Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston Flash drive is NOT accessible (8GB)
(When inserting the device the system detect the new hardware attached so, The Device & drive letter appears in my computer window but when double click on it the following message appears: Please insert a disk into Drive H:)..
Thank you in advance
My flash drive is not supporting my computer kingston
Posted on Mar 04, 2009
Install again new window and check it
What is the password for the new kingston USB DT109?
It is true that locking mobile storage devices, such as USB drives, with Imation Lock is an excellent way to protect your data.
However, using Imation Lock with a Kingston USB drive can create problems.
Learn how to unlock your Kingston USB drive so you can use it once again.
Ensure that your Kingston USB drive has been removed from your computer's USB port.
Start the Imation Lock software by double clicking the Imation Lock.
Plug in the Kingston USB into a USB port immediately after the "Please Insert the Device or Run This Utility as Privileged User" message appears.
Access your Kingston USB drive by clicking Start > Computer.
Double click on the device.
Start the Imation Lock software again by double clicking the Imation Lock.
Disable the password protection by clicking the open lock icon.
or
If you have password protected a USB drive or partition on your computer and have since forgotten the password, you will need to completely erase the drive.
Erasing and reformatting the drive will remove any password protection, software and data on the drive preventing you from accessing the drive.
The process is simple using Window's Disk Management utility.
Log into the computer as the administrator.
Open the Windows Start menu, select "Run," type "Compmgmt.msc" and click "OK." In Windows Vista and Windows 7, simply type the command into the "Search" field.
Select "Disk Management."
Locate the password-protected drive.
Right-click it and select "Delete." Confirm the action.
The drive will be erased and become unallocated free space.
Hope this helps.
Nov 28, 2012 | Kingston Ultra Thin DataTraveler DT 109...
My 8gb wont open it say incorrect function and it does not allow me to format
insert your flash disk into your computer right click on my computer on the desktop. Go to "Manage". On the left side of the Computer Management window click on Disk Management (under Storage). Then right click on the name of your flash drive (typically called the manufacturer's name, default, or removable media). Click on change drive letter and paths. Then click Change, and choose a drive letter that is not currently in use, any letter . Press OK twice to return to the computer management window, press the X, and you should be back at the desktop and able to access your flash drive
May 18, 2012 | Kingston 8GB Data Traveler - 108:...
Hello bro My 8gb kingston pendrive is showing 1.97mb in my computer as its size? how to get back the 8gb size plz help me its urgent!!!!!!!!!!!!!!!
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy.
May 30, 2011 | Computers & Internet
My kingston 2 gb flash disk is not recognized, how can i fix it?
Please follow the below steps to fix your problem
Connect your flash drive to your computer using an available USB port. If your flash drive is not recognized, you'll usually receive an error that says "USB Device Not Recognized."
Click "Start" > "Control Panel" and open the system configuration by double-clicking the "System" icon.
Navigate to the "Hardware" tab and click the "Device Manager" button to open the Device Manager.
Click the "+" next to "Disk Drives" and locate your USB flash drive. A question mark icon should be shown to the left of the label. Right-click the device name and select "Uninstall."
5
Open the "Action" menu at the top of the Device Manager and select "Scan for hardware changes." This will scan your PC for any new devices. Because you uninstalled the flash drive, it will be detected as a new device and the drivers will be reinstalled.
6
Click "Start" > "My Computer" and look for your flash drive. If this process was successful, your flash drive should now show up under My Computer as a storage disk.
Hope the above information will be helpful to you.
Thanks.
Oct 22, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My transcend 8gb pendrive is not working. plz help me
plug in your flash drive then go to device manager then universal serial bus controllers expand it ..you will see usb mass storage device right click in it and select uninstall now remove your flash drive and restart your system ..now plugin flash drive.... this time it will detect your flash drive and.. i think branch is in panjagutta, ameerpat...in secundrabad it is in jagdish market at abids and chenoy tradecentre mg road parklane..if some how you get to properties box try to format with ntfs system....goodluck
Jun 14, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I got amessage which say that USB Devise not recognize
There are different Ways to troubleshoot Your Problem
1. Verify if minimum operating system requirements are met.
2. Try other USB ports
3. Check status of the Cruzer under Device Manager
4. Connect the Cruzer to the PC
If you receive a "USB Device Not Recognized" error on the computer, the flash drive is most likely failed. Additional troubleshooting is unlikely to correct the problem.
*. check under Device Manager
  • 1. Right-click My Computer, and select Manage
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click on the entry with the error mark, select Uninstall.
*. 2. On the top menu, click Action then select Scan for hardware changes.
*... STEP 4 - Verify if the flash drive is detected
1. Double-click My Computer.
2. Look for the Cruzer under devices with removable storage.
Now the Other way
*. There might be a conflict in drive letters, see Resolving drive letter conflict.
Feb 19, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My 8GB Kingston pen drive shows ''USB device not recognized'' when inserted in any PC. Help please
It has malfunctioned.
Kingston will replace it, under warranty, but all your data is, sadly, "gone".
Jan 13, 2010 | Electronics - Others
My pen drive is not showing file system ( fat 32 etc..), what can i do? and how can I format the my Kingston 64 GB and 40 GB drives
Sometimes when a flash memory stick or USB external hard drive fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory USB hard drive device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the flash or external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs) also between XP/Vista and earlier versions of Windows.
Insert the flash or external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Health.
Dec 08, 2009 | Kingston Televison & Video
I cant open my usb device
Those memory sticks are not hot changeable. Try the stick in a different computer if you can't open then it is bad, and it can change the drive letter for your cd-rom. Remove stick reboot computer and make sure the cd-rom drive has the right letter if not search help for how to change drive letter. Rember to always rignt on task bar then safely remove hardware or buy a hot changeable. Please rate nr mysleuth
Apr 28, 2009 | Computers & Internet
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
951 people viewed this question
Top Kingston Computers & Internet Experts
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
