries in your keyboard.
Jun 11, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Sharp al 1631 not working properly
That is the drum replacement light reset it by pressing these keys: Clear, then the far left key, then Clear again then far left again.
So C, far left, C, far left
If done quickly like within 4 secomds the display should go blank. If so then key in 24 as if you were making 24 copies.
Now press the print button.
Now key in 7 and hit print again.
You should now be getting flashing zero's
Turn the machine off then on and the light should be gone and the copier is ready to use.
You can reset your drum life at least once with no problems.
Jan 05, 2010 | Sharp AL 1631 Copier
New Saeco Odea Giro machine not working
That is the machine is saying to empty the drip tray, pull out the tray on the side and wait until the red light start flashing then put back the tray.
Dec 24, 2009 | Saeco Odea Giro Plus Coffee Maker
I have a Sharp AL 1631 it won't print. It shows an H-4 in the menu screen
Press "Clear" then "Exposure Mode" then "Clear" then "Exposure Mode" quickly like within 4 seconds. The exposure mode key is the far left key.
If you do this correctly the display will go blank.
Key in 14 as if making 14 copies
Press the print button.
Short version: C, far left, C, far left, 14, print
The machine should reset and run fine. This is a common "false" code on these machines.
If it comes back after a couple of tries the you have a thermal fuse or heater lamp failure.
Nov 18, 2009 | Sharp AL 1631 Copier
Red alarm wording showing, what does that mean
The Alarm light will come on if:
1) The printer is out of paper.
2) The paper is jammed.
3) The paper is too far to the right. (The paper must cover the small groove on the left side of the rubber platen.)
Thanks for using Fixya.
Aug 27, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Red light above display flashes but no functions working
hi Dave
I'm not the most technical person in the world but I think I've fixed mine which had the same problem this afternoon, which is how I came to find your message!
Right.. here's what I did. It would appear that you have some kinda mechanism jam (even if there's no disc in it), so... please excuse my non-techie terminology throughout.
By the way, I probably don't need to tell you this but unplug the unit from the mains first or you might light up if you touch something!
Working with the unit facing you (control side), remove the two small screws at the back (on the metal flange) and two medium screws from the right hand and left hand sides of the main casing, then slide it off from front to back so that you can see inside the recorder. If you look in and down at the CD tray transport mechanism you should see a white plastic 'cog' wheel on the left hand side of the unit near the bottom 'floor' of the machine. Carefully rotate this wheel with a finger CLOCKWISE (pushing the wheel from front to back), slowly and gently - don't force it - and you should see the CD tray mechanism and gubbins start to move; keep rotating until the tray comes right out, or as far as you think it goes. Then, plug the unit back in, and switch on - the tray SHOULD then be taken back into the machine, the red light will flash, and the display should come on. As I say, mine has, so try it and I hope it works for you!
All the best (we'll beat these damn machines yet!)
Kev
Apr 16, 2009 | Pioneer PD-R509 CD Recorder
Bauchnecht GSF 5343 dishwasher
I used to work for Bauknecht years ago.
I dont remember that machine, but it could be an indication that your salt dispencer needs refilling.
May 04, 2008 | Dishwashers
The far left icon is red and the temp light green. I have taken everything apart and cleaned it. Now nothing happens, at first it would make the usual noises and nothing would happen.
sounds like a microswitch is out.
needs to be brought in for service. No easy way around it.
there's 3+ microswitches per unit depending on the model. They go out, red light comes on, nothing works.
Machine will have to be taken apart and all of them looked at one by one.
Apr 21, 2008 | Saeco Magic De Luxe Espresso Machine
Fellowes Manufacturing Powershred  4200CC (Cross-Cut) Shredder Logo
61 people viewed this question
Top Fellowes Manufacturing Office Equipment & Supplies Experts
Andrew Taylor
Andrew Taylor
 Bob Buchholz
Bob Buchholz
Are you a Fellowes Manufacturing Office Equipment and Supply Expert? Answer questions, earn points and help others
