Question about Toshiba Tecra A2 Notebook
Microphon and dvd
I canot find microphon after reinstalation and my dvd is not working properly
Microphone feed back
You can go into the properties of the microphone and disable or fine tune to eliminate the feedback. If all else fails reinstall the driver.
Good first step.
See below: Windows 7 and eirlier
The information below is designed to help solve your microphone not working properly. This does not cover problems related to specific programs or third-party microphone hardware and software.
If your laptop microphone is not working properly, ensure it is not disabled:
  1. Open the Start Menu and type "Sound" in the search field.
  2. Select "Sound" from the results.
  3. Select the RECORDING tab and select the desired microphone. Default microphone is Realtek High Definition Audio.
  4. Click "Properties" to view and modify settings.
Reloading the sound driver may resolve this issue.
  1. Open the Start Menu and type "Device Manager" in the search field. Select "Device Manager" from the results.
  2. Locate and select "Sound, Video and Game Controllers."
  3. Identify the sound devices.
  4. Right-click on each one and select "Uninstall".
  5. Reboot the computer.
  6. Your drivers will automatically install. Third-party drivers may need to be reinstalled manually.
Nov 22, 2013 | Toshiba Satellite L505-ES5042 Notebook
Microphone feed back, i cant get my microphone to turn off, i set it up so my wife wouldnt have to learn to type using speak commands
Good first step.
Dvd read stuck canot open dvd canot eject dvd canot play dvd
if the disc was not installed in the plate fully and partly out in the front sometimes it gets stuck and u have to unscrew your dvd player andtake out the disc and it should work perfectly fine afterwards
Jul 14, 2012 | LG DVRK-898 MULTI SYSTEM REGION FREE DVD...
Microphone built-in not working
However, if the internal laptop microphone is not working properly, you have a driver problem (as there is no connection issue and the laptop is automatically set to use the built-in microphone). To correct the problem you need to reinstall the laptop's mic driver.
Apr 08, 2012 | Computers & Internet
My presario V3000 laptops microphone is not working so i cant talk . Plz give me idea.
Check your microphone software to see if the unit has it on mute. If on mute, uncheck the mute box and that should make it work.
If it still does not work, then reinstall the microphone driver by going to HP website and downloading the driver there.
If that does not work, then scan for viruses and do defrag on hard drive.
I hope this helps and write back and let me know if any of this works.
Jun 14, 2010 | HP 417065-001 - HP Compaq Presario V3000...
No image while playing PAL DVD on computer!! Only sound.
Try to update the drivers for your video card
Nov 04, 2009 | Computers & Internet
Window cannot find file csrcs.exe
this is virus problem ur system is virus affected. please reinstall windows xp properly with all the drives formated and see that ur system is working properly.
Sep 05, 2009 | Compaq Computers & Internet
About my microphone
make sure your audio device is selected, the one that you are using such as a usb phone over your onboard realtek audio.
Aug 19, 2008 | Shure Head Set Microphone Microphone
Dubbing to DVD not working
make sure the DVD is formated.
Feb 01, 2008 | JVC SR-DVM70 DVD Recorder
Toshiba Tecra A2 Notebook Logo
32 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
