Relay switch goes on and off. Fan is running. Not cooling
When A/C is requested and the ambient temperature is more than 10?°C (50?°F).
A/C refrigerant pressure exceeds 1310 kPa (190 psi).
After the vehicle is shut off if the engine coolant temperature at key-off is more than 117?°C (243?°F) and system voltage is more than 12 volts. The fans will stay on for approximately 3 minutes.
The engine cooling fan system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the PCM to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the engine wiring harness junction block. The ground path is provided at G101.
During low speed operation, the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the FAN CONT #1 relay coil, closes the relay contacts, and supplies battery positive voltage from the FAN CONT #1 fuse through the cooling fan motor supply voltage circuit to the right cooling fan. The ground path for the right cooling fan is through the FAN CONT #2 relay and the left cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the PCM supplies the ground path for the FAN CONT #1 relay through the low speed cooling fan relay control circuit. After a 3-second delay, the PCM supplies a ground path for the FAN CONT #2 relay and the FAN CONT #3 relay through the high speed cooling fan relay control circuit. This energizes the FAN CONT #2 relay coil, closes the relay contacts, and provides a ground path for the right cooling fan. At the same time the FAN CONT #3 relay coil is energized closing the relay contacts and provides battery positive voltage from the FAN CONT #2 fuse on the cooling fan motor supply voltage circuit to the left cooling fan. During high speed fan operation, both engine cooling fans have there own ground path. The result is a parallel circuit with both fans running at high speed.
Is your vehicles check engine light lit ?
Is the
