Question about Acer NSK8458AN Keyboard
The question mark will not show how do I get
The question mark will not show how do I get it to come up.what keys do i touch
  • 2 more comments
  • Anonymous Mar 04, 2009
    Yes, I have the same problem. When I type the question mark it shows as ééé and if I hold the shift key it shows ééééé
  • Anonymous Mar 12, 2009
    mee too
  • bluegardenia Apr 02, 2009
    the solution provided doesn't work for me....
    problem: using either the apostrophe key and the question mark key will produce the letter 'e' with accent mark on top if you use shift key it will produce a capital E....only seems to happen when i'm composing an email...couldn't get it to happen here.
  • 7studhom Apr 12, 2009
    when you hit the shfit key and hit the key with the question mark on it, you get what the origional post says...you get an E with an accent on it. Smart ***.
  • Acer Master
  • 4,806 Answers
Hi there
Hold down the shift key and hit the key with the ? on it
Good luck and thanks for using FixYa!!
Posted on Mar 04, 2009
Touch screen
After clearing the memory,or if the touch panel detection function is not working correctly,follow this procedure to calibrate the touch screen.Press the yellow reset key ,press 1993 and press red stop key 5 times to open the self diagnostics menu.On the touch screen press Touch Screen Adjust.Use a pointed tool to press the upper left mark.Press the lower right mark after it appears.Touch a few spots on the touch pannel to confirm that the marker appears exactly where the screen is touched.When you are finished press OK on the scree,touch Exit on the screen to close the self diagnostic menu and save the calibration settings.
Dec 30, 2013 | Ricoh Office Equipment & Supplies
Hi ,i purchased my dell inspiron laptop recently.2 days onwards,touch pad is not working.could you please help me?
My dear friend this will usually be a problem with the function keys, you might have de-activated the touch pad. Try to check in the function keys and you may find a key with marking of touch pad usually it would be F4 so to activate it you need to Hold Fn+F4 key and try. It will sure work well and this is not a problem with the machine.
DONT FORGET TO RATE MY SOLUTION DEAR
Jun 27, 2011 | Dell F3534 Touchpad
Touch screen working but it's not recognizing finger to chang
You need to calibrate the touch screen.
Try this:
Press Yellow key
On the key pad Press 1-9-9-3.
Press 5 times the red key (the 5th old a little longer)
(If everything is good in the touch screen shows an option "calibrate touch screen")
Try to touch there and will show a little arrow on each corner. With a pen click there to calibrate the touch screen.
Click exit and its done
Mar 08, 2011 | Ricoh Aficio 3025P Black and White Copier
Showing 6ae on my Tissot T touch. Also cannot synch properly
Press the center button marked "T". The watch should beep once;- Touch the center of the touch-sensitive face until 24H Cm appears in the digital LCD display;
- Press and hold the center button marked "T" for approx. 5 seconds. The watch will beep once and then again a second time, after 5 seconds have passed. The digital LCD display should now read SYNCHRO;
- Press the upper button marked "+" to move the minute hand until it is positioned exactly at 12:00;
- Press the lower button marked "-" to move the hour hand until it is also positioned exactly at 12:00;
- When both hands are aligned together and pointing directly at 12:00, press the center button marked "T" to save your settings.
- Your watch is now synchronized, so no expensive repair work is required!
Jan 24, 2011 | Tissot T-Touch T33759851
Unit seems to work fine, but don't know how to get Qwerty keyboard up. When I follow Tools to System to Qwety, screen does not show the keyboard. Also I have not heard any voice out of this thing. How...
all this is in the tool box, my wife just gave me this same GPS for Christmas
Ok turn it on, touch the "Wrench" symbol, in the next screen there is another "Wrench" symbol touch that, in the next screen touch the gear symbol marked "System" in the next window it will say "Key Board layout" touch that the next screen shows "ABCDE" AND "QWERTY" select Qwerty and then touch OK. any other questions call me 925-577-7157
As far as the voice goes inb the same window as the System select the "LIP" symbolt in the next window u will see "VOICE" select tha and then select this setting "American English-Samantha (TTS)" this will enable the voice that speaks road names and streets.
Dec 31, 2009 | Garmin nuvi 255W GPS Receiver
Need to find heater fuse
Fuses are on the left side of the dash. Open your driver's door to access them. Should be marked on the lid for which is which. If not, use a test light. Turn the key on, and then touch each side of the fuse with the test light. Just touch on the silver metal part that shows through the back of the fuse on either side of the amp number. If the light lights on both sides, the fuse is good. Just one side... replace.
Oct 31, 2009 | 1996 Chevrolet S-10 Pickup
I have an ipod touch that I am trying to connect to my qwest wireless internet. I have entered the WEP key and it shows that I am connected but when I attempt to open Safari it says that it can't find the...
  1. Turn on your iPod.
  2. If not at the home screen, press home button.
  3. Tap settings button.
  4. Tap wi-fi.
  5. If broadcasting your ssid, choose from the 'choose a network' list.
  6. If not broadcasting your ssid choose "other" under 'choose a network'.
  7. Under 'name' type your ssid.
  8. Tap 'security' if you are using security and select your security type.
  9. Tap the 'other network' button to get back to network setting.
  10. Type in your security password, which is your key in your wireless network setting. Important *you must use key 1* in wireless setting.
  11. Click 'join' after you have typed in your security password.
  12. Your network name (ssid) should show in 'choose a network' with a check mark next to it.
  • Use security with your wi-fi connection.
  • Use the first key password in your wireless network setup screen, key 2, 3, and 4 will cause the iPod touch to not connect even if the password is correct.
Sep 24, 2009 | NetGear DG834G Router
I want to turn off my touch mouse on my laptap keybord.
there is a key on your laptop keyboard marked "Fn". and u will see a blue color like touch pad marked key in the top of or keyboard. press Fn key and this marked key simulaniously.mean both key should be pressed at a time. u can do it by pressng Fn key and that marked key generly f3 or f7 depends on manufacturer.
Aug 23, 2009 | Computers & Internet
Touch pad
Usually you have a shortcut key by pressing the Fn key with the touchpad key. It is marked on the keyboard as two touchpads. One is crossed by a bar.
Dec 30, 2008 | Toshiba Satellite A40-S161 Notebook
Acer NSK8458AN Keyboard Logo
222 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
