Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
HOSHIZAKI that wont stop making ice
My ice machine just keeps on making ice till ice is up in the top area then its still continues to make ice.
    Director Badge:
    Uploaded 100 video answers.
  • Hoshizaki Master
  • 488 Answers
Bin Thermostat does not work
Posted on Oct 09, 2015
Bin stat defective
Posted on Mar 04, 2009
Hi .my hoshizaki ice machine it till running but do not make ice . Can you tell me , what wrong with the machine ? Thank you
The machine, all in one, not indoor/outdoor split type, will make beeping sound when something is wrong and stops working until it is turned off and turned back on. Some times the machine needs to be reset with the power on, covers removed, reset button inside on electronic mother board.
The ice machine covers have instructions and information on beeping sounds.
Aug 27, 2017 | Hoshizaki Freezers
Why did my hoshizaki ice machine stopped making ice?
bin stat is what is used to shut machine down. if it goes bad in any way, no power will go to the control board. Start there.
Aug 11, 2014 | Hoshizaki Freezer Commercial Ice Machines...
How to change float switch on hoshizaki ice machine ?
take the front and top cover off from the top look down and you can see the reservoir there is a black piece on top with two wires going in to it. turn it to remove it. You can test it by starting the ice machine and turning the float up side down. If water continues to flow you may have a bad diaphragm in your water valve. You can replace the diaphragm with a Phillips screw drive. Just be very careful when you lift the stem that goes in the solenoid make sure you pull the diaphragm with it as well. there is a spring it the stem that will fly out and it runs fast and hides well. look at the diaphragm's hole if it looks worn replace it before the float switch.
Jun 13, 2014 | Hoshizaki Freezer Commercial Ice Machines...
How to reset hoshizaki ice machine
small white button on control board. press once to stop beeping. Very small but it is labeled and very hard to see.
Feb 09, 2012 | Hoshizaki Freezer Commercial Ice Machines...
The machine is good , up and running but it does not stop till its over flowing..how do i look for the stpping device for the machine once its full .??
the bin stat is either out of place or is not adjusted correctly. The machine should stop in no more than 10 seconds after the sensing bulb is submerged in ice. Make sure the bulb is mounted correctly and they come out of their holders on a regular basis.
Sep 30, 2011 | Hoshizaki Freezer Commercial Ice Machines...
I have a model # f-450 mah ice machine. After the bin gets full of ice it stops making the ice but the water continues to run and runs out of the machine. Any ideas on how to stop this?
Sounds like the water valve is stuck. Probably needs replacing. Turn off water after machine shuts down and see if water stops. If it does, water valve is most likely the issue.
Mar 01, 2011 | Hoshizaki Freezer Commercial Ice Machines...
Bin control
The bin control shuts it off when the ice bin is full. Without a bin control it should keep making ice and never stop.
Dec 27, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice machine repair?
seems that its low on water or float switch is bad. try to clean float
Sep 02, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Beeping Ice Machine
I have a Hoshizaki KM-250BAF that is making 3 beeps then pauses and them makes 3 beeps again. If I unplug the ice maker and plug it in it continues to make the 3 beeps. The manual does not mention anything about beeps. Can anyone help?
Jul 09, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
356 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
