Question about Maytag Neptune FAV6800AW Top Load Washer
I have a maytag 6800 toploader. Water from bottom
I have a maytag 6800 toploader. I noticed there is water leaking out the bottom. Any help would be appeciated.
  • 335 Answers
If you feel OK to troubleshoot the Service Manual will give you some possible leak points to check. If you want to troubleshoot you beyond basic inspection you will need to remove the front panel and observe where the leak source might be. Worse case a tub seal issue. Easier fix would be a leak in the drain line; tub to drain pump/drain pump to output drain hose, one poster recently reported a cracked drain pump housing as their leak source. Here is a link for the manual.
The one leak source I would be concerned with is a leak described around the clutch pulley on page 28. If that is your leak source it’s a big project and you may need think about a service repair (BIG$ for labor but see if you can get a no cost quote) or a replacement machine if it’s not cost effective to repair. If you go the replacement direction call the Maytag CSV phone number at the end of the manual and complain, I got them to offer up a 25% rebate by talking to a supervisor on their Whirlpool, Amana, Maytag product line (don’t shoot the messenger). I’m a DIY’er and if I can’t fix this thing for under $300 with ebay parts I would move on. But let’s go one step at a time and try to ID the leak source.
To help you remove the front panel see page 33 Pic for the putty knife insertion point to raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base.
See page 41 for front panel removal don’t poke around in there with the power on just view for a water leak with a flash light while the machine fills in a Quick Wash cycle and as the machine proceeds through the wash cycle. Safety first, please follows the safety guide lines in the SM. Post again if you have questions and I’m sure I or other forum members will chime in for support. Good Luck.
Posted on Mar 04, 2009
My GE topload washing machine is leaking
Check the hose that connects to the bottom of the tub to the drain hose. Make sure that hose is securely fastened.
May 29, 2012 | GE Washing Machines
Leaking water Maytag Washer
If the connecting hoses is not a problem then it is probably be the pump present inside the machine.It helps in moving and draining the water.If it is not working then such problems might arise.It is best that you ask the plumber to replace it instead of you doing it
Apr 10, 2010 | Maytag PAV2300 Top Load Washer
My maytag topload washer overfilled,
It isn't a sensor problem, it sounds more like your water level tube has pulled loose. This is attached to the outer drum itself. You can see it when you remove your front cover to the right of the outer tub. This tube uses the pressure generated from your tub water level to push air up to your water level selector, which has a rubber membrane that flexes and closes 2 contacts as the water level makes the rubber expand. If that tube is off, the water will just keep running.
Mar 18, 2010 | Maytag MAV3905EWW 13 Cycle Washer
Maytag top load washing machine leaking water from bottom
The machine is leaking water from the bottom, I think the leak is in the area near where the motor is mounted. Before we noticed the water comes from underneath the washer, we smelled like burning rubber.
Al Bana
Jun 26, 2009 | Maytag PAV2300 Top Load Washer
Maytag washer
Many of the maytag toploaders have a rubber fill hose at the top of the outer drum.
Sometimes if the machine is fully loaded (or overloaded), during the spin cycle if clothes are above the top of the drum they can actually knock the rubber flange of the hose out of the drum. Then when the machine fills with water, it will dump it down the outside of the tub and it will appear that the water is leaking from the top and side of the drum... Fix it by snapping the fill hose flange back into the hole in the top part of the drum... let me know how you do or need more help...
Mar 23, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
Maytag FAV 6800 leaks while filling
I was finally able to fix our leak. Noticed that when closed the back of the lid bent down a little toward the middle.  That was enough obstruct the water shooting into the lid causing it to spray out of the top a little and leak out the back alot.  Took the lid off, bent it back, and now it works!
Jun 15, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag LA212 Toploading Washer - leaks as soon as a load is started. Will continue to leak until washer is stopped. Not a small leak - there is a puddle two days later in the floor below it. Removed...
It appears that from that area the problem may be the water inlet valve or it's connections. See diagram
Nov 02, 2017 | Maytag Washing Machines
No hot water for a Maytag topload washer
Turn the water off and disconnect the hot wat hose from the spigot and the machine. There should be a screen filter in one end. Check to see if the screen is clogged. If it is then replace it. If not then replace the water valve
Jan 10, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Sep 07, 2007 | Maytag MAT13MN Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
191 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
