Question about RCA RT2280 System
I have RT2280. Audio levels used to be 1-50, now
I have RT2280. Audio levels used to be 1-50, now the levels are 1-20, and level one is really loud. Any ideas what's wrong?
  • Speak-ER Mar 04, 2009
    I already tried unplugging and that did not help. Have not yet discovered where the reset button might be.
  • 463 Answers
Sounds to me as if someone may have gotten into the menu to adjust the individual levels of each loudspeaker and cranked some of them way up. As to why the "main" volume level goes from1-20 now as apposed to 1-50, you got me there...
Is there a reset button or equivalent on the remote or the unit? Try that. Try unplugging the unit for 15 minutes...
Here's the owner's manual:
http://support.radioshack.com/support_audio/doc66/66651.pdf
See page 21 for advanced volume control functions...
Posted on Mar 04, 2009
The sound output is very low even using earphones can the audio output be upgraded to give a normal listening level.
Probably not without using separate amplified speakers. Check the mixer levels are set correctly.
Apr 02, 2016 | Computers & Internet
Why would the output sound level on a MP3 vary so much?
MP3 songs are recorded at different levels. Many modern tunes have been deliberately recorded loud by the record companies for maximum effect.
If you are recording the songs yourself some recording software has a "normalize" feature. This increases or reduces the volume of the track to a certain level. Especially useful when you have tracks at different levels. By the way this is how they get CD tracks to play at the same levels. So you don't have to turn up the volume or turn it down every time a new track plays.
Nov 11, 2017 | Audio Players & Recorders
How do I increase the overall loudness of a CD once it has been burned
What you need to do is find an option called "normalise" this makes the sound at the same level for all tracks on the CD. However I should point out that even some commercial discs are recorded at much greater levels then are needed. In otherwords they are loud!
Apr 15, 2017 | Audio Players & Recorders
How can I increase the loudness of the CDs burned on the internal CD-RW drive?
You can use a free software audio editing and recording program called Audacity. Using this program load your stereo track(s) into Audacity, then look in the effects menu and select normalize. Make sure to set highest loudness level to 0 db, which is the maximum digital volume level. You can hear the difference in volume when you use the test button. If you can't still get enough over all volume level with the normalize feature then you will need to compress and limit the stereo track, but I don't suggest getting your over all loudness levels that high because it ruins and lowers the dynamics of your music. Another words when you compress and boost the over all loudness of your album then all your music is at the same highest audio level which is very ear fatiguing. It may sound better to you at first at louder volume levels but you will quickly learn to hate it over time because it does not sound natural. That is why most music today is all about loudness and ear fatigue. And because of the loudness wars going on today every Record company is trying to have the loudest album out there thinking it will sell more copies. It is all false baloney, it really should be about the quality and dynamics of your sound instead of how loud it is.
May 23, 2013 | Fostex MR16HD/CD Digital Recorder
The best Rec. levels
As with all recording levels it's best to keep them to a max of 0 VU on the level meter. Some say an odd peak into the red or above 0 VU is acceptable, but it should not go to high. Sett it on the loudest part of what you are going to record, then the rest of the time should be OK. Try some loud music first if it's all speech. That should set the right level for the speech. It is possible to increase the audio level on Audacity afterwards anyway.
Oct 01, 2017 | Samson C03U Professional Microphone
My surround speakers are too loud. I have adjusted the speaker level, speaker distance and surround level but none of these seem to change. When i go back into menu it does reflect the changes but doesn't...
Did you try changing the front & center speakers to a higher level as well as setting the surrounds to a lower level? Are all speakers using the same wire gage?
Nov 26, 2010 | Sony STR-DE897 Receiver
Distorted recording and loud
If you're using the RCA cables, how is the switch set on the TT?
From the manual....
2. RCA Audio Output Cables: These cables should be plugged into a CD or Auxiliary input on your computer. IMPORTANT:
There is a switch on the bottom panel, next to the RCA cables that selects between PHONO/LINE. Use PHONO level for
plugging into a turntable input on a home stereo. Use the LINE level for plugging into CD/AUX/TAPE inputs. WARNING: You
may damage your receiver if you plug in a LINE level into a PHONO input.
Mar 29, 2010 | ION Audio iTTUSB Turntable
Help! My Yamaha EMX66M Peak Indictor LED's are not working.
It looks to me like a fault in the LED circuit controller. Unless there is some kind of level control located on the unit.
I would assume that loud feedback could damage the unit.
Dec 06, 2017 | Yamaha Emx68s Powered PA Mixer System
To increase up volume
The code is: *#0206*8378#
Then go in: H/W Test > Audio Settings > MP3 spk
change 'ear gain' to 14.
Then, enter 'Rx vol.'....
I made this changes:
Level 1: 150
Level 2: 180
Level 3: 210
Level 4: 260
Level 5: 300
Level 6: 370
Level 7: 460
Level 8: 550
Level 9: 640
Level 10: 700
Level 11: 800
Level 12: 1000
Level 13: 1350
Level 14: 1400
I made this changes and the sound of mine became very loud now...
You can do your own changes,
Jul 21, 2008 | Lands Phones
IM HAVING PROBLEMS WITH MY PHONE. I CAN BEARLY HEAR MY PHONE RING WHEN I GET A CALL. THE VOLUME IS ON 7 BUT STIL I CANT HEAR.
Increasing Loudness in Earpiece as well as Headset
# Goto Test Mode by presing *#0206*8378#
# Goto H/W test > Audio Setting > Goto Normal > Rx PGA > Change value maximum upto 254
# Goto H/W test > Audio Setting > Goto Normal > Rx Vol > Change value of each level by 5-20
# Goto H/W test > Audio Setting > Goto Normal > HFR gain > Change value maximum upto 20
# Goto H/W test > Audio Setting > MP3 Codec SPK > Increase the value for each level by 6 and set the 14th level 254
# Goto H/W test > Audio Setting > MP3 Codec EAR > Set 14th level as 248 and set value for other levels by decreasing the value by 7
Jun 07, 2008 | Samsung Cell Phones
RCA RT2280 System Logo
145 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
