Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
DTV My tv Is digital. Do I still need something else to pick up digital broadcasts ? I need to enter a decimal point for some channels and cant do this with what I have
    President:
  • Hitachi Master
  • 1,779 Answers
Yes, you will need a HDTV converter box. Your set does not have a ATSC tuner that recieves HDTV signal. Your HD signal will be thru your Component Inputs on the rear jack panel along with audio IN.
Posted on Mar 08, 2009
Does this model have a digital tuner or do I need to have a box to watch televison over the air?
Yes this tv dose have a digital tuner inside of it,all flats LCD and Plasma tvs are Digital tvs they all can get free DTV air broadcasting tv channels.All digital flats LCD and Plasma tvs are DTV set u just require a very good like a roof Antenna or a newly Digital design portable Antenna connected the tv incomming air broastcasting signal cable back of to the flats screen tvs at the axail input call ANT.Then go into the tv menu.Goto setup go down pick AIR than press the enter button for scanning for free DTV air broadcasting channels.After the tv finish scanning for channels than the tv will let ur tv to get all the free DTV broadcasting channels.
Sep 29, 2011 | Olevia LT32HVE 32 in. LCD Television
Tried to use roof antenna on RV. My Sharp hdtv by passes the digital setup. How do I receive the over the air digital signal
Used the tv remote.Push the menu button.Now u are tv menu.Goto SETUP,go down to CH SETUP push enter on the tv remote.Pick AIR not Cable and push enter on the remote again.Now tv go in auto scanning.After it is done searching all cannels,ur tv will get all the free DTV air broadcasting channels.
Apr 17, 2011 | Sharp AQUOS LC-32GP1U 32 in. LCD HDTV
Cant get channel 11 when i hook my converter box to this tv is there a way i can i get regular tv without it
No,if this tv is an analog tv mean tv have a big back cover and have a heavy CRT-(tv tube).Must have a good antena like a digital antena or move antena around to left or right to pick up channel 11,might lost some other channels than.This tv now can't pick up digital signal now without the tv converter box if u want to pick up free DTV air broadcasting tv signal,it all broadcasting in DTV free air in all digital now.
Apr 14, 2011 | Apex Digital AT2402 24" TV
I have a Bravia TV and have lost Channel 7
Ur tv is hook up to a antena and getting free AIR DTV broadcasting signal?Yes,tv have lost channel 7 tunning in frequencies.Go into ur tv menu goto SETUP and pick EZ or Wizard scannning might get it back,not must go into Ch. pick AIR not Cable to rescan the whole thing for picking up all free AIR DTV channels again.If tv it is getting pay Cable do the same thing,pick CABLE for channels scanning not AIR.
Apr 07, 2011 | Sony Televison & Video
I need to know what steps need taken in order to update my Sony LCD Digital TV to accept the 1st phase of the Wow Cable digital channel conversion
U mean u want ur tv to getting a Free DTV AIR incomming broadcasting tv channels?Yes.U must have a good antena like a roof or a digital antena plug into the tv hole that said ANT.Go into tv menu goto SETUP go down CH. enter and pick AIR and then press enter again for scanning for Free AIR DTV incomming broadcasting tv channels.
Apr 04, 2011 | Sony BRAVIA KDL-40XBR3 40 in. LCD HDTV
Do you need a cable box for it
U mean a digital converter box for getting free broadcasting DTV airing channels?No,this tv it is a digital tv,just require a roof or a good digital antena.Hook it up with the antena and goto tv menu go to setup go down to Ch.pick AIR not CABLE and go into scanning for DTV channels after that tv will get all the free broadcasting DTV air channels.
Feb 17, 2011 | Toshiba 19HLV87 19 in. LCD HDTV
How to Chanel Scan
Tv is hook up to cable tv or free DTV air broadcasting?Have a good antenna source hook up or cable or satellite signals.Go into the tv menu go to SETUP.Go down to CH. press enter pick Cable or Air.Enter for scanning,after it done scanning will get all free DTV air or cable broadcasting channels stations signals.
Feb 08, 2011 | Polaroid TLA-04011C 40 in. LCD TV
Why won't my new Vizio DTV work on an antenna without the digital box?
Do you have the antenna aimed correctly and the correct antenna for the distance between your location and the stations? Check antennaweb.org and tvfool.com for the directions to the stations you should be able to receive. Antennaweb assumes an external antenna and is very conservative in the station list. TVfool gives the stations you should get with various different types of antennas. Tall trees and buildings will block signal strength so consider the environment around you.
With digital signals, if you do not have enough signal strength for a given tuner, the channel will not come in. An amplifier may help you get the signal, particularly if the signal is shared to several devices. Failure of an amplifier or lightning surge protection can stop the signal from reaching the TV. A surge through the antenna can damage the tuner.
A damaged cable can also be a source of a problem. Check the outside portion of the wire as well as the interior wires. Replace any that have damaged insulation or ends.
For this TV, if you have done a channel scan with the TV set to the Input TV/DTV, and the Signal Source set to Antenna. Turn the antenna and then set the Additional Scan to On. (Menu > TV > Channels > Additional Scan.) Then do another channel scan.
If you need a copy of the manual, see: http://www.vizio.com/m220va.html#support .
Jan 22, 2011 | Vizio M220VA 22 in. LCD HDTV
Tv tuner will ot detect digital signal in windows media center, vista
All US TV signals are now digital, but most TV tuners are like our old TVs - analog. Are you sure your tuner is a DTV tuner? If not, you will need to replace it or get a DTV converter. A DTV converter will not let your computer pick the channel and time though.
But one footnote. Broadcast digital TV is often not the same a cable digital TV. If you get a cable digital signal it is encrypted to the actual serial number of the receiving box. No broadcast DTV converter can do this. This is how the cable company now controls the number of receivers and one has to pay for EVERY set.
Apr 23, 2010 | Sony VGC-LT16E VAIO 22" All-in-One Desktop...
My VCR not recording after the switch to digital tv signal
The answer to this question can get a little complicated. Lets tackle it in two parts. First the last part; the part about picking up channels as decimals. With analog TV transmission, it took the full television broadcast channel to transmit one standard definition TV program. The newer digital transmission system uses some advanced video compression and audio compression technology to reduce the data needed to transmit the pictures and sound which allows the same bandwidth to deliver either High Definition Television programming or MULTIPLE channels of Standard Definition programs. So in your example above, you use to watch one channel of programming on TV channel 4, but now the TV station can broadcast multiple channels of programming on channel 4, sot they delineate the programs with a decimal point. So 4.1 it the first program on TV channel 4, 4.2 it the second program on TV channel 4..... Well, I hope you get the idea.
Now for the hard part of your question. I believe that before the transition, even with your new digital TV, you were still enjoying the analog broadcasts from your stations. Your VCR picked them up and recorded them and your digital TV could tune them in and you watched as you had always done in the past. After the transition you noticed that your VCR could not record anymore and your digital TV had discovered the digital channels that replace the analog channels. To remedy this situation, your VCR will need the aid of a DTV converter box to tune channels, and you may have to reconfigure the way your TV and VCR are connected. The best resource that I can give your for the reconnecting is the website http://www.fcc.gov/cgb/consumerfacts/converterbox_vcr.html. Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Scroll down to the Normal 0 false false false MicrosoftInternetExplorer4 section about “Set-up #2: Watch One Channel while Recording a Different Channel”.
Hope this helps
Jun 20, 2009 | Insignia Digital-to-Analog Converter for...
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
122 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
