Question about Mitsubishi VS-50603 50" Rear Projection Television
Locked up I locked my tv so that my kids could not watch. I've forgotten my 4 digit code and have tried all sorts of combinations to no avail. How do I unlock? Thanks for the advice
  • biggz2559 Mar 25, 2008
    tv is locked up
    Problem Solver:
  • 3 Answers
I have a VS 50607. My manual gives instructions that may work for your set. See the attached pic.locked up - 0fa93b0.jpg
Posted on Jan 03, 2008
SOURCE:
We've moved to Spain and have decided to use our safe but weve forgotten the combination, can you please help please
we dont sell safes but if you have registered you safe combination with the safe company then they may be able to assist you if not will need to notify a locksmith who is familiar with your type of safe
Jul 15, 2016 | Locks & Locksmithing
Tip
Lock Code, Pin Code & PUK code
Lock code: 1. 5 digits, Used to prevent unauthorized access to certain functions on the phone 2. Where: Tools > Settings > Security > Phone & SIM 3. Default: The default lock code for Nokia Series 60 devices is 12345. 4. Forgotten - If you've changed this code and forgotten it - you will need to visit a Nokia authorized service center, who will be able to reset the lock code for you. PIN code 1. 4 digits, an optional 4 digit code to protect your SIM 2. where: Tools > Settings > Security > Phone & SIM 3. Forgotten -If you keep trying, you'll eventually get locked out and need to contact your network operator for a PUK code PUK code 1. 8 digits, You'll be asked for this 8 digit code if you've entered the wrong SIM code more than the allowed number of times. You'll need to contact your network operator to get this lock lifted.
on Jul 30, 2007 | Nokia E61 Smartphone
Says code error
How To: Open A Locked Sentry Safe If You Forgot ...
? 5:21
https://www.youtube.com/watch?v=Mr8QrvVAtuI
Jul 15, 2014 - Uploaded by TipsNNTricks
I show you How To Open A Locked Sentry Safe If You ForgotThe Combination Or Loss Your Digital Code Or Lossed Your Key. The Sentry Safe ...
' Sentry® Safe ' Lost Your Combination
https://www.sentrysafe.com/.../Lost_Your_Combination
Sentry GroupCombo Recovery. What you'll need: Model Number; Safe Serial Number; Notarized Statement of Ownership. Step 1. Safe Info. Step 2. Notary Form. Step 3
opening a electronic safe forgotten the lock code ready to ...
www.instructables.com/.../OPENING-A-ELECTRONIC-SAF...
InstructablesJul 6, 2009 - I HAVE A SAFE GAURD COMPANIES SAFE I HAVE FORGOTTEN THE LOCK CODE TO OPEN IT. THEIR IS NO ALTERNATIVE OF KEY ...
How to Crack a Safe (with Pictures) - wikiHow
Jan 10, 2016 | Home Security
Need to know how to remove the red key on tv and code
When a red key appears in the lower left corner of your Apex television screen, the set's V-chip is engaged, preventing you from watching restricted content. You can override parental controls and reset your television's pass code with your remote.
Parental Lock
  1. The Apex prompts you to enter a 4-digit code when you set up parental controls. You can block programs according to their MPAA ratings or their content designations, such as V for violence or S for ****** situations.
Disabling the Lock
  1. You can override parental controls on most Apex models by simultaneously pressing the F and mute buttons on the remote control. If you own Apex models GT2011J or GT2011S, hold the remote's display button for ten seconds. The red key will vanish and the V-chip will unblock your program.
Override Codes Apex's default parental lock control code is 6688, so if you haven't set a new code, entering 6688 will remove the red key and unblock your program. If you've set a new password and forgotten it, entering 3308 will reset the code and unblock your program.
Sep 25, 2012 | Apex Digital Televison & Video
I have a new Nubbio piece of luggage with a TSA lock.I thought I set my combination but it does not work with my numbers and 000 doesn't work either?How do I open?
You can not reset your lock combination without knowing the original combination you had set.
If you have forgotten your lock combination, then there are 2 solutions.
1. You could use Bolt Cutters to break the Lock open.
2 . Sometimes, the simplest solution is often overlooked, as your lock is a 3 digit combination lock, and if you have about 30 minutes to spare, then why not try all the possible combination from 000 - 999 ( 000, 001, 002, 003 through to 999) You may think this will take a long time, but it should not take you more than 30 minutes and if the first digit of your forgotten code starts with a 0, 1, 2, or 3.. then it will take significantly less than 30 minutes. Try it out, as it will save you from having to buy a new lock if you use bolt cutters.
This is a helpful link that I can give you.
http://shop.heys.ca/help_answer.asp?ID=19
May 28, 2011 | Locks & Locksmithing
Forgotten password
Your tv is switched on and locked , blue screen and shows keys. A tv with activated child lock can only be unlocked after an 4-digit code is punched in.
Reset of child lock is as followed :
Determain chassisnumber type on type plate on the back of TV.
example: CUC xxxx ( xxxx = 4 digit number).
TV's CUC 6300, 6301 and 6310: bullet.gif Press cursors (blue arrows ) in sequence : Right, Left, Down , Up, followed by OK
TV's with chassis CUC 2003, 2005, 1805, 1825 t/m 1827, 1842, 1894, 1952, 1962, 1983, 1984, 1806, 1828, 1829, 1830, 1836, 1929, 2020, 2021, 2030, 2031, 2033, 2050, 2058, 2059:
bullet.gif Punch in universal code 7038 in. This code ends the child lock
TV's with Chassis CUC 1832, 1930, 1931:
bullet.gif Punch in universal code 7038580. This code ends the child lock Greetz and good luck, and PLS let me know if it works
Arni
Jun 13, 2008 | Televison & Video
Philips universal remote 4 digit codes
For combination tv/vcr the codes on the Phillips remote are 0039, 0739. I can only enter the channel I want to watch I can not use the up and down arrows for some reason.
sb2141
Jan 21, 2008 | Quasar VV2009 Combo
Televison & Video Logo
165 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
