Question about Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine
Wont to put the cable back on that makes the blade turn
Mower blades won't engage
Did the smoking stop when you disengaged the blades? If so it is most likely your belt that is smoking. Make sure all the blades turn freely by hand to ensure you have not hit anything that may have bent a shaft on one of the blades. If one of the shafts is bent and wont turn FREELY, the belt driving the blades would slip and start smoking as it tried to turn them.
Apr 19, 2015 | Garden
How do you change blades on 5ft bush hog?
lift The brush hog up and place on blocks or other foundation that wont fall over. disconnect the power take off shaft from the tractor. Now look for two round openings in the middle of the deck one on ether side of the gear box (the thing on the brush hog that the pto shaft from the tractor hooks up to to make it spin there might be a slip clutch on the shaft but go to the box in the middle) Now turn the shaft till you see the blade nuts in the hole These could be castle nuts with a small carter pin locking them so they don't unscrew. Remove the pin and with a large socket set unscrew it from the bolt then knock the press fit bolt down and the blade will come off, do the same to the other blade if you need them both off. To put them back on use something under the blade and bolt to hold it up so you can start the nut then reverse the order and put everything back on. The blade bolt might be stubborn to get out just take something that fits through the access hole like a wood doll or long punch and drive the bolt down till it comes out as it is press fit and is jammed up to keep the bolt from turning, when putting it back on you will need to make it tight so the bolt can repress back in. Be Careful when reaching under to set the blade and bolt back in. There is not much you can mess up it is just a big nut and bolt Just make sure you put the blade on the way it came off if you do one blade or one at a time you can look at the other to see which way it goes.
Oct 02, 2014 | King Kutter Rotary Tiller Pto Bush Hog...
Mower blades wont turn while sitting but turn when you stand up
I think you have a switch under the seat, which is malfunctioning
Mar 24, 2013 | John Deere 22HP VTwin 48" Riding Mower
Ninja blender blade wont turn with food in container.
make sure blade is pressed tightly onto shaft... should click into indent. if not then you need a new blade piece.- stripped
Aug 18, 2012 | Blenders
How to put together the blade
askmanny.jpg Instruction to assemble a clipper blade.Above picture Socket askmanny_0.jpg
Turn Socket & Spring Tension over Make sure Socket is slide back askmanny_4.jpg
This is Call a Blade Guide Make sure the blade Guide is on the Spring Tension askmanny_5.jpg
Make sure blade guide is on like picture above, Now place Socket & Spring aside askmanny_6.jpg
Place cutter blade as picture above, making sure cutter blade smaller blade is on the comb blade Rail. askmanny_9.jpg
Hold the blade like this Finger on top and Thumb on the bottom askmanny_10.jpg
Turn blade over like this while still holding the blade together askmanny_11.jpg
Now that you have the 2 screw in and not tight place the blade like this You need to hold the blade with one hand and with your Philips screw driver tap the cutter blade back lightly until the cutter teeth are 2/32 back from the comb blade. askmanny_14.jpg
the cutter blade which is the smaller blade is back 2/32 from the comb blade which is the bigger blade. When this is done by holding the blade together with your finger & Thumb askmanny_15.jpg
We hope this was helpful when assembling a clipper blade.
May 11, 2011 | Andis AG 2 Hair Trimmer
I have a used Cub Cadet Model #144-664-100 that I purchased last year and used half of the summer and ran great but towards the end it wasn't cutting very cleanly. So I took off a mower blade, which was...
Have you tried running it with the blade back on? It may be ok as there is a braking system built into the pto clutch that makes the blades hard to turn by hand. Regards Phil
Apr 15, 2011 | Cub Cadet Lawn Mower Deck Drive Belt...
The piece under the blades cracked can it be replaced with out buying the whol blender
You can try removing the blades and put apoxy in the crack and let it dry. Put the blade back on and make sure the blade does not rub by turning the blade by hand to see if it turns smoothly. Do all of this while the blender is unplugged.
Mar 11, 2011 | Vacuums
I tried to clean the blades but now it wont cut and also it sounds tremendously loud
are all the screws tight? Sometimes my screws on my blades come loose and I can't tell until all of a sudden they fall apart in a clients hair
Jul 18, 2008 | Oster 76076-010 Hair Trimmer
After cleaning the unit, blue light turns on momentarily then red cleaning light comes back on. Have cleaned and dried unit including the contacts on the end (cleaned with alcohol). Sounds like a common problem, any solution?
Jun 17, 2008 | Ionic Pro 901P2RIP04 Air Purifier
Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine Logo
129 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
