Question about Apple iPod nano
IPod entry code forgotten.. The iPod cannot be accesed because of the entry code
How to reset my combination lock number on ipod A1236
Hi William
If you have forgotten the code or put the wrong code in your ipod, you can unlock the Ipod by doing the following:
Connect your IPod to the primary computer you use it with (the first one Ipod synced with), and open iTunes.
When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock Ipod using either (the code or connecting it to the computer you use to manage its songs). . . you can restore your ipod to factory settings using ipod Updater.
Please note that this will erase all data on your ipod.
Afterwards, you can add your music and data back to your ipod.
If you want to change the primary computer that your Ipod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone.
All of your songs and files will be deleted.
Always make a backup of your important data.
2. Connect your ipod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
If you can't unlock your ipod and you don't have access to the primary computer, your only option is to restore the Ipod, which will erase all music and data.
Please take time to rate me
Bud
Apr 03, 2013 | Audio Players & Recorders
I missed my password and forgotten some of my information
Hi abkrarosm...
If you have forgotten the code, you can unlock the IPod by doing the following:
Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes.
If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod.
Afterwards, you can add your music and data back to your iPod.
If you want to change the primary computer that your IPod is associated with, do this:
All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data."
Sep 04, 2011 | Apple iPod touch
Hi i am having the same problem. i seem to have forgotten the unlock code to my ipod model a1320 emc2317
Hi nalotita47...
According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following:
Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data."
For this FREE answer, Please rate me
Apr 26, 2011 | Apple iPod nano
Can you unlock my ipod
with, do this:
Please rate me...
Aug 22, 2010 | Apple iPod nano MP3 Player
How to unlock forgotten combination lock for ipod nano 4gb
if you have forgotten your code that is not a problem. Follow the steps that i have outlined below. If this does not completely help your situation please let me know and i will be glad to assist you from here. According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following: 1 If you can't unlock IPod using either [the code or connecting it to the computer you use to manage
its songs. . . Plug the iPod USB cable into the bottom of the iPod Nano. 2 Plug the other end of the iPod USB cable into a free USB port on a Mac or PC computer. 3 Open the iTunes application by clicking on the Dock icon on a Mac or using the Start menu on a PC. 4 Click on the name of your iPod Nano under the "Devices" list in the iTunes window. 5 Click on the "Sync" button to establish a connection between your iPod and the computer. 6 Click on the eject symbol next to your iPod's name after the syncing process has finished. 7 Unplug your iPod Nano. The device will be unlocked and you will be able to access all normal features again. if that does not work you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your IPod is associated with, do this: 1. Restore your iPod. WARNING: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize. Apple also notes that company "representatives cannot unlock an iPod if you forget your combination.
If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data." If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the comment. thanks and have a great day.
May 26, 2010 | Apple iPod nano
Passcode forgotten, how can I open my ipod to reset the passcode?
Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked.
to your iPod.
Warning: The restore process cannot be undone.
computer.
Good Luck, I hope this helps
Please do not forget to rate me...Thank You
May 18, 2010 | Apple iPod touch
I cant unlock my ipod
if you have forgotten the code to unlock that is not a problem. if you have forgotten your code that is not a problem. Follow the steps that i have outlined below. If this does not completely help your situation please let me know and i will be glad to assist you from here. According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following: 1 If you can't unlock IPod using either [the code or connecting it to the computer you use to manage
Nov 04, 2009 | Apple iPod nano
Restriction code on Ipod Touch forgotten
Use the Five Rs to restore the iPod. You will lose the data that is currently on it if you restore but you can always re-sync the data to the iPod. http://www.apple.com/support/ipod/five_rs/
-=/ Daft Tech /=-
Oct 24, 2009 | Apple iPod touch
Unlock my ipod please!
In the device folder rename the file '' _locked '' by '' _unlocked '' then disconnect the ipod safely with the windows option in the task bar then unplog the ipod and your ipod should be unlocked Good luck
Jun 19, 2009 | Apple iPod nano
My 8GB ipod touch is disabled and showing connect to itunes
Hopefully the option wasnt selected to delete the ipod after a certain number of incorrect passcode entries.
When you connect your ipod to itunes its going to reformat it.
(meaning it gets erased, they do it as a precaution)
DONT FORGET THE CODE NEXT TIME!
Jan 04, 2009 | Apple iPod touch
Apple iPod nano Logo
62 people viewed this question
Top Apple Audio Players & Recorders Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
mac colar
Sean Cole
Sean Cole
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
