Question about Saeco Magic De Luxe Espresso Machine
Saeco Magic Deluxe water leak
I have a leak coming from the boiler area dripping onn the counter and in the pan. How do I get open the macine to inspect the bolier?
  • 2 more comments
  • Victor 12 Mar 07, 2009
    My Saeco Magic Deluxe is leaking also, hot water is almost pouring into the drip tray while making a cup of coffee -- oddly the coffee still tastes fine.
  • ormondgranit Apr 28, 2009
    I had the same problem and my boiler ended up leaking into the brain and shorting out the whole machine. cost me $400 to fix it.
  • Anonymous May 02, 2009
    I have a 4.5 year old machine. Had the leaking water problem about 3 years ago and had the boiler replaced at a cost of $200. It is now happening again - I was told the boiler had been replaced by a more heady duty version...very frustrated. Where do I go for service in Atlanta area?
  • smotley1 May 02, 2009
    water leaking into the coffee grinds bin and in the tray under the coffee
Bansheracer-
I have the same problem with the boiler leaking, and I'm also guilty of not descaling nearly enough. Anyway, I've already replaced the machine, but I just can't bring myself to throw away this otherwise great machine. I've ordered a boiler repair kit and I want to attempt a fix on my own (don't want to spend too much money). I have the machine opened up, but I'm not sure how to remove the boiler. Do you have directions?
Thanks.
Posted on Feb 02, 2010
  • 1,089 Answers
Hi Boilers leaking are usually a sign of not descaling enough. It is not recommended to take apart your machine unless you have knowledge in electronic repair. There are a lot of wires and hoses.
Once the boiler starts leaking it needs to be replaced. email me for directions since it won't fit on this page.
Posted on May 23, 2009
Vaillant boiler leaking only when heating switched off.
It would seem a joint has come a bit loose from the heating and cooling cycle. put a drip pan under the leaking area( the drips would evaporate quickly), then next time you shut it down go through all the joints in the area with wrenches to find the loose joint.
Oct 27, 2014 | Water Heaters
Tip
Boiler Leaking Water - The Boiler Leak may not be the boiler
Went on one call today and had another query by Facebook about this so I though why not write an article about it. Both persons were very concerned as they saw water dripping from theirs boilers. A closer inspection for both showed that it had nothing to do with the boiler its self.
There are many things that can make water leak from your boiler. If you know for sure that the water is coming from a hole in the sections then you may have a serious problem. Usually though there is an easy fix for that also, more on that in another article. Both boilers today were leaking water from the relief valve.254c728.jpg
This valve is design to relieve the excess pressure from the boiler in case of a build up of extra pressure in the boiler. The extra pressure can come from a number of different things. A few of the causes may be a bad expansion tank, a bad fill valve or pressure reducing valve, or an open bypass valve. The bypass is easy, just close it and relieve the extra pressure. The others are not as easy.
Your expansion tank is simply a tank that allows water from the system to go in and out according to the pressure in the system.610ab3c.jpg This tank contains about ½ air which acts as a cushion to absorb the extra volume of water that is created as the water is heated. Hotter water takes up more space or volume, so it needs a place to go to when it is heated. If the expansion tank is totally full of water then, it will push water out of the relief valve. Changing your expansion tank will fix the problem.
If the reducing valve or fill valve is leaking by then you can also get extra pressure in the system.8e5ccb4.jpg A normal heating system will only run 10-20 psi pressure. Most well systems or city water is way higher than that. If the pressure in your boiler gets over 30 psi then it will begin to relieve the extra pressure by dripping water.
If you have a drip from your boiler this is what you check. First the expansion tank, the reducing valve, and the bypass valve that bypasses the fill valve. This valve is usually installed to quick fill the system, or purge the water lines of air.
Often there is just a small problem that looks like a big problem. Do not get excited and methodically check through the possibilities. You will usually find that the problem is not nearly as bad as you first thought that it was.
on Dec 06, 2009 | Heating & Cooling
Aurelia 4 group mystery leak below drip pan when unit is off
My 2 group Aurelia does this also and I have traced it back to a fitting on the boiler. It only leaks when off with no pressure...on mine it was the right tube/fitting on the boiler.
Mar 04, 2014 | Nuova Simonelli Aurelia Semi-automatic 4...
I have a Carrier furnace and noticed water on the floor. I saw it was coming from the filter housing. I pulled out the filter which was wet only on the bottom And noticed the pan/track it sits in had water...
Hello, there might be a crack in the condesate pan. Usually if the leak is concentrated in one area that is the cause. If the water would be leaking all around then a blockage in the drain line would be a problem. Have the drain pan inspected.
Jun 18, 2012 | Heating & Cooling
My side by side drip"s
The water is from a blocked drain of the defrost, especially with the water off that's where its from. This tip i wrote will tell ya how to clear that drain http://www.fixya.com/support/r9991618-wrong_when_side_side_refrig_leaks_from
GENE
Sep 14, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
I have a Intertherm Heat Pump system in my Manufactured Home, Model # E2EB-015HB; Serial # E2E0121006692. Condensation is forming on the Coils and the water fills up the area under the coils, drips down...
There is a drip pan bit the middle is open to allow air flow through the coil and into your ducting. If the drain for the drip pan is clogged it will fill up and overflow onto your furnace and then to the floor.If that is what is happening then clean out the drain tube running down the front of the furnace and it should empty the drip pan and solve your problem.
You also need to have your furnace checked for water damage in the electrical components, if these have gotten wet then you run the risk of a fire. Please consider calling an expert in your area to inspect your furnace and make sure the drain line is clear.
Jun 13, 2011 | Intertherm Heating & Cooling
Coffee doesnt flow but water gathers in the drip pan instead.
Hi Your problem is probably the boiler leaking. Its located just above the drip tray in the center of the machine. When it starts leaking it goes into the drip tray or on the counter top. If you can remove the top, you can see if the boiler is leaking. There will be a white line between the 2 halves of the boiler.
Feb 09, 2010 | Saeco Magic De Luxe Espresso Machine
Water is leaking from inside the freezer side of
water drianage is normal, it is supposed to drip from the freezer area to a drip pan under the unit and evaporate before it gets full. check to make sure that the drip pan is properly located and exsits and that you do not have an obstruction hindering the drain opening
Aug 22, 2009 | Hotpoint Refrigerators
I BELEIVE THAT THERE IS WATER DRIPPING FROM HOUSING FOR FILTER
I opened up the housing and saw that when I removed the water filter that the water didn't leak out . I also turned the ice macine and water dispenser off.
Feb 11, 2009 | Estate TS25AFXK Side by Side Refrigerator
Water leaks from my Saeco Incanto after brewing.  It appears to be coming from the boiler or back of unit.  I also here a hissing sound which makes me believe that the water is in contact with a hot...
I think you have to replace your bolier in the machine.
If it is the boiler and you replace it, make sure to descale your machine regulary.
Best regards
/Mirran
Sep 04, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
1,007 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
