Question about HP Compaq Evo n800c Notebook
Problem with vga driver
I have problem with my vga driver making my laptop's screen look white so i rely want you to help me out or possibly mail me website where i could download vga driver for my video control, i will be very grateful
  • smasting Mar 04, 2009
    I have downloaded the installer for the driver but i gives me an error when finishing the install.
    Setup failed to run installation: (0x80040707)
    Can you help me????
  • 75 Answers
Tyou can get drivers from compaq website.
Posted on Mar 04, 2009
Is this compatible with windows 8
This device should not rely on Windows Drivers so compatiblity should not be an issue. However the computer needs a VGA output or S-Video output. You will most likely need a 3.5 mm headphone type plug into the headphone jack of the P.C. and on the other end a rfc plugs.
http://www.4cabling.com.au/stereo-3-5mm-jack-to-2-x-red-white-rca-2m.html?gclid=CJ2GpveT28QCFVNwvAodrhkAMA#.VR8QWOE_xhI
A vga cable from P.C to projector may be needed.
If a laptop one of the function keys will switch the dual modes of the video card. f4 on my laptop may be different on your laptop.
http://www.miniinthebox.com/vga-male-to-male-cable-1m_p1051840.html?currency=AUD&litb_from=paid_adwords_shopping&gclid=CJvWyb6U28QCFUkDvAod4oEAGg
check what gender you need on each end and buy a matching cable. The one in the link is male to male . Check your devices to see if they have female sockets.
Apr 01, 2015 | Mitsubishi XL8U Multimedia Projector
Screen driver problem notebook
Might be a hardware problem as well. To make sure it is not, boot to "VGA mode" (see below), keeping the external monitor disconnected, and see if the problem is still there on the laptop screen. If the problem disappears, then it's more than likely that a driver update will solve your issue. If this is the case, uninstall the driver for your graphic card, download the latest one from the manufacturer's website and install it. If not, then you need a more in-depth look, maybe you have a faulty LCD display.
To boot to VGA mode, press "F8" repeatedly while rebooting your computer and select the appropriate choice from the black and white bootloader screen that will appear.
Sep 10, 2014 | Dell Computers & Internet
My screen on my acer aspire one d255 is cracked and it has turned completly white with some black in the corners. I was told that I would be able to connect it to a tv in order for me to see the screen...
Yes, it is possible to hook your laptop up to a tv or monitor. Your laptop has a VGA adapter which can be easily found on pc monitors, however it is less readily found on tv's so you will have to find a VGA to A/V converter. If you are lucky then your tv will have a VGA input.Here is a link to a new screen just in case
Good luck.
Aug 24, 2011 | Acer Aspire One D255-2670
Screen goes white while in use. LCD issue? Iam a pc tech, problem seems to come from the LCD cable
To make sure this LCD issue or not, use PC monitors then connect to VGA port..
Two possibilities can cause of this problem LCD or Motherboard...
Aug 08, 2011 | Acer Aspire 4315 Notebook
Thin white vertical line from top to bottom of screen about 1/3 of the way from the left side of the monitor.
That is either a screen problem or VGA driver/decoder problem.
Can you plug your laptop into an external display? That will tell you which is at fault.
New screens are fairly inexpensive from ebay etc.
If you have the same problem on an external display, the VGA decoder is inbuilt on the main motherboard and not easily replaced.
Hope this helps.
Dec 09, 2010 | Computers & Internet
''help me i got a windows problem''
the most likely problem is that your display drivers crashed,start your pc press f8 you'll get black screen with options select enable vga then it will start up,when the desktop opens go to control panel and un-install the display drivers first,reboot,and then reinstall them,hope that works.
Feb 06, 2009 | Computers & Internet
Display shows pink color lines in white areas of the screen
Reinstall your VGA driver and i assume, it should be fixed if not you need to think about *********** board.
thanks
Dec 27, 2008 | Lenovo ThinkPad T61 Notebook
Acer Aspire 5585 Laptop LCD Problem
Have you tried booting into "Enable VGA" mode via the "Windows Advance Option" screen? By press F8 before Windows XP loading screen comes up. In this mode the Video Card drivers are disabled. So if your screen appears normal and not white in this Mode then it is your video card drivers which are causing the issue.
Aug 19, 2008 | Acer Aspire 5610-4648 Notebook
LCD screen
please check it out with qualified professional
Apr 01, 2008 | IBM ThinkPad T21 Notebook
HP Compaq Evo n800c Notebook Logo
134 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
