Question about Nokia N81 Smartphone
Audio recording i need software for audio recording when am make call
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 66 Answers
Hi here is the link where you can download software for audio recording
http://www.filebuzz.com/findsoftware/Call_Recorder_For_N_81_nokia/1.html
Posted on Mar 04, 2009
Does window 8 supports Audio Recorder 3.0 with USB Cassette Player?
Don't know about Audio Recorder 3.0, but the free Audacity software can probably meet your needs, and it ruins well under Windows 8.1.
Oct 19, 2014 | Honestech Audio Recorder 3.0 Plus with...
Tip
How to record Guitar sound on a computer
<p>Line-in <br /> <p>1. Buy a software package for recording music, if your budget allows. Recording music software is specifically designed for recording musical instruments formed. He cannot offer features found in common software audio. Alternatively, an audio recording program for free to get the music recording software than your needs and budget. <br /> <p><br /> <p>2. Buying a guitar cable to your computer if you use an electric guitar. Connect the larger end of your guitar amplifier and the small end into the computer microphone / line-in. <br /> <p><br /> <p>3. For an external microphone when a traditional guitar. Plug the microphone into the computer microphone / line-in. A stereo microphone is a natural sounding audio file, due to the dual microphones. <br /> <p><br /> <p>4. Open your audio recording program, which recognizes the device connected to ensure the microphone / line-in. Pull the cord, again if it does not recognize the device. Change the settings for the recording program to your needs to adapt, you can file type for quality change, and the recording is mono or stereo and audio level. Press the Record button, then started playing guitar. <br /> <p><br /> <p>5. Press the "Stop" button when you finish the game. Some programs can automatically be prompted to save the file; others may be the audio file first. Press "control" and saving "S", if not prompted. <br /> <p><br /> <p>Digital recorder <br /> <p>1. Buy a stand-alone digital recorder, if you do not want a guitar cable or an external microphone. A stand-alone digital recorder is small enough to fit in your pocket and can be placed anywhere without the need hampered by a cable. <br /> <p><br /> <p>2. Set the digital recorder on a flat surface. Press the record button. <br /> <p><br /> <p>3. Press the digital recorder, "Stop" when finished. Connect the recorder to the computer with data cable. Open the device by clicking on "Start" then "Computer" and double click on the recorder in the "Removable Devices". Copy the file from the recorder to your computer. Turn off the burner when you are ready to save battery power.<br />
on Jun 21, 2011 | Computers & Internet
Gigaware no sound
If you have audio cables from your source connected to the capture card, then your Recording device needs to be the Line In of the capture card.
If you connect the source to the Line In on the computer, then you use that as the default recording device. Until I set this, the default audio recording device was my microphone (not connected at the time). In Windows, you need the Manage Audio Devices Recording tab. (In Windows 7 and 8, it's under Control Panel > Hardware and Sound > Sound > Manage Audio Devices.)
If you are recording something playing on your computer, then the stereo mix option may work.
You should be able to use any video&audio software if the drivers are compatible. Thus the software you used for the video recording should work. (Stereo mix may be an exception - not all sound cards actually work when you try to record that content.)
I hope this helps.
Dec 03, 2013 | Televison & Video
I can't find the drivers for my Olympus Digital voice recorder VN-2000PC. What can I do? I can't tranfers my audio files to my PC.
Do you need the software/drivers for the VN-2000PC or the VN-2100PC? The software for the VN-2100PC is available here: http://www.olympusamerica.com/cpg_section/cpg_support_downloads.asp?id=1270 . Select your OS and you'll find the software.
The VN-2000PC doesn't connect to the computer via a USB port. To transfer your files to a computer, connect the earphone jack to the line In (blue) jack of the computer with a 3.5mm to 3.5 mm audio patch cable. Use a program like Audacity to record the audio track during playback. Make sure to set the Audio input to Line In. (In Windows 7, click Start > Control Panel > Hardware and Sound. Under Sound, click Manage Audio Devices. Then select the Recording tab and set the input device.) Then set the recording device in the software as well. Click the Record button in the software and then start the play back on your VN-2000PC. You should see a flat line for a bit then see a wave form start. If the line stays flat, you haven't set the Line In device properly.
I hope this helps.
Sep 01, 2012 | Olympus VN-2100PC Digital Voice Recorder
How i can recorde
Music or video ?????
If video you can install vlc player from here free:
http://www.videolan.org/vlc/
When installed click on show in the menu bar
and select advanced control now the player can record.
When click on the record button.
And it will create your video in your video map.
For music also for free you can install this recorder from here:
http://www.sound-recorder.biz/freesoundrecorder.html
Free Sound Recorder does exactly as it sounds -- it is an easy-to-use FREE software program that lets you record any sounds from your sound card and save the recording directly into MP3, WMA or WAV files.
Free Sound Recorder is a perfect audio recorder to record your own voice, music or any other sound by working directly with your sound card. It supports the record input/source from a microphone, streaming audio from the Internet, external input devices (e.g. CDs, LP, music cassettes, phone line etc.) as well as other applications like Winamp, Media Player, etc. With built-in advanced audio record engine, the recorder produces high quality recordings.
If you're looking for an application to help you for audio recording, you won't be disappointed in Free Sound Recorder! Main Features of Free Sound Recorder
bg_link_arrow.gif Allows you to record audio into MP3, WMA or WAV format directly.
bg_link_arrow.gif Allows you to pre-define audio recording qualities to help quickly set and manage recording parameters.
bg_link_arrow.gif Built-in advanced audio record engine to produce high quality recording.
bg_link_arrow.gif Allows you to preset/preview your audio recording device before starting record.
bg_link_arrow.gif Build-in WMA WAV MP3 decoder.
Hope this was helpfull
Mar 10, 2011 | Computers & Internet
Ive been able to record and now i cant record bcuz the screen says "no inputs..." but i can hear music thru the inputs and the lexicon alpha is selected as the input and output sourc. whats wrong????
It sounds like you have NOT connected via the recording software.
It is like the normal Windows software audio has hijacked the audio system even though it is external.
Go into your recording software and look for an option to select the Lexicon device. You did not tell us what recording software you are using.
This is not an uncommon problem with these external audio recording devices.
Apr 14, 2010 | Lexicon Alpha Personal Recording Studio
I OWN A AKAI 4000DS MK2 REEL TO REEL TAPE RECORDER, IS IT POSSIBLE TO CONVERT MY TAPES TO DIGITAL. WHAT WILL I NEED? THANK YOU
All you need is to connect the Tape deck via a lead to the audio input of your computer. You can then get a audio recording software (I use and recomend Dan Das Digital Audio Editor). It will record the audio and then you can save it to any number of audio formats. There are some basic processing functions on most Audio Editors, but for more advance features get Audio Cleaning Lab, by Magix. You can record direct with this software. But it's easier to import files into it, due to the fact that they have made the cutting functions complex to use, but the special features easy!
Dec 19, 2009 | Audio Players & Recorders
Audio Recording Problems
try using the windows sound recorder to see if that records music? if it doesnt then you need to go into your sound recording properties and change it from mic to wave
Dec 02, 2008 | E-Mu 0404 Sound Card
Sound in one ear only
The Fastrack only has one audio input signal to the PC. You'll need to set your recording software to mono, then you can add stereo fx in your audio software.
Jun 06, 2008 | M-Audio Fast Track USB (FASTTRACK) Audio...
Nokia N81 Smartphone Logo
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
