Question about Frigidaire Gallery Series® GLHT186H Top Freezer Refrigerator
My fridge keeps making a ticking noise, sort of
My fridge keeps making a ticking noice when the fan is on
    Genius:
  • 1,550 Answers
The evaporator fan, inside the freezer will sometimes come in contact with ice and make this noise.
If the overload on the compressor is tripping it will make a clicking sound.
Posted on Mar 04, 2009
Fridge light doesn't work/makes ticking noise
Let the refrigerator cool for awhile without opening the door. 39 minutes should do. Then check to see if the bulb is warm or hot. If it is the door switch is bad and the light is staying on which will make the plastic expand and cracklel or tick. Hope this helps.
Apr 11, 2014 | Magic Chef Refrigerators
Magic chef 10 cu fridge makes ticking noise but works fine
Some times refrigerators make a noise that sounds like a tick. It could be caused from the refrigerant flowing through the lines. This usually happens when the refrigerator first starts up and goes away after a few minutes. the other possibility is a fan motor blade taping the shroud from time to time. The refrigerant issue is not something that can be fixed. The fan blade issue could be fixed by moving the fan blade back or froward on the shaft a slight amount. If you have a 10 cu ft refrigerator it may not have a fan.
Apr 05, 2014 | Magic Chef Refrigerators
My bathroom Broan exhast w/light makes a constant clicking / tick tock sort of noise when the fan is not running. as soon as I turn the fan on the noise stops and then stops after I turn the fan off, only...
remove the cover and clean anything in the vent , check the fan for anything that could be touching it, as the back draft comes through the vent, something could just be touching the fan blade as this draft makes the blade turn slowly, which would create a ticking noise
Jul 10, 2011 | Broan-NuTone (8663RP) Ceiling Fan
Fisher and Paykel fridge is making a noice sounds like the fan
Here is a tip that I wrote about refrigerators and the fan noise that they develop sometimes...
Refrigerator Fan Noise
heatman101
Jan 22, 2011 | Fisher and Paykel Refrigerators
Ticking noise
HI, This is the result of a damaged Power control board. This board is not regulating the incoming current correctly. This board should be replaced, immediately. This will cause the in-house circuit breaker to blow. The board is located behind a access panel, on the rear of the unit. Have it replaced, soon.
It may be mounted on the compressor platform, as well.
Dec 22, 2009 | GE GDS20KBS Bottom Freezer Refrigerator
Fan started making noise
I have one of these, and every so often, the fan would start making a loud clicking noise. I discovered that if I shut the fridge off for a while and left the door open to defrost it, it'd work fine again for a while before the noise came back. Apparently, some ice was building up between the metal heat-sink and the fan, causing the fan blades to scrape against the ice/frost build-up and make the "tick, tick tick" noise.
There is no compressor in the Avanti EC15W-2 mini fridge. It uses a simple Peltier junction device to transfer heat from the inside of the fridge to the outside/rear of the unit. So it should never get very loud at all, unless one of the two fans in it is acting up in some way.
Aug 15, 2009 | Avanti EC15W-2 Compact Refrigerator
Ac compressor. is making a ticking noice
This is normal, the compressor is spun by the fan belt, and when everything equalizes the pulley stops moving. This repeats over and over again.
Jul 21, 2008 | Hyundai Motor 2002 Elantra
Refridgerator
There is fan in the freezer behind the metal cover. Try to stop the fan, and see if the the noise stops... If the noise stops then its possible that the fan is out of balance. If this is not the case then i would suspect that this is problem with the mainboard.
Jul 09, 2008 | Jenn-Air JCB2059G Bottom Freezer...
Fridge keeps ticking when not running???
Kevin, I'm going to give you a few scenerios to check out. The evaporator fan, inside the freezer will sometimes come in contact with ice and make this noise. Check your condensor fan, in back and make sure that is not hitting the shroud. If the overload on the compressor is tripping it will make a clicking sound, but it would be about every 4 to 5 minutes. If the unit goes into defrost, the evaportor coils tend to make a clicking sound. If you can be more specific as to where the noise is coming from, we might be able to help you better...Catriver...post back.
Aug 14, 2006 | Whirlpool ET9FHTXMQ Top Freezer...
Frigidaire Gallery Series® GLHT186H Top Freezer Refrigerator Logo
508 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
