Question about Maytag Atlantis MAV7000
MAV7000 clicking sounds in all cycles. sounds like a fan blade hitting an obstruction. noise volume decreases a bit when spin cycle occurs sounding like gravel. Spin locked up once. Strange metallic odor as well.
  • 58 Answers
Sounds like there is an obstruction striking or rubbing against the impeller in the drain pump assy. It will require removing the front cover/ Drive belt from the bottom of unit/ Hoses from drain pump (be prepared for the water) a 3/8" socket to remove the pump & a needlenose plier to remove the obstruction... Hope this helps....Bill
Posted on May 18, 2009
In winter the outside unit sounds like a rubbing/ticking noise
Sounds like ice coming of the coil. That would explain the ticking. The rubbing could be ice buildup before the defrost cycle or it's building on the blades of the fan throwing it of balance a bit.
Feb 13, 2015 | Fujitsu Halcyon ASU12RMLQ Mini Split Wall...
Whirlpool cabrio (4yr.old) making loud motor straining noise on final spin cycle.
Hi valued Consumer, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Valued Consumer), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 24, 2017 | Whirlpool WTW6400SW Cabrio Washer
When my washer is in the wash cycle, it makes a loud clicking noise. It sounds like a maybe a gear is skipping through some teeth. It is loud and at a regular interval, although the rate at which the noise...
its most likely a bra wire caught in there as the bowl spins around it is hitting the plastic tank therefore making the clicking sound. its super hard to get em out and if it has put a hole in the plastic tank its really expensive to fix call your appliance service asap to have one of them take a look. this is a very common problem from a front load washing machine
Jan 09, 2011 | Maytag Neptune MAH5500B Front Load Washer
Makes growling noises throughout the cycle.
HI. here are the most common issues that will cause a noise during the wash.
* Check the spray arm for damage and obstructions
* Check the inlet filter screens
* Test the water inlet valve(see below for test procedure)
* Check the motor and mounts- The motor may e loose or one of the mounts may have separated form the housing. this will cause mis-alignment.
* Check the fan motor and blade
* Check the drain for obstructions
NOTE
If all checks out above, the culprit will be a cracked pump impeller. this will occur if the drive stud becomes unstable, allowing the impeller to partially separate form the motor spin drive stud. this will cause the impeller to rub or grind during the wash cycle. If this is the case, there are impeller repair kits available for purchase that will correct this issue.
Sep 25, 2009 | GE Dishwashers
Refrig does not cycle - freezer unit ices
Sounds like you have a defrost control board problem too if your freezer is icing up. The thermostat is what causes your refrigereator to cycle on and off - most common causes is indeed a faulty themostat. On refrigerators with electronic controls, you may have a faulty motherboard. On those with a dial knob with numbers, try slowly turning down the knob so you decrease the numbers. example, if you ahve it set to 5 decrease it slowly to 4....3..etc You should hear a "CLICK" that cycles off your compressor, evap & condenser fans - you may have the dial set too high. If however you go all the way down and it doesn't cycle off unless you completly turn it off to 0, you have a faulty thermostat - if it does cycle off at a very low setting, say 1, your therm is out of calirbation - you would need to change the unit. Make sure the sensor is not obstructed with dirt or foreign objects, if it is obstructed your thermostat will be fooled and think your fridge is not cooling and always stay on. If setting the knob to a lower value, cleaning / removing foreign objects or obstructions does not help you will need service - have them check the thermostat / control board and defrost timers while at it - there should not be frost build up in your refrigerator.
good luck
Aug 22, 2009 | Amana Refrigerators
Will not start wash cycle
Sound like the lid switch has went out , you should hear it click when the lid is close to an inch of being closed , they are un-expensive and easy to replace and they go out often from use. Easy to find online with your real model number located under the lid.
Phil
The washer with the grind noise is a main bearing going out and may be covered under warr. through maytag.
Apr 11, 2009 | Maytag Atlantis MAV7000
Load squeal when it in the agitation cycle.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
for detailed help with diagrams and step by step instructions click the link http://www.applianceaid.com/washerspinnoise.html
Dec 29, 2008 | Admiral AW22 Top Load Washer
Noisy Spin Cycle
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
Jun 12, 2008 | Whirlpool LSR9434PQ Top Load Washer
Loud Buzzing noise
Sounds like the fan is hitting some ice build-up. If you can access the area of the fan motor you can try a hair dryer to defrost the ice out of it.
Apr 15, 2008 | Frigidaire FRS23R4A Side by Side...
LG Fridge making intermittent sound - like something hitting fan
GAIN ACCESS TO THE FAN IN THE FREEZER(EASIER SAID THAN DONE) AND INSPECT THE FAN BLADE AND FAN SHROUD. HAVE REFRIGERATOR TURNED OFF AND MANUALLY ADVANCE FAN BLADE. WATCH FOR SLIGHT CONTACT BETWEEN THE FAN BLADE AND OTHER OBJECTS NEAR IT-ELECTRICAL WIRING, FAN SHROUD, ICE CYCLE,ETC. ADJUST FAN BLADE OR OBJECT TO INCREASE CLEARANCE.
Mar 27, 2008 | Refrigerators
Washing Machines Logo
101 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
