Question about Bunn VPR Coffee Maker
My bunn coffee maker is just dripping when it is making coffee. Then the next time it makes it just fine.
    Novelist:
  • 125 Answers
Hello, I am wondering how long between times you are stating, as most Bunn commercial units, stay heating 24/7, and if water is not poured into the machine every couple of days, they will evaporate off water that is held in the tank. This drop in water level can cause short brewing, slow brewing, etc.. as the unit relies on a vacuum or suction to brew properly. You could also have a leaking tank gasket, or brew tube gasket, and it is seeping air into the tank, breaking the vacuum/siphon action, and then seals with water, or expansion at other times. Another cause would be scale build up, and pieces are floating in the tank blocking the flow of water, or your spray head may be clogging/clogged, which minor cleaning should take care of the sprayhead, and tube, or a major cleaning necessary for the tank.
Hope that helps, and thank you.
Posted on Mar 08, 2009
WHY HAS MY CAFE STOPPED WORKING? IT DOESNT DRIP COFFEE INTO CUP.
Sounds like your machine is congested. Consider cleaning out the nozzle or the filter.
Sep 22, 2014 | Bunn Commercial Bunn My Cafe Pourover...
Coffee starts dripping down before I can get the water all poured in and the pot on the warmer, causing a mess.
This is common with bunn coffee makers, if you are not fast enough, coffee starts dripping. The only solution I found is to use a water pitcher, first fill coffee pot to cup mark you are using, then pour into pitcher, put pot back on machine, then pour in water. You can mark a line on picture, so you know where to fill to each time.
Jul 15, 2010 | Bunn NHB Coffee Maker
Doesn't drip through. Don't know where the coffee water went to?
When setting up a new machine, it requires 2 full decanters of water to be poured into the machine. After you have done this, then you plug the machine in and turn on the vacation switch on the side of the machine. After 15 min, then you will pour in 4-10 cups of water and it will force out the hot water from the tank in the back and brew the coffee. If this doesn't correct the problem, then please call customer service with the model and date code.
Sep 11, 2009 | Bunn NHB Coffee Maker
When pouring coffee it drips, also doesn't keep coffee hot
Hi - Any time I've had an issue with my Bunn BT10-B, I go to the website, www.bunn.com , and go to their Customer Service area. They have been extremely helpful and informative.
Aug 16, 2009 | Bunn B10 Coffee Maker
This is commercial and the water drips instead of flowing,took 20-30 min to make coffee, how can i clean?
Have you tried to brew without coffee to see how long it takes? If yes then use a pair of channel locke to remove sprayhead and then use the deliming sprding that came with your bunn and clean the brew line then try again, if you still get the ame result, the brewer needs to be descaled.
May 06, 2009 | Mr. Coffee Coffee Makers & Espresso...
We find water under the coffeemaker in the morning.
Sounds like a leaking water pipe from the water source, unless you have a over temp heater and this results in steam and dripping.
Mar 30, 2009 | Bunn VPR Coffee Maker
MY BUNN COFFEE MAKER LEAKES WATER
Yes Bunn will send you a repair kit free of charge. Just apply a bead of silicon below the rubber gasket before you tighten it down and it will solve the problem.
Mar 16, 2009 | Wega Mininova EPU Espresso Machine
Dripping
Is the burner hot when this occurs?
Sep 14, 2007 | Bunn A10 Coffee Maker
Bunn coffee maker
Is the burner hot while your pouring water in?
Sep 14, 2007 | Bunn NHB Coffee Maker
Bunn VPR Coffee Maker Logo
242 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
