Question about Garmin eTrex Legend Cx GPS Receiver
Etrex legend has stopped picking up satalites.
Etrex legend has stopped picking up satellites. Batteries good & all else seems to be working as usual.
  • 74 Answers
I have had this problem occasionally and if you use Restore Defaults it appears to fix it. Using the front button go to Main Menu, Setup, System, move left and press the button button. Before I did this I just used to leave it a few weeks and it would suddenly be working again.
HTH
Peter
Posted on Mar 07, 2009
My etrex worked properly up to a month. Satellite catching don't works any more. I verify that GPS is NOT Off and I also ...Idon_t find the solution Thanks
Ensure that you have fresh batteries and a clear view of the sky. Turn the Legend on, Click the top right hand button until you see the main menu, go to setup and select system. Under GPS ensure it is set to Normal. Then click the top right button again till you see satellite, click the single square near the top right, and select new location (you may not be in a new location, but this forces the GPS receiver to check for satellites regardless of what it may have seen last time, as the satellite configurations will now be out of date.) Leave your GPS in a safe place outside for up to 30 minutes till it acquires satellites. If that fails this gives some more solutions http://www.fixya.com/support/t139887-garmin_etrex_legend
If it is now working, ensure you have a clear view of the sky when you attempt a reading, and don't use battery saver unless you have good reception (which means it is a good idea to have spare batteries on hand!)
Jan 20, 2011 | Garmin eTrex Legend GPS Receiver
Vista etrex cx will not acquire satellites . It worked okay the last time I used it.It then says poor reception .Use with GPs off. Its a clear day and was yesteday when i tried to use it. There seems no...
My Etrex Legend would not aquire satellites and after several call to tech support, I finally reset the whole unit. First I saved the waypoints on Mapsource. Then with the unit off press and hold the page button (upper right) then push the rocker button in and then push the power button. Once it starts you can then release all the buttons and set the unit outside for about 20 minutes.
May 22, 2010 | Garmin eTrex Vista Cx GPS Receiver
Have a Garmin Etrex LEgend and there is nothing showing in the display- I have changed the batteries, but there is still no picture. Any suggestions?
Try updating the unit's internal software and drivers. A new satellite was launched which caused problems and the updates solve this. Let us know if this solution solves your problem, and please rate our answer. Thanks.
Feb 18, 2010 | Garmin eTrex Legend GPS Receiver
GPS won't pick up satellite reception.
Let's assume the unit is in good conditions. When you travel for more than 500 Kms the unit need more time to acquire the satellites, so the solution is to keep the unit on in a uncovered area for about 15 minutes.
Regards
Osiris
Aug 11, 2009 | Garmin eTrex Legend GPS Receiver
My garmin etrex legend Cx wasn't used for a few months and now won't aquire satellites. Batteries have been changed to no avail.
Go to the Garmin.com website and download updated drivers/software for the unit. Make sure the drivers are for your specific unit as they are all different.
Jul 04, 2009 | Garmin eTrex Legend GPS Receiver
ETREX LEGEND HAS 1 VERTICAL LINE ON SCREEN AND WONT SHUT OFF UNLESS YOU PULL BATTERYS
Have you updated your unit's software from the Garmin site? There was a new satellite launched in 2008 which has been causing problems, and the new update fixes this.
Mar 03, 2009 | Garmin eTrex Legend GPS Receiver
Screen appears to freeze up
Try updating the unit software. A new satellite was launched this year and has been causing problems. The updates from Garmin fix it. Disable the WAAS in the meantime and see if that solves the problem in the meantime.
Dec 06, 2008 | Garmin eTrex Legend GPS Receiver
Garmin Etrex Legend Cx - no signal
Have you tried upgrading the unit's software. Go to Garmin.com and download the latest software for your unit. This will sometimes fix satellite reception problems.
Sep 28, 2008 | Garmin eTrex Legend GPS Receiver
Garmin etrex legend
I had this problem today, updated the software, now the unit seems to be working perfectly. The unit "crashes" (single line down screen center) as soon as it get enough satelites to work with WAAS.
Go to Garmin site for software updates. Download and install the WebUpdater. Once or unit is hooked up to your computer and you have internet access, the software will download and update your GPS with the latest software fixes. I had software Version 3.7. For the Legend, Version 3.9 fixes the problems with WAAS.
Jan 04, 2008 | Garmin eTrex Legend GPS Receiver
Garmin eTrex Legend
Do the following: 1 - Make sure you have fresh batteries in the unit and turn the unit on. 2 - Check the GPS date and Time. On the Main Menu at the bottom of the screen, you can see a date and time. If the date and time are not current, then the clock is your problem. You will have to wait for the almanac information to be updated. Details are below in a later section. 3 - Make sure your GPS is in the Normal Mode and not a demo mode. Verify other systems settings. Go to the main menu and click on Setup icon. From the Setup screen, access the System screen icon. Verify the following settings: GPS: normal WAAS: Enabled Language: English or your choice. Battery: Set according to your battery types. 4 - Check your GPSs Version Software. Go to the main menu and click on Setup icon. From the Setup screen, access the System screen icon. From the System screen, access the sub-menu icon in the upper right bar. Select "Software Version" from the list. Verify the actual software version for me. The latest version available for the eTrex Legend is version 3.90 dated March 2008. http://www8.garmin.com/support/download_details.jsp?id=711 Update the unit using this latest software and using Garmin's Webupdater. http://www8.garmin.com/products/webupdater/howtoinstall.jsp If that won't work, use the following download page to access the latest software updates per units. http://www8.garmin.com/support/blosp.jsp 5 - Resetting your GPS clock and almanac information Next you may need to acclimate your unit to a new date and time (almanac information). If you had your unit off and without batteries for over a month since you last accessed satellites, then your clock and almanac information may be incorrect. Even Garmin acknowledges this problem after software updates and the problem with accessing satellites. They state: "unit data including alamanac information may be incorrect or cleared. Back up all user data before upgrading. After installation is complete, place unit with a clear view of the sky for 15-30 minutes to re-acquire almanac data. " I know of no way to reset the clock using the GPS menus. All I can suggest is that you do the following: A - turn the unit on and wait 5 minutes or so for the "Poor Satellite Reception" screen to appear. See page 7 of the owner's manual. B - Set the "new location" to your area using the map when the "poor satellite reception screen" appears. Be sure to use the "map" option and not the "automatic". C - Set the GPS outside with a clear view of the sky. Check on it every 10 minutes. When the "Poor Satellite Reception" screen appears again, then click on "Restart Search". The "Restart Search" option is used when the date provided in the GPS is not today's date. (See page 7 of the Owner's manual for an example) Legend Owners Manual: http://www8.garmin.com/manuals/eTrexLegend_OwnersManual.pdf D - Once the GPS can track 4 satellites, then the clock should reset and you should be fine. This process could take up to an hour. I have had this problem with my eTrex Vista and eTrex Legend (both backup GPSs) and resolved it by having the clock reset. In fact, I just tried my eTrex Legend today after not using it for many months and storing it without batteries and it had this same problem. I followed the steps above to fix the problem. This took about 35 minutes.
Mar 28, 2007 | Garmin eTrex Legend GPS Receiver
Garmin eTrex Legend Cx GPS Receiver Logo
224 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
