Question about KitchenAid Ovens
Wolf DO30U Shuts off after 8 min on Broil mode.
Hi, I have a Wolf Double Oven DO30U and when in Broil mode it shuts off after 8 min and the cool fan starts up. This happens with both top & bottom units. Any advice?
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    SOURCE: cooling fan does not come on at all...
    Hi ,I posted this problem as well (ROYP75) I fixed the problem by replacing the printed circuit board(this amongst other things controls the fan speed).If you can remove and replace self tapping screws and replace wires like for like on the circuit board you can do this.Isolate from gas and electric, remove oven back taking care with fan wires, wires connected to circuit board and fan connected to oven back once removed you will see circuit board and from their it's just a case of swapping parts .circuit board was purchased from espares .co.uk part no es660722 hope you find this helpful
    Posted on Feb 14, 2009
    SOURCE: GE JTP56 double oven controls OK top OK bottom no heat
    have you inserted the business card as described in the solutions?
    Posted on Jun 28, 2009
    • 52 Answers
    SOURCE: OVEN GAS SHUTS OFF
    Sounds like a bad safety valve.
    Posted on Jul 15, 2009
    heatman101
    • 43501 Answers
    SOURCE: Double Oven Bottom oven will heat in Bake mode but will broil
    Check out this tip that I wrote about this problem...
    http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
    heatman101
    Posted on Apr 26, 2010
    Bosch oven cooling fan is continuously on at the same speed and is on always no matter what the temperature is. Upper heating element does not turn red hot in broil mode.
    The oven has internal fan at back of oven encircling the element that should get reshot when stat turned up high. Also there is cooling fan under lid to keep the wiring area cool.This should stay on for around ten - fifteen minutes after cooking finished. David "The Famous Forry"
    Oct 16, 2017 | Bosch Ovens
    Auto clean problem
    You say you checked the thermal fuse but did you check the broil element for continuity. Most ovens use the broil element for the clean function. The thermal fuse will shut off both the bake and the broil element.
    Feb 16, 2014 | Whirlpool GBD307PR Electric Double Oven
    Unit shuts off when using broiler
    can't broil with door open with these models. If closed, most likely an air flow issue with the cooling fan above in the control panel.
    Nov 15, 2013 | Thermador C272 Electric Double Oven
    I have a Thermador Model C302U wall oven the fan on the uppper oven starts and then stops and I get the F34 code I am thinking to replace the motor but I want to know if there are other things I should...
    When that fan starts up the air pushes against an air switch and that tells the board the fan is blowing. The stove uses a DAC system that relies on switchs to confirm the operations of the fan. the DAC control uses signal voltage to detect switch function. The air switches must physically close by air movement from the cooling blowers before the oven proceeds into a bake or broil mode. Reason being f the cooling motor does not function and the oven goes into a bake or broil mode, the oven will overheat and could damage the fancy smancy over engineered piece of garbage electronic components. My opinion. This is not for the DIY unless you are a TV repairman.
    Nov 03, 2011 | Thermador C302U Electric Double Oven
    Aeg oven d4100 cutting out
    There is a cooling fan in the cabinet of the oven which is not working either the fan is faulty or the controling cut in stat is, The fan should run when the grill is selected if does not it is more likely to be the fan/motor at fault.
    Dec 07, 2009 | AEG D2100-4 Electric Double Oven
    CPS227W Dacor double wall oven from 1995. Problem is common to both upper and lower ovens on any cooking mode (broil, bake, etc). Turn on, set temperature, hear a relay click on, then about 15 seconds...
    I have the same problem, however I found that if I just hold the Bake, Broil.ect button in until you hear the relay click then the oven functions normally.
    Sep 26, 2009 | Ovens
    Cooling fan does not come on at all...
    Oct 06, 2008 | New World G60m Gas Single Oven
    My oven turns off on me after only a minute never heating up fully
    Could be caused by either of following;
    1. Faulty thermostat.
    2. Faulty thermal cut out switch. (controls power to cooling fan).
    3. Faulty cooling fan (not fan inside oven).
    Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
    To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
    When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
    If mains current exist but fan is not turning then replace fan. If mains voltage is not present then its the thermal switch.
    Jun 19, 2008 | AEG B1180-4 Electric Single Oven
    Fan on during cooking
    djpat, in looking at your schematic, it shows that the cooling fan will be on during bake and broil operations as well as cleaning. So this would be a normal operation. Catriver.
    Dec 24, 2007 | Whirlpool RBD245PD Electric Double Oven
    Ovens Logo
    67 people viewed this question
    Top KitchenAid Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
