Question about Boating
I have a SYLVAN boat and need the schematic for the coil and distributor.
2 Suggested Answers
captainjeffq
  • 52 Answers
SOURCE: need Wiring Schematic/Diagram for 89 Astro GT16 boat
In all honesty, its probably impossible to get the original wiring diagram. Also, I would be willing to bet that there has been alot of re-wiring and changes made to the wiring and electrical system of the boat. If you describe exactly what your trying to do, install fix or re-wire I may be able to better assist
Posted on Apr 14, 2009
I HAVE A 1990 16' NORTHWOODS, SYLVAN FISHING BOAT WITH A BUILT IN FUEL TANK. IS THERE A FUEL FILTER SOMEWHERE?...1990 EVINRUDE 40, 2 CYCLE
I think the only filter is on the motor itself there is check valve's in the primer hose, I think there might be a screen in tank but the one on the motor should pick up rust..The bad news is if it's
a older metal tank if left empty in winter there could be rust in the tank good luck might have to pull the tank and Im sure it's under the floor sorry...............
Sep 22, 2017 | Boating
I blew out a fuse on my Sylvan tritoon boat using the 12volt outlet to blow up a float. Where is the fuse and what type and size is it?
The fuse should be in the main 12volt supply to the panel where the outlet is located.. Mine are 3 amp.. using a air pump might take more amps.. see the paperwork with the pump, it will give you the amp draw.. be careful!
Jun 09, 2017 | Boating
WHERE IS THE HORN ON MY 19 FT SYLVAN PRO FISH
probably under the dash.(console)
Jun 04, 2014 | Boating
I have 1991 mpv v6 3.0 engine. It will not start. I changed the ignition coil and the igniter coil. what else could cause no spark?
Several things, actually. There could be no battery power at the distributor due to a blown fuse or a bad main relay. You could have a bad distributor cap, bad rotor, bad ignition cable between the coil and the distributor cap, a bad Engine Control Unit, a bad distributor pick-up coil, or any of the wiring in-between. (see schematic)
Aug 16, 2011 | Mazda MPV Cars & Trucks
I have a 1978 starcraft boat with a 470 mercruser in it or a 170 or 180 ford engine we have spark to the coil but not to the distribtor what is the point setting or what are we doing wrong
I am a bit reluctant to jump on this one as you have spark at the coil and not to the distributor. If you have spark at the coil... the points are working. It I don't want to sound like a wise arse here but it would appear the coil wire from coil to the distributor itself is bad.
However.... there could be other problems like a missing rotor in the distributor... or the carbon and spring have fallen out of the distributor cap internal center post.
The above seems to be the only thing that makes sense at the moment. Like I said the points have to be working to have spark at the coil.
Dwell should be 29 - 31 and the timing 8 - 10. I know at the moment it is impossible to check either.
You can set the point gap at .020 to start... then adjust dwell once you have figured out where the missing spark is.
Respond if you need more help but refrain from rating this post until we figure out what is causing your problem and have cured the no spark issue.
Kelly
Jun 22, 2010 | Boating
My boat Merc Cruiser V8 4brl, Thunderbolt IV 1978. Won't run well or idle, it back fires stutters and dies. This happens after it worms up. I rebuilt carb, cleaned out the old fuel, new fuel tank, Runs...
you need to replace your coil it is only about 15.00 it doe not sound like a fuel problem if the coil doesnt work you need to look at your cdi if you have the outdated box it will be mounted on the distributor it about a 1/4 inch thick 3 inches long and 2 inches wide with one flat plug going in it. before you do that change your plugsand wires wait im sorry i just saw the year of the boat now were getting somewhere you have a bad codenser if your boat has points under the distributor cap the condeser is the little siver cylinder while your in there you should just get a kit cap,rotor, button,points and condesor the points should be set at 25 to35 thousands i asume that 1978 is theyear modle if not like i said the new cdi box is out of date and very expensive $498.00 to be excact i would do a good tune up before turning to that but if it is a 1978 the distributor tune will fix your problem kit is about 70.00
Jun 27, 2009 | Boating
Boating Logo
168 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
