Question about Carrier Heating & Cooling
My aircon would suddenly switch on and off itself
My aircon would suddenly and occasionally switch on and off itself. When it is on, I also cannot switch it off with my remote control. Practically, there is no way to stop it unless I switch off the mains.
    Problem Solver:
  • 18 Answers
Sounds like a T-stat issue,As for the remote change the batteries that might help.
Posted on Mar 04, 2009
I had the aircon thermostat on cold then my friend just transfered it to warm without turning the aircon off because it was too cold. in the afternoon when i tried to use the aircon theremostat to...
Problem is the thermostat.The heat/cool selector switch might not be making try back and fourth from heat/cool to make a good contact.In heat mode make sure the temp is set LOWER than your cooling temp.If it is too cold in the future just RAISE the cooling temp up and not the heat/cool switch.
Jun 04, 2011 | Heating & Cooling
TCL air conditioner works for about 15 minutes, switches off and gives a signal of 4 red flashes every now and then.
It's due to abnormality of out door unit. Clean condenser coil first. Check run amps. If gradually increases, replace running capacitor. Check rpm of f.motor. If slow, replace fan capacitor. If still problem, replace fan motor. Service indoor unit also. Thanks.
Feb 04, 2011 | Heating & Cooling
On the Aircon, when switch is set to 1 or 2 no aircon but when switch is set to 3 and 4 aircon is felt. Thanks.
blower fan resistor block, for fan speed operation is blown on 1 & 2
needs replacing usually located near fan itself
Jan 03, 2011 | Honda Civic Cars & Trucks
Jag X-Type 2.0 V6 Auto (2002). Amber engine icon lit and aircon switches itself on. No loss of power/drives great. Temperature gauge appears all normal. After a while aircon switches itself off again -...
The Amber Engine Icon means the same as a Check Engine Light. Your car's ECM (Computer) has stored a Trouble Code, and you will need a OBD II Reader (On- Board Diagnostic) to get the code so you can diagnose what is wrong with your vehicle. You can go to any AutoZone and they can read the code for you at no charge. You will need to diagnose and fix the problem before the Check Engine Light will turn off.
Aug 13, 2010 | 2002 Jaguar X-Type
My air conditioner only goes for a few seconds then turned off by itself. the technician that i called on the phone said, ''It's probably caused by the unstable voltage from the electricity company.'' The...
i don't what kind of unite you got but that a little strange. most AC unites have dedicated breakers. and do not see what power company has to do your particular house, that wild!
Jul 04, 2009 | Heating & Cooling
I own a nissan pulsar 2001 LX & the air con swith dosn't work on 1,2,3 & on 4 the fan blows the air in full force. I'm in the process of selling & need to fix it asap & as cheap as poss. hopfully it's a...
A cheap and nasty way to make it work is to by pass pressure switch in the engine bay,your aircon has shut itself down to protect itself.the switch thats responsible for that is either on the air con compressor with two wires plugged into it or close to the reciever/drier, join the wires together and the air con switch and associated parts will work again.This is a short term fix as the switch is there to tell you that the aircon pressure is too low and ultimately it will need recharging.
Dec 28, 2008 | Nissan Pulsar Cars & Trucks
No air
You may have to get aircon recharged as pressure regulator switch on aircon pump is not allowing use of pump to protect itself.easy test is to take the two wires off the switch and join them if the air con pump works you will need to recharge.Do not leave hooked up as pump will eventualy sieze.
Oct 11, 2008 | 1996 Jeep Grand Cherokee
Sudden brownout
hi,
it has a small microcomputer which will shut off if /or error if the voltage parameters are too far out(brownout,surge) carriers are a higher end machine, better parts, should be fine..
jm
Jul 27, 2017 | Carrier Heating & Cooling
Heating & Cooling Logo
342 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
