Question about Ovens
F7 fault code on the Jenn-air W30400W
I was awaken in the midlle of the night by an alarm tone. hit cancel/off it quit and restarted beeping. after 4 or5 tries turned off circuit breaker.
what does the F7 fault code mean?
  • 15,935 Answers
F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC)
F7 Function key shorted or stuck button.
1. Replace touch pad or clock assembly (also called the ERC)
2. Attempt to free stuck button.
Most likely the key pad. If you called me to come service your unit, I would gain access to the control panel and then remove the touchpad ribbon connector from the control and then restore power. Wait 24 hours and see if the code reappears
Thanks for using FixYa - a FixYa rating is appreciated for my effort in answering your FREE question.
Posted on Mar 04, 2009
    Genius:
  • 1,550 Answers
The F7 error code on your oven indicates the touch pad has failed. To repair it you will need to replace the touch pad which is listed as a control panel w/keypad in the parts diagram.
If you do the repair yourself, disconnect the power to the oven. Take the 3 screws out above the door that hold the control panel on to the oven. Pull the control panel out at the bottom and lift it up, then pull out the top and drop it down so you can see the back side of the control panel, and you will see a ribbon connector going from the touchpad to the electronic oven control (ERC).
There is a latch holding the ribbon connector to the ERC, raise the latch to release and pull the ribbon out of the ERC.
Replace the part and reverse these instructions to replace the control panel.
Hope this helps .
Why won't it operate?
Hi Pam, Is this not covered in the user manual? Additionally search online by "error code f7 f1" and see what hits you get.
Jul 10, 2015 | Jenn-Air JJW9630C Expressions Collection...
Beeping
Here is what the fault code means:
F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button
I hope that this helps for you
Apr 20, 2009 | Jenn-Air Ovens
My oven wont quit beeping!
if it is an E0-F2 error code then i believe it is for a bad control or keypad.. i would replace both.
Feb 13, 2009 | Ovens
Beeping and F7 when cleaning
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jan 07, 2009 | Jenn-Air JJW8230D Electric Double Oven
It depends on the actual model number (that you didn't supply), but most Kenmore F7 errors indicate a bad keypad or bad control panel. If you unplug the ribbon cable from the keypad to the panel then plug the oven back in and it starts beeping again, it's a bad control panel, if it doesn't beep anymore, it's a bad keypad.
Please unplug the oven power with working on it.
Geno
Aug 02, 2008 | Ovens
Jenn-Air WW30430W double oven flashing F7 and beeping
It seems you have a stuck button. Here is a list of fault codes:
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Dec 09, 2007 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
887 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you an Oven Expert? Answer questions, earn points and help others
