Question about HP w1907 LCD Monitor
The Volume Screen on my monitor keeps popping up
I have a HP w1907 monitor. The volume from the monitor keeps popping up not sure why. It happens about every minute. It pops up stays on for about 30 seconds.
  • Anonymous Mar 04, 2009
    Same problem - just occured last night
  • Anonymous Mar 30, 2014
    The volume icon appears in the middle of the monitor screen and I can't remove it.
    Problem Solver:
  • 10 Answers
Try putting pressure on the monitor near the buttons. There might be a short or some type of stress pressing the buttons.
Posted on Mar 24, 2009
Monitor will cycle through the menu screen every few seconds after being turned on.
the menu button is stuck,use a sharp knife to pry the button out very lightly,not all the way out,just enough to make sure that it isnt stuck,if it still happens then the board for the menu button needs to be replaced
May 27, 2015 | HP w1907 LCD Monitor
My Hp w1907 is doing crazy things. First of all it won't stay on. I have to keep turning it on and off to get the screen to stay on, and now the menu keeps poping up and doing things like turning the...
Aww ****. I thought this had a solution but it didnt. Almost the same thing is happening to me. besides the menu thing. It keeps turning on and off. and this is right after my warranty ran out. I think HP is trying to **** us .-.
Sep 17, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
Volume screen keeps popping up every few seconds, when I touch "menu" button it goes away, only to come back a few seconds later
michaelfoder, Because very strange things start to appear on the screens of cold cathode fluorescent lamp, back-lit, LCD monitors, I always investigate the "switch-mode-power-supply/ccfl inverter supply for very common occuring defects in the supply!!! You can find out about them here: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Just remember to do a fixya rating and testimonial if this response helps you to find and correct problem in your 2-3year old unit. Problem could be an unstable +5v or +3.3v dc supply rail. 12fixlouie
Aug 16, 2010 | HP w1907 LCD Monitor
Volume window stuck on screen
My HP w2408 monitor. I just fixed this issue about 5 mins ago after getting tierd of whacking the buttons with anything handy. There are 2 slots on the underside of the monitor, in between the black frame and silver outer frame. Stick a flat screw driver and use a motion as if to literally pull the black frame away from the monitor. Use caution and dont stick the screw driver too far in. You will hear it pop. Do the same to the other side. There are multiple tabs arond the frame including one in the bottom center. Keep pulling on the free ends of the frame till all the tabs come off. Now you will see the buttom assembly, disconnect the small white connector from the montior. If you dont care for the buttons, which if you have a w2408 or any such model you will never use (auto detects input and auto adjusts) then just pop the frame back on. If you want to go further remove the 2 screws on the button assembly pull down on the silver frame to remove the button assembly. I did not go further then this but i read somewhere that if you wash the assembly in some liquid it will work again. I am guessing some good acohol from walgreens will do. For me I am just glad the message when away.
Keep fixing and keep sharing! Corporations that sell to the masses will show respect only when the masses unite.
Jul 27, 2010 | HP w1907 LCD Monitor
Menu buttons
Jul 26, 2010 | HP w1907 LCD Monitor
OSD Lockout and Volume pop up
my monitor always fading into sleep mode or some thing,on & off etc..
Jun 23, 2010 | HP w1907 LCD Monitor
My volume menu from monitor pops up, volume auto-decreases
Was something spilled on the volume key? Sounds like it is stuck... you can use a fine toothpick and plain water to "scrub" around the key, there may be some buildup that inhitbits the key from "unpressing".
Hope this helps!
-- RT
Sep 02, 2009 | HP w2207 Monitor
Volume pop up in the middle of my screen
no photos of said window presented? i cant see them?
must be OSD? the monitor brain on screen display (menu)?
even with the DVI cable pulled?
only a monitor stated, w1907, no PC
some monitors have button lock
read the manual ?oops HP deleted it...
it tells you to push the menu key on the monitor for 10 seconds
and it unlocks. (4 buttons right side left button is MENU)
doom?
that power deal sounds super bad, like the power supply is bad.
if the monitor fails by its self not plugged it to a PC
then the monitors is bad.
try a reset on it? ( power off for 1hr, or off then plug in with power button held? or power on with menu held (wild guesses but common practice)
ok found your manual page 4-8 shows menu page advanced
list line in list factory reset.
but if the keys are dead, and power lamp failing
the power supply is no good or worse. worse is always possible.
and expensive
ever see the support page, read the guides
https://support.hp.com/us-en/product/HP-w1907-19-inch-Widescreen-LCD-Monitor/3709665/model/3709666
its over 10 years old now. 2007?
walmart has larger one for $50
cheaper that parts or repair this.... vastly
Jul 27, 2017 | HP w1907 LCD Monitor
HP w1907 LCD Monitor Logo
997 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
