Question about Dell Latitude D600 Notebook
How to create a mobile sim in dell laptop internal system
Solve the sim problem which driver should be input
  • pixelpowered May 11, 2010
    Please note your Service Tag found on the bottom of the laptop. Also verify if your machine was ordered with a Broadband option from Dell to confirm if you have the correct hardware installed.
I have dell inspiron n5010 laptop. i have read in manual that sim card can be inserted in laptop and also i checked in my laptop that there is a sign to insert sim card but i am unable to insert. anybody...
To solve this problem, follow the link below and follow the instructions on the linked page on how to solve this problem. For me to give you instructions here, it would be too long so I set up this link that will take you to solve the problem you're having http://support.dell.com/support/edocs/systems/insN5010/en/sg/sg_en.pdf
Aug 27, 2011 | Computers & Internet
Hi,i have dell studio 1555 laptop i waana to know to about where we insert a sim in my laptop and how to conifgure for internet
actually, I know the solution partially....
and i need that solution too.
Open your battery, then you will see a sim card slot (some metallic type).
Now you know about drivers then tell me name of driver...
Apr 04, 2011 | Dell Wireless 5530 Mobile Broadband...
I have a alcatel OT 255 D n my home country is India. m using this mobile in India only and I have a problem in opening WAP or Internet. I even subscribed to GPRS Package bt when i requested for GPRS...
I have this mobile too
go to setting -> connectivity -> data account -> GPRS -> options -> create
to create a data account ( input your APN setting, etc. )
back to connectivity ( or go back to main menu -> WAP ) -> edit profile -> SIM1 ( or SIM2 ) -> create
to create a WAP profile, input the homepage, etc. Select the data account you created
( Don't forget to check "Select SIM card" setting in profile to choose right SIM )
Dec 02, 2010 | Computers & Internet
I have del studio 1450.its sim slot driver not found.so can you help me..???
Friend you install studio 1450 min drivers.one icon on the desktop will appear
then inser net activated simcard click on connect to net.
your problem will solve
Nov 13, 2010 | Dell Wireless 5530 Mobile Broadband...
I cant get my sound to work. The speaker icon has the red X over and I cant remove it.
Install the latest audio driver for your computer you can download it in support.dell.com. input your service tag then download your driver install it, make sure you input the right operating system,..after installing it restart the computer,. it that doesn't work. try to check the device manager if the audio driver is detected if not ,, try to do system restore and set it back to the last day it was working, (depends on the restore point)
So if all of that doesn't work and you still have the "X"over it you'll need to replace that internal speakers.
Hope this helps!
Feb 13, 2010 | Dell Inspiron 1721 Notebook
What actually Dell Wireless 5530 Mobile Broadband and what it is use for?
It's a mobil connection.
It enables you to stay connected to the internet if you are on the way with your laptop.
This are the spec. from Dell for the UK Internal Dell Wireless
Stay connected while on the go with the Wireless 5530 3G/HSDPA Mobile Broadband Card from Dell. It uses WCDMA Technology that offers fast, wireless broadband speeds to help you achieve LAN-like mobility. It helps maximize your productivity while maintaining contact with clients, colleagues and family. Its high efficiency compact broadband design provides consistent throughput performance. Its GPS capability allows you to retrieve location data from GPS satellites, utilize GPS navigation and location-based applications. This product has been tested and validated on Dell systems. It is supported by Dell Technical Support when used with a Dell system.
Highlights
•WCDMA technology for quick and easy integration into laptops, PDA’s and mobile
•Coupled with 3G technology for high level of mobility
•Compact design for enhanced throughput and performance
Compatible With:
•Latitude E6500 / E6400 / E6400 ATG / E5400 / E4300 / E4200
•Precision M4400 NB
It's quite cool and fast as described, I used the Vodafone Mobile connect HSDPA and I can confirm the good performance.
One serious issue are the costs, as you pay for the downloaded MB once you exceed your free data limit,
Not sure if you want to use it privately, then you need to monitor the amount of downloaded data closely otherwise you will be poor very soon :-). Check at the Vodafone Home page the costs.
Aug 29, 2009 | Dell Wireless 5530 Mobile Broadband...
No internal hard disk found
Hi there.
Use the Vista CD to create the new partition, but first you have to delete the old partition first, (the 220GB partition not the 10GB one because that will be the recovery partition).
Get a calculator and work out your new partition, for example 50GB is 50x1024MB so that will be 51200MB.
When you have deleted the 220GB partition select NEW and input your newly worked out partition and carry on from there, to activate the other partition just format it.
Please post back with the results and for anymore help if needed.
Good luck and thanks for using FixYa!!
May 24, 2009 | Dell Inspiron 1525 Notebook
Dell Latitude D600 Notebook Logo
671 people viewed this question
Alun Cox
